Fulfill workteam A3 printing and copying needs and provide scan-to-email from your MFP plus optional fax functionality, with a tool that is affordable and easy to use and makes processes simple and efficient.
- HP LaserJet M5025 MFP - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 200000 impressions
- Max Copying Speed
- Up to 25 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 25 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 76 x 127 mm (min) - A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 312 x 470 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 2100 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Optional (copying)
- Connection Availability
- Interface
- USB 2.0, LAN
- 61 cm x 57.1 cm x 58.4 cm
- 55 kg
- Microsoft Certification
- Certified for Windows Vista
- Copier Type
- Digital
- Laser - monochrome
- Interface
- USB 2.0, LAN
- Standard Memory
- 256 MB 256 MB
- Max Supported Memory
- 512 MB 512 MB
- Hard Disk Drive
- 40 GB
Copying
- Max Copying Speed
- Up to 25 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 1000
- Optional
Printing
- Up to 25 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF 1.4
- Image Enhancement Technology
- HP FastRes 1200, HP ProRes 1200
- First Print Out Time B/W
- 10 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
Document & Media Handling
- Min Original Size
- 76 x 127 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A3
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 105 g/m²
- Supported Media Type
- 600 sheets
- 2100 sheets
- 100 sheets
- 250 sheets
- Bypass tray - 100 sheets size: 76 x 127 mm - 312 x 470 mm weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: 148 x 210 mm - 297 x 364 mm weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: 148 x 210 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 120 g/m² , ADF - 50 sheets size: 138 x 210 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 105 g/m² , Output tray - 250 sheets size: 76 x 127 mm - 312 x 470 mm weight: 60 g/m² - 120 g/m²
- Speed Details
- Printing: up to 25 ppm - B/W , Copying: up to 25 ppm - B/W
- 1 x USB 2.0 , 1 x LAN
- Network Protocols
- IPX/SPX, AppleTalk, DLC/LLC
- Operating System Support
- MS Windows XP, MS Windows 2000, MS Windows Server 2003, Apple MacOS X 10.2 or later, MS Windows XP Professional x64 Edition, Apple Mac OS X 10.3.9, Apple MacOS X 10.4 or later
- Software Included
- Drivers & Utilities
- 1265 Watt
- Power Consumption Standby
- 24 Watt
- Power Consumption Sleep
- 0.1 Watt
- Consumables Included
- 1 x toner cartridge (black) - up to 15000 pages
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- FCC Class B certified, cUL, EN 61000-3-2, ICES-003, NOM, EN 61000-3-3, EN55022 Class A, CISPR 22, FCC Part 68, FCC CFR47 Part 15, UL 60950-1, CSA C22.2 No. 60950-1-03
- 61 cm
- 57.1 cm
- 58.4 cm
- 55 kg
- Shipping Width
- 85.2 cm
- Shipping Depth
- 76.6 cm
- Shipping Height
- 72.1 cm
- Shipping Weight
- 61.1 kg
- 15 °C
- 35 °C
- 20 - 80%
