HP LaserJet P2035 Mono Laser Printer
HP LaserJet P2035 Printer
Quicklinx: 5CCPWS00 Mfr#: CE461A#B19
  • Enhance productivity and get great value for money with this black-and-white HP LaserJet
    Enjoy fast print speeds of up to 30 ppm and get a fast first page out from low power mode with Instant-on Technology.Conveniently connect your printer to a computer using the USB or parallel port.Print a variety of office documents of almost any length, with a 250-sheet input tray; the 50-sheet multipurpose tray supports a variety of print media.Process complex files quickly with a 266 MHz processor and 16 MB memory.
  • Achieve impressive, professional quality results with this conveniently compact printer
    Print professional-quality documents with crisp text and sharp images thanks to HP FastRes 1200 which provides 1200 dpi effective output quality.This sleek, space-saving printer's compact design ensures that it fits conveniently into a small area of the desktop.Reduce operation noise with the printer's unique Quiet mode.The reliable all-in-one HP LaserJet print cartridge is designed to meet your usage needs, optimise print quality and provide excellent value.
  • Extremely easy to set up, use, and maintain
    Interactive intelligence built into the Original HP print cartridge optimises print quality and provides alerts when supplies are low, making management straightforward.One-door access to the easy-to-install HP LaserJet Print Cartridge means installation and replacement are simple and convenient.Easily navigate printer functions with the simple LED control panel.
  • You'll hardly notice it's there
    Select quiet mode to reduce printer operation noise.Easily print a range of media sizes including cards and prescription-size forms.
HP LaserJet P2035 - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
9.9 kg
English / United Kingdom
Max Media Size (Standard)
Legal
Print Speed
Up to 30 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
Max Resolution ( B&W )
1200 dpi
Image Enhancement Technology
HP ProRes 1200 / HP FastRes 1200
Parallel, USB
266 MHz
RAM Installed ( Max )
16 MB ( 16 MB )
Language Simulation
PCL 5E
Media Type
Envelopes, transparencies, labels, plain paper, glossy paper, cards
Total Media Capacity
300 sheets
Monthly Duty Cycle (max)
25000 pages
AC 120 V
UNIX, Novell NetWare, Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9, Apple MacOS X 10.4.3, Microsoft Windows Vista, Apple MacOS X 10.5.x
Microsoft Certification
Certified for Windows Vista
1 year warranty
36.6 cm x 36.8 cm x 25.7 cm
Printer Type
Printer
Print Speed
Wired
Parallel, USB
1200 dpi
PostScript Support
Standard
First Print Out Time B/W
8 sec
Language Simulation
PCL 5E
Fonts Included
45 x TrueType
266 MHz
RAM
16 MB / 16 MB (max)
Media Handling
Media Type
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm)
300 sheets
Media Feeder(s)
1 x autoload - 50 sheets - Legal (216 x 356 mm) , 1 x autoload - 250 sheets - Legal (216 x 356 mm)
Output Trays Capacity
150 sheets
Duty Cycle
25000 pages
1 x USB 2.0 , 1 x parallel
Consumables Included
1 x toner cartridge ( black )
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
FCC Class B certified, UL, cUL, EN 61000-3-2, GS, ICES-003, IEC 825-1/EN 60825-1 class 1, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1
Power supply - internal
AC 220 to 240 V
Frequency Required
50 Hz
550 Watt
Power Consumption Stand by / Sleep
7 Watt
Software Included
Drivers & Utilities
1 year warranty
Service & Support Details
Limited warranty - 1 year - on-site - response time: next business day
17.5 °C
25 °C
30 - 70%
36.6 cm
36.8 cm
25.7 cm
9.9 kg
5CCP HP 05A Dual Pack Black Toner Cartridge for LaserJet P2035/P2055 In Stock £159.36
Resources
The following resources are available for the HP LaserJet P2035 Mono Laser Printer
