A high-productivity MFP with the fastest two-sided printing in its class, an automatic feeder, and the time-saving HP Smart app. Count on peace of mind from more reliable connections, and a worry-free experience with simplified setup.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Fastest in-class two-sided printing speed
Speed through multipage documents with the fastest in-class two-sided printing speed. -
Small size. Big performance
A LaserJet so compact it can fit almost anywhere. -
Your reliable connection
Get better range and faster, more reliable connections using dual-band Wi-Fi with self-reset. -
Increase productivity
Breeze through tasks with automatic scanning and copying. -
Seamless setup
Get started fast with simple setup that guides you through each step, with HP app. -
Amazing scanning, now on your smartphone
Get high-quality scanning, and share to Dropbox, Google Drive, email, or the cloud – from virtually anywhere.
- HP LaserJet MFP M234sdw - multifunction printer - B/W
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 200 - 2000 pages
- Max Copying Speed
- Up to 29 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 29 ppm
- Max Printing Resolution
- Scanning
- 600 x 600 dpi
- Display
- 1.6"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 40 sheets
- Media Size
- 101.6 x 152.4 mm (min) - 216 x 356 mm (max)
- Media Type
- Envelopes, plain paper, bond paper
- Standard Media Capacity
- 150 sheets
- Max Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), Bluetooth LE
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, Mopria certified, anti-dust cover, scan to PC, HP Auto-On/Auto-Off Technology, IPP printing, print from mobile devices, scan to PDF
- Power
- AC 230 V (50/60Hz)
- 41.8 cm x 30.8 cm x 29.44 cm
- 9.5 kg
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Laser - monochrome
- 20000 pages
- 200 - 2000 pages
- Display Diagonal Size
- 1.6"
- Display Features
- Icon LCD display
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 64 MB
- Max Supported Memory
- 64 MB
Copying
- Max Copying Speed
- Up to 29 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy
Printing
- Up to 29 ppm
- Printer Drivers / Emulations
- PCLms, URF, PWG
- First Print Out Time B/W
- 7 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 40 sheets
- Min Media Size
- 101.6 x 152.4 mm
- Max Media Size
- Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Min Media Weight (lb)
- 16 lbs
- Max Media Weight (lb)
- 43 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, JIS B6 (128 x 182 mm)
- 150 sheets
- 150 sheets
- 100 sheets
- Input tray - 150 sheets size: 101.6 x 152.4 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m²; weight (lbs): 16 lbs - 43 lbs , Output tray - 100 sheets size: 101.6 x 152.4 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m²; weight (lbs): 16 lbs - 43 lbs
- Speed Details
- Printing: up to 29 ppm (A4) - B/W normal , Printing: up to 30 ppm (Letter A) - B/W normal , Printing: up to 18 ppm (A4) - B/W duplex , Printing: up to 19 ppm (Letter A) - B/W duplex , Printing: up to 7 ppm (A5) - B/W portrait , Copying: up to 29 ppm (A4) - B/W normal , Copying: up to 30 ppm (Letter A) - B/W normal , Copying: up to 18 ppm (A4) - B/W duplex , Copying: up to 19 ppm (Letter A) - B/W duplex , Scanning: up to 19 ppm (A4) - B/W normal , Scanning: up to 10 ppm (A4) - colour normal
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- SSL, Apple Bonjour, TLS, IPv6 support, SNMP 3
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), macOS 10.13, MS Windows Server 2016 x64 Edition, macOS 10.14, macOS 10.15
- Software Included
- HP Printer Assistant
- Voltage Required
- 453 watt
- Power Consumption Standby
- 3.3 watt
- Power Consumption Sleep
- 0.6 watt
- Warm-Up Time
- 45 sec
- First Copy Out Time B/W
- 8 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- UL, TUV GS, BSMI, CCC, FCC, IEC 60825-1, FCC CFR47 Part 15 C, FCC CFR47 Part 15 B, EN 60825-1, KC, EAC, EN 62479:2010, RCM, Blue Angel Ecolabel, BIS, EN 61000-3-3:2013, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, IEC 62311:2007, EN 55032:2012, RSS-102 Issue 5, RSS-247 Issue 1, FCC CFR47 Part 15 E, ICES-003 issue 6, EN 62368-1:2014, CAN/CSA-C22.2 No. 62368-1, CISPR 32:2012, EN 300 328 V2.1.1, UL 62368-1, CISPR 32:2015, EN 55032:2015+AC:2016 Class B, RED 2014/53/EU, EN 55035:2017, Mercury-free, EN 301 893 V2.1.1, DE-UZ 205, EN 301 489-17 V3.2.0, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, IPv6, EN 301 489-1 V2.2.3
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 41.8 cm
- 30.8 cm
- 29.44 cm
- 9.5 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 37.9 cm
- Shipping Height
- 40.9 cm
- Shipping Weight
- 12.45 kg
- Sound Emission
- 51 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
Ink (2)
HP 135A Black Original LaserJet Toner | In Stock | £36.10 |
HP 135X - High Yield - black - original - LaserJet - toner cartridge | In Stock | £59.67 |
Other bundles (4)
HP Care Pack Standard Exchange Extended Service Agreement 3 Years Shipment | In Stock | £40.43 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment | In Stock | £48.51 |
HP Care Pack Standard Exchange Extended Service Agreement 2 Years Shipment | In Stock | £21.99 |
HP 2y Nbd Exch Cons Laserjet MFP-E SVC -HP Consumer Laserjet MF | In Stock | £27.47 |
