HP Laserjet MFP Analog Fax 300 Accessory
HP LaserJet MFP Analog Fax Accessory 300
Quicklinx: 3JZ8WS00 Mfr#: Q3701A#ABU
Easily send and receive documents by adding embedded analog fax functionality to your HP LaserJet MFP. Eliminate the need for a standalone analog fax with seamless integration on HP Color LaserJet 9500mfp, LaserJet 9040/9050mfp, and LaserJet 4345mfp.
HP Analog Fax Accessory 300 - fax interface card
Fax interface card
English / United Kingdom
Max Fax Transfer Rate
33.6 Kbps
Color LaserJet CM4730 MFP, CM4730f MFP, CM4730fm MFP, CM4730fsk MFP; LaserJet 4345mfp, 4345x mfp, 4345xm mfp, 4345xs mfp, M5025 MFP
Fax interface card
Modem
Wired
33.6 Kbps
HP Color LaserJet CM4730 MFP, CM4730f MFP, CM4730fm MFP, CM4730fsk MFP , HP LaserJet 4345mfp, 4345x mfp, 4345xm mfp, 4345xs mfp, M5025 MFP
