HP LaserJet MFP M234sdw Multifunction Printer
Quicklinx: GXR6WS00 Mfr#: 6GX01F#B19
Type: Printer / copier / scanner
Functionality: Copier, Printer, Scanner
Output Type: Monochrome
Wireless Capability: Wired, Wireless
Technology: Laser
29 In Stock
£170.57 ex VAT
£204.68 inc VAT
A high-productivity MFP with the fastest two-sided printing in its class, an automatic feeder, and the time-saving HP Smart app. Count on peace of mind from more reliable connections, and a worry-free experience with simplified setup.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Fastest in-class two-sided printing speed
    Speed through multipage documents with the fastest in-class two-sided printing speed.
  • Small size. Big performance
    A LaserJet so compact it can fit almost anywhere.
  • Your reliable connection
    Get better range and faster, more reliable connections using dual-band Wi-Fi with self-reset.
  • Increase productivity
    Breeze through tasks with automatic scanning and copying.
  • Seamless setup
    Get started fast with simple setup that guides you through each step, with HP app.
  • Amazing scanning, now on your smartphone
    Get high-quality scanning, and share to Dropbox, Google Drive, email, or the cloud – from virtually anywhere.
HP LaserJet MFP M234sdw - multifunction printer - B/W
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
200 - 2000 pages
Max Copying Speed
Up to 29 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 29 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Scanning
600 x 600 dpi
Display
1.6"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
101.6 x 152.4 mm (min) - 216 x 356 mm (max)
Media Type
Envelopes, plain paper, bond paper
Standard Media Capacity
150 sheets
Max Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), Bluetooth LE
AirPrint Enabled
Office Machine Features
Scan to e-mail, Mopria certified, anti-dust cover, scan to PC, HP Auto-On/Auto-Off Technology, IPP printing, print from mobile devices, scan to PDF
AC 230 V (50/60Hz)
41.8 cm x 30.8 cm x 29.44 cm
9.5 kg
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified, Blue Angel
1-year warranty
Printing Technology
Laser - monochrome
20000 pages
200 - 2000 pages
Display Diagonal Size
1.6"
Display Features
Icon LCD display
AirPrint Enabled
Standard Memory
64 MB
Max Supported Memory
64 MB
Copying
Max Copying Speed
Up to 29 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 29 ppm
Printer Drivers / Emulations
PCLms, URF, PWG
Automatic Duplexing
First Print Out Time B/W
7 sec
Scanning
Optical Resolution
600 x 600 dpi
Colour Depth
24-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
40 sheets
Min Media Size
101.6 x 152.4 mm
Max Media Size
Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
43 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, JIS B6 (128 x 182 mm)
150 sheets
Max Media Capacity
150 sheets
100 sheets
Input tray - 150 sheets size: 101.6 x 152.4 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m²; weight (lbs): 16 lbs - 43 lbs , Output tray - 100 sheets size: 101.6 x 152.4 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m²; weight (lbs): 16 lbs - 43 lbs
Speed Details
Printing: up to 29 ppm (A4) - B/W normal , Printing: up to 30 ppm (Letter A) - B/W normal , Printing: up to 18 ppm (A4) - B/W duplex , Printing: up to 19 ppm (Letter A) - B/W duplex , Printing: up to 7 ppm (A5) - B/W portrait , Copying: up to 29 ppm (A4) - B/W normal , Copying: up to 30 ppm (Letter A) - B/W normal , Copying: up to 18 ppm (A4) - B/W duplex , Copying: up to 19 ppm (Letter A) - B/W duplex , Scanning: up to 19 ppm (A4) - B/W normal , Scanning: up to 10 ppm (A4) - colour normal
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
SSL, Apple Bonjour, TLS, IPv6 support, SNMP 3
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), macOS 10.13, MS Windows Server 2016 x64 Edition, macOS 10.14, macOS 10.15
Software Included
HP Printer Assistant
AC 230 V (50/60Hz)
453 Watt
Power Consumption Standby
3.3 Watt
Power Consumption Sleep
0.6 Watt
Warm-Up Time
45 sec
First Copy Out Time B/W
8 sec
Consumables Included
1 x toner cartridge (black) - up to 700 pages
UL, TUV GS, BSMI, CCC, FCC, IEC 60825-1, FCC CFR47 Part 15 C, FCC CFR47 Part 15 B, EN 60825-1, KC, EAC, EN 62479:2010, RCM, Blue Angel Ecolabel, BIS, EN 61000-3-3:2013, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, IEC 62311:2007, EN 55032:2012, RSS-102 Issue 5, RSS-247 Issue 1, FCC CFR47 Part 15 E, ICES-003 issue 6, EN 62368-1:2014, CAN/CSA-C22.2 No. 62368-1, CISPR 32:2012, EN 300 328 V2.1.1, UL 62368-1, CISPR 32:2015, EN 55032:2015+AC:2016 Class B, RED 2014/53/EU, EN 55035:2017, Mercury-free, EN 301 893 V2.1.1, DE-UZ 205, EN 301 489-17 V3.2.0, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, IPv6, EN 301 489-1 V2.2.3
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
41.8 cm
30.8 cm
29.44 cm
9.5 kg
Shipping Width
49.7 cm
Shipping Depth
37.9 cm
Shipping Height
40.9 cm
Shipping Weight
12.45 kg
Sound Emission
51 dBA (operating)
15 °C
32.5 °C
10 - 80%
Ink (2)
GXR6 HP 135A Black Original LaserJet Toner In Stock £36.07
GXR6 HP 135X - High Yield - black - original - LaserJet - toner cartridge In Stock £58.79
Other bundles (4)
GXR6 HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment In Stock £40.43
GXR6 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £47.70
GXR6 HP Care Pack Standard Exchange Extended Service Agreement 2 Years Shipment In Stock £21.99
GXR6 HP 2y Nbd Exch Cons Laserjet MFP-E SVC -HP Consumer Laserjet MF In Stock £27.47
Functionality: Printer
Functionality: Scanner
Wireless Capability: Wireless
Technology: Laser
Max Print Speed: 29ppm
Max Paper Size: 216 x 356 mm
Brand: HP
