Boost your workteam with the HP LaserJet P2050 Printer Series. Create high quality documents with 1200 dpi, at fast speeds of up to 33 ppm. Performance features include expandable memory, automatic two-sided printing and Gigabit networking.
Get more done in less time with this high performance HP LaserJet
Get print speeds of up to 33 ppm A4 and a fast first page out from low power mode with no wait Instant-on Technology.Save time and paper with convenient automatic two-sided printing.Quickly and accurately process complex print jobs with a 600 MHz processor and expandable memory.Enjoy reliable sharing and efficiently utilise printing resources with high speed connectivity via built-in Gigabit networking.Easily connect the printer to your computer with the Hi-Speed USB 2.0 port. -
Create professional quality output with this compact printer
Achieve professional quality with true 1200 dpi resolution for crisp text, fine lines and sharp images, every time you print.Adjustable paper trays help you easily print a variety of black-and-white documents in all sizes from A6 to A4 (from all trays).Save valuable desktop space and enjoy convenient access to the printer with its sleek, compact design.The high yield, All-in-one HP LaserJet print cartridge is designed for simplicity and delivers consistently great results. -
Easy to set up, use and maintain
Navigation is intuitive with the LCD control panel.Experience fewer interruptions with a 250-sheet input tray, 50-sheet multipurpose tray and optional 500-sheet tray.Conveniently order supplies with HP SureSupply.HP Web Jetadmin enables access to printer status, alerts, configuration settings and more. HP Universal Print Driver increases ease of use and productivity.Interactive intelligence built into the HP print cartridge enables alerts when supplies are low, making management easy.
- HP LaserJet P2055 - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 9.9 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 33 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Image Enhancement Technology
- HP ProRes 1200 / HP FastRes 1200
- Interface
- USB
- Processor
- 600 MHz
- RAM Installed (Max)
- 64 MB (384 MB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, glossy paper
- Total Media Capacity
- 300 sheets
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 750 - 3000 pages
- System Requirements
- UNIX, Novell NetWare, Linux, Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Apple MacOS X 10.4, Apple MacOS X 10.3.9, Microsoft Windows Vista, Apple MacOS X 10.5.x
- Microsoft Certification
- Works with Windows Vista
- 1-year warranty
- 36.6 cm x 36.8 cm x 26.8 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 1200 dpi
- First Print Out Time B/W
- 8 sec
- Fonts Included
- 45 x TrueType , 35 x PostScript
- Processor
- 600 MHz
RAM
- 64 MB / 384 MB (max)
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 216 mm x 356 mm
- Media Sizes
- Legal (216 x 356 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), A4 Long (210 x 348 mm)
- 300 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) , 1 x automatic - 250 sheets - Legal (216 x 356 mm)
- Max Media Capacity
- 800 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 50000 pages
- 750 - 3000 pages
- Connections
- 1 x USB 2.0
- Consumables Included
- 1 x toner cartridge (black)
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- FCC Class B certified, UL, cUL, EN 61000-3-2, GS, ICES-003, IEC 825-1/EN 60825-1 class 1, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 570 Watt
- Power Consumption Stand by / Sleep
- 8 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - parts and labour - 1 year
- 17.5 °C
- 25 °C
- 30 - 70%
- 36.6 cm
- 36.8 cm
- 26.8 cm
- 9.9 kg
- Width (Shipping)
- 48.1 cm
- Depth (Shipping)
- 67.7 cm
- Height (Shipping)
- 26.8 cm
- Weight (Shipping)
- 12.4 kg
