HP LaserJet M9050 MFP - multifunction printer - B/W
HP LaserJet M9050 Multifunction Printer
YOU BUY. YOU TRY. YOU DECIDE!
Quicklinx: 54LQWS00 Mfr#: CC395A#B19
Boost user productivity and enhance performance with fast A3 printing and copying. Save time and make office tasks more efficient with scan-to-email, digital sending and optional faxing, and a choice of paper-handling and finishing options.
  • Simplify everyday office tasks and save valuable time
    Work efficiently and simplify office tasks with an intuitive touch-screen control panel, and fast print and copy speeds of up to 40 ppm/up to 50 ppm. Send and receive faxes easily and save time with scan-to-email and digital sending.
  • Increase user productivity and improve performance
    Boost productivity and improve performance with a range of features which include paper handling and professional finishing options, and advanced solutions like document capture, job accounting and authentication.
  • Count on these HP LaserJet MFPs to deliver a consistently reliable experience
    Count on these MFPs to deliver industry-leading HP LaserJet reliability. Achieve consistent results with Original HP supplies. HP Web Jetadmin enables proactive fleet management and HP Jetdirect networking assures easy sharing in large workgroups.
Multifunction printer
English / United Kingdom
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
300000 impressions
Max Copying Speed
Up to 50 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 50 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 dpi
Original Size
A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Transparencies, plain paper, cards, labels, bond paper
Standard Media Capacity
3100 sheets
Max Media Capacity
3100 sheets
Output Trays Capacity
3000 sheets
Stacker
Optional
Stapler
Optional
Automatic Duplexing
Yes (copying)
Connection Availability
USB 2.0, Gigabit LAN
(50/60Hz)
Microsoft Certification
Works with Windows Vista
1-year warranty
Printing Technology
Laser - monochrome
300000 impressions
Standard Memory
256 MB 256 MB
Max Supported Memory
512 MB 512 MB
Hard Disk Drive
40 GB
Copying
Max Copying Speed
Up to 50 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Printing
Max Printing Speed
Up to 50 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF 1.3
Image Enhancement Technology
HP FastRes 1200
First Print Out Time B/W
9.5 sec
Scanning
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Colour Depth
30-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
100 sheets
Max Media Size
A3/Ledger
Min Media Weight
64 g/m²
Max Media Weight
227 g/m²
Supported Media Type
3100 sheets
Max Media Capacity
3100 sheets
3000 sheets
2 x input tray - 500 sheets - A3/Ledger (297 x 432 mm) , Input tray - 2000 sheets - A3/Ledger (297 x 432 mm) , Bypass tray - 100 sheets - 312 x 470 mm , ADF - 100 sheets - A3/Ledger (297 x 432 mm)
Speed Details
Printing: up to 50 ppm - B/W , Copying: up to 50 ppm - B/W
Finishing Equipment
Stacker
Optional
Stapler
Optional
1 x USB 2.0 , 1 x Gigabit LAN
Operating System Support
MS Windows 2000, Linux, IBM OS/2, Apple Mac OS X 10.3, Apple Mac OS X 10.2.8, Apple MacOS X 10.4 or later, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional
Software Included
Drivers & Utilities
(50/60Hz)
1092 watt
Power Consumption Standby
345 watt
Power Consumption Sleep
255 watt
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
15 °C
32.5 °C
54LQ HP 43X High Yield Black Original LaserJet Toner Cartridge In Stock £289.29
