Fast print, scan, and copy performance in such a small but robust package. This MFP finishes key tasks faster and guards against threats. Original HP Toner cartridges with JetIntelligence give you more pages.
Speed through more tasks. Keep data protected.
Scan digital files directly to email, USB, network folders, and the cloud with preloaded business apps.
Breeze through multipage documents with two-sided printing that’s faster than the competition.
Grab pages and go – without waiting around. This MFP wakes up and prints faster than the competition.
Easy management. Efficient printing.
Easily manage print jobs directly at the MFP – just tap and swipe the 7.6 cm (3-inch) touchscreen.
Easily print Microsoft® Word and PowerPoint® documents – now directly from your USB drive.
Easily manage devices and settings using HP Web Jetadmin with a suite of essential management features.
More. Pages, Performance, and Protection
Get the most prints for your money – with Original HP High Yield Black Toner cartridges with JetIntelligence.
Count on professional quality at high speeds with precision black toner.
Help ensure you’re getting the authentic HP quality you paid for with innovative anti-fraud technology.
Stay connected with easy mobile printing options
Easily print from a variety of smartphones and tablets – generally no setup or apps required.
Count on wireless direct printing in the office – from mobile devices – without accessing the company network.
Easily access, print, and share resources with Ethernet and wireless networking.
Fastest first page out
This printer wakes up and prints faster than leading competitors. -
Fast two-sided printing
Breeze through multipage documents with two-sided printing that's faster than the competition. -
30% more pages
Get more pages than ever before, using Original HP High-Yield color toner cartridges with JetIntelligence. -
Helps save energy and easily manage tasks
Print using less energy than competitors - enhanced by Original HP Toner cartridges with JetIntelligence. -
Fast, easy scanning
Scan documents to email, USB, network folders and the cloud. -
Easy mobile printing
Print straight from your smartphone or tablet in just a few simple steps.
- HP LaserJet Pro MFP M426m - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish Chile / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 750 - 5000 pages
- Max Copying Speed
- Up to 38 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 38 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 3"
- Original Size
- 48.8 x 48.8 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, light-weight paper, punched paper, preprinted paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 900 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network, scan to Cloud, Instant-on Technology, Mobile Printing, HP Auto-On/Auto-Off Technology, JetIntelligence Cartridge Technology
- Power
- AC 230 V (50/60Hz)
- 42 cm x 39 cm x 32.3 cm
- 12.86 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Fax Type
- Plain paper
- Laser - monochrome
- 100000 pages
- 750 - 5000 pages
- Display Diagonal Size
- 3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Up to 38 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Fit to page, ID Card Copy, collation copy
Printing
- Up to 38 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.7, PCL 5, PCLm, URF, PWG
- Image Enhancement Technology
- HP FastRes 1200, HP ProRes 1200, HP ProRes 600
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- PC Faxing
Fax Machine Features
- Speed Dialing
- 120 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- 119 stations
- Delayed Transmission
- Remote Fax Retrieval (Polling)
- Fax forwarding, activity report, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax memory backup, block fax, poll receive, print fax log, billing codes
Document & Media Handling
- Min Original Size
- 48.8 x 48.8 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 175 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 102 x 152 mm, 254 x 381 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 197 x 273 mm, 127 x 127 mm, 216 x 355.6 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, JIS B6 (128 x 182 mm), 195 x 270 mm, 184 x 260 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 350 sheets
- 900 sheets
- 100 sheets
- 150 sheets
- ADF - 50 sheets size: 102 x 152 mm - Legal (216 x 356 mm) weight: 60 g/m² - 90 g/m² , Input tray - 250 sheets size: 104.9 x 148.6 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 175 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 38 ppm (A4) - B/W normal , Printing: up to 40 ppm (Letter A) - B/W normal , Printing: up to 30 ppm (A4) - B/W duplex , Printing: up to 32 ppm (Letter A) - B/W duplex , Copying: up to 38 ppm (A4) - B/W normal , Copying: up to 40 ppm (Letter A) - B/W normal , Copying: up to 30 ppm (A4) - B/W duplex , Copying: up to 32 ppm (Letter A) - B/W duplex , Scanning: up to 26 ppm - B/W , Scanning: up to 21 ppm - colour
- 1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- LDAP, SSL, Apple Bonjour, TLS, 802.1x, TKIP
- Operating System Support
- UNIX, Red Hat Linux 8.0, Red Hat Linux 9.0, Ubuntu Linux 10.04, Red Hat Enterprise Linux 5, Mandriva 2010, Red Hat Enterprise Linux 6, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Fedora 17, Fedora 18, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, MS Windows XP 64-bit Edition SP3 or later, Apple Mac OS X 10.9, Fedora 19, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Linux Mint 15, Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Ubuntu Linux 13.10, Windows 10 (32/64-bits), SuSe Linux 12.2, SuSe Linux 12.3, SuSe Linux 13.1, Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, MEPIS 6.0 or later, Slackware Linux 9.0 or later, gOS 8.04.1, IGOS 1.0, Linpus Linux 9.4, Linpus Linux 9.5, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0 - 7.6, Mandriva 2011, MEPIS 6.5, MEPIS 7.0, MEPIS 8.0, PCLinuxOS 2006, PCLinuxOS 2007, PCLinuxOS 2008, PCLinuxOS 2009, Red Hat Enterprise Linux 7, Slackware Linux 9.1, Slackware Linux 10.0, Slackware Linux 10.1, Slackware Linux 10.2, Slackware Linux 11.0, Slackware Linux 12.0, Slackware Linux 12.1
- Software Included
- Drivers & Utilities, HP Update, HP Device Experience (DXP)
- Voltage Required
- 583 Watt
- Power Consumption Standby
- 9.1 Watt
- Power Consumption Sleep
- 2.7 Watt
- FCC Class B certified, ICES-003, FCC Part 68, CS-03, R&TTE, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CAN/CSA C22.2 No. 60950-1-07, GB 9254-2008, EN 61000-3-3:2008, IECEE CB, EN 61000-3-2:2006+A1:2009+A2:2009, NOM-151-SCTI-1999, IEC 60825-1:2007, EN 62479:2010, 21 CFR 1040.10, 21 CFR 1040.11, GB 17625.1-2012, ETSI ES203 021, EN 55024:2010, CISPR 22:2008, IEC 60950-1:2005 + A1:2009, IEC 62479:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 55022:2010 Class B
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 42 cm
- 39 cm
- 32.3 cm
- 12.86 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 39.8 cm
- Shipping Height
- 49 cm
- Shipping Weight
- 15.5 kg
- Sound Emission
- 55 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
