A compact multifunction printer with the fastest two-sided printing in its class and the time-saving HP Smart app.Includes HP+, the smart printing system that keeps you connected and ready to print from virtually anywhere.
Fastest in-class two-sided printing speed
Speed through multipage documents with the fastest in-class two-sided printing speed. -
Small size. Big performance
A LaserJet MFP so compact it can fit almost anywhere. -
Increase productivity
Get better range and faster, more reliable connections using dual-band Wi-Fi with self-reset. -
Seamless setup
Get started fast with simple setup that guides you through each step, with HP Smart app. -
Amazing scanning, now on your smartphone
Get high-quality scanning, and share to Dropbox, Google Drive, email, or the cloud – from virtually anywhere. -
Printing just got more productive
Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive.
- HP LaserJet MFP M234sdne - multifunction printer - B/W
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 200 - 2000 pages
- Max Copying Speed
- Up to 29 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 29 ppm
- Max Printing Resolution
- Scanning
- 600 x 600 dpi
- Display
- 1.6"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Media Size
- 101.6 x 152.4 mm (min) - 216 x 356 mm (max)
- Media Type
- Envelopes, plain paper, bond paper
- Standard Media Capacity
- 150 sheets
- Max Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, Mopria certified, anti-dust cover, scan to PC, HP Auto-On/Auto-Off Technology, IPP printing, print from mobile devices, scan to PDF
- Power
- AC 230 V (50/60Hz)
- 41.8 cm x 30.8 cm x 29.44 cm
- 9.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - monochrome
- 20000 pages
- 200 - 2000 pages
- Display Diagonal Size
- 1.6"
- Display Features
- Icon LCD display
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Localisation
- Standard Memory
- 64 MB
- Max Supported Memory
- 64 MB
Copying
- Max Copying Speed
- Up to 29 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Resize
Printing
- Up to 29 ppm
- Printer Drivers / Emulations
- PCLms, URF, PWG
- First Print Out Time B/W
- 7 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- Min Media Size
- 101.6 x 152.4 mm
- Max Media Size
- Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Min Media Weight (lb)
- 16 lbs
- Max Media Weight (lb)
- 43 lbs
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 101.6 x 152.4 mm, B6 (125 x 176 mm)
- 150 sheets
- 150 sheets
- 100 sheets
- Input tray - 150 sheets size: 101.6 x 152.4 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m²; weight (lbs): 16 lbs - 43 lbs , Output tray - 100 sheets size: 101.6 x 152.4 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m²; weight (lbs): 16 lbs - 43 lbs , ADF - 40 sheets size: 101.6 x 152.4 mm - 216 x 356 mm weight: 60 g/m² - 163 g/m²; weight (lbs): 16 lbs - 43 lbs
- Speed Details
- Printing: up to 29 ppm (A4) - B/W (ISO) , Printing: up to 29 ppm (A5) - B/W landscape , Printing: up to 18 ppm (A4) - B/W duplex , Printing: up to 19 ppm (Letter A) - B/W duplex , Printing: up to 7 ppm (A5) - B/W portrait , Copying: up to 29 ppm (A4) - B/W normal , Copying: up to 30 ppm (Letter A) - B/W normal , Scanning: up to 19 ppm (A4) - B/W normal , Scanning: up to 10 ppm (A4) - colour normal , Copying: up to 18 ppm (A4) - B/W duplex normal , Copying: up to 19 ppm (A4) - colour duplex normal
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- SSL, Apple Bonjour, TLS, IPv6 support, SNMP 3
- Operating System Support
- Linux, MS Windows Server 2008 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Server 2016, macOS 10.13, macOS 10.14, macOS 10.15
- Software Included
- HP Printer Assistant
- Voltage Required
- 453 Watt
- Power Consumption Standby
- 3.3 Watt
- Power Consumption Sleep
- 0.6 Watt
- Warm-Up Time
- 45 sec
- First Copy Out Time B/W
- 8 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- IEC 60950-1, FCC CFR47 Part 15 C, EN 300 328, IEC 60825-1 Class 1, EN 62311:2008, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62311:2007, RSS-102 Issue 5, RSS-247 Issue 1, FCC CFR47 Part 15 E, CAN/CSA-C22.2 No. 62368-1, UL 62368-1, Mercury-free, EN 301 893 V2.1.1, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, IEC/EN 62368-1, EN 301 489-1 V2.2.3
- ENERGY STAR Certified
- 41.8 cm
- 30.8 cm
- 29.44 cm
- 9.5 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 37.9 cm
- Shipping Height
- 40.9 cm
- Shipping Weight
- 12.45 kg
- Sound Emission
- 51 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
