HP LaserJet MFP M234sdne
Quicklinx: GDCFWS00 Mfr#: 6GX00E#B19
A compact multifunction printer with the fastest two-sided printing in its class and the time-saving HP Smart app.Includes HP+, the smart printing system that keeps you connected and ready to print from virtually anywhere.
  • Fastest in-class two-sided printing speed
    Speed through multipage documents with the fastest in-class two-sided printing speed.
  • Small size. Big performance
    A LaserJet MFP so compact it can fit almost anywhere.
  • Increase productivity
    Get better range and faster, more reliable connections using dual-band Wi-Fi with self-reset.
  • Seamless setup
    Get started fast with simple setup that guides you through each step, with HP Smart app.
  • Amazing scanning, now on your smartphone
    Get high-quality scanning, and share to Dropbox, Google Drive, email, or the cloud – from virtually anywhere.
  • Printing just got more productive
    Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive.
HP LaserJet MFP M234sdne - multifunction printer - B/W
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
200 - 2000 pages
Max Copying Speed
Up to 29 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 29 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Scanning
600 x 600 dpi
Display
1.6"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Media Size
101.6 x 152.4 mm (min) - 216 x 356 mm (max)
Media Type
Envelopes, plain paper, bond paper
Standard Media Capacity
150 sheets
Max Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN
AirPrint Enabled
Office Machine Features
Scan to e-mail, Mopria certified, anti-dust cover, scan to PC, HP Auto-On/Auto-Off Technology, IPP printing, print from mobile devices, scan to PDF
AC 230 V (50/60Hz)
41.8 cm x 30.8 cm x 29.44 cm
9.5 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - monochrome
20000 pages
200 - 2000 pages
Display Diagonal Size
1.6"
Display Features
Icon LCD display
USB 2.0, LAN
AirPrint Enabled
Standard Memory
64 MB
Max Supported Memory
64 MB
Copying
Max Copying Speed
Up to 29 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
Resize
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 29 ppm
Printer Drivers / Emulations
PCLms, URF, PWG
Automatic Duplexing
First Print Out Time B/W
7 sec
Scanning
Scan Element
CIS
Optical Resolution
600 x 600 dpi
Colour Depth
24-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
Min Media Size
101.6 x 152.4 mm
Max Media Size
Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
43 lbs
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 101.6 x 152.4 mm, B6 (125 x 176 mm)
150 sheets
Max Media Capacity
150 sheets
100 sheets
Input tray - 150 sheets size: 101.6 x 152.4 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m²; weight (lbs): 16 lbs - 43 lbs , Output tray - 100 sheets size: 101.6 x 152.4 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m²; weight (lbs): 16 lbs - 43 lbs , ADF - 40 sheets size: 101.6 x 152.4 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m²; weight (lbs): 16 lbs - 43 lbs
Speed Details
Printing: up to 29 ppm (A4) - B/W (ISO) , Printing: up to 29 ppm (A5) - B/W landscape , Printing: up to 18 ppm (A4) - B/W duplex , Printing: up to 19 ppm (Letter A) - B/W duplex , Printing: up to 7 ppm (A5) - B/W portrait , Copying: up to 29 ppm (A4) - B/W normal , Copying: up to 30 ppm (Letter A) - B/W normal , Scanning: up to 19 ppm (A4) - B/W normal , Scanning: up to 10 ppm (A4) - colour normal , Copying: up to 18 ppm (A4) - B/W duplex normal , Copying: up to 19 ppm (A4) - colour duplex normal
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
SSL, Apple Bonjour, TLS, IPv6 support, SNMP 3
Operating System Support
Linux, MS Windows Server 2008 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Server 2016, macOS 10.13, macOS 10.14, macOS 10.15
Software Included
HP Printer Assistant
AC 230 V (50/60Hz)
453 Watt
Power Consumption Standby
3.3 Watt
Power Consumption Sleep
0.6 Watt
Warm-Up Time
45 sec
First Copy Out Time B/W
8 sec
Consumables Included
1 x toner cartridge (black) - up to 700 pages
IEC 60950-1, FCC CFR47 Part 15 C, EN 300 328, IEC 60825-1 Class 1, EN 62311:2008, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62311:2007, RSS-102 Issue 5, RSS-247 Issue 1, FCC CFR47 Part 15 E, CAN/CSA-C22.2 No. 62368-1, UL 62368-1, Mercury-free, EN 301 893 V2.1.1, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, IEC/EN 62368-1, EN 301 489-1 V2.2.3
ENERGY STAR Certified
41.8 cm
30.8 cm
29.44 cm
9.5 kg
Shipping Width
49.7 cm
Shipping Depth
37.9 cm
Shipping Height
40.9 cm
Shipping Weight
12.45 kg
Sound Emission
51 dBA (operating)
15 °C
32.5 °C
10 - 80%
