HP Laserjet M406dn A4 Mono 40ppm Laser Printer
Quicklinx: G9WHWS00 Mfr#: 3PZ15A#B19
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Laser
Hurry, only 3 left in stock!
£350.00 ex VAT
£420.00 inc VAT
HP's entry-level Enterprise-class printer with speeds up to 42 ppm and strongest security.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
  • Easy to use, simple to manage
    HP FutureSmart firmware can be updated with the latest features to optimize your investment for years to come. Centralize control of your printing environment with HP Web Jetadmin - and help build business efficiency. Easily enable workflows across your fleet with a consistent user experience and intuitive, tablet-like icons. Set up this printer fast, and easily manage device settings to help increase efficiency. The world's most secure printing the operating code (BIOS) is automatically checked during startup and repairs itself if compromised. Common Criteria certified to continually monitor memory activity to detect and stop attacks in real time. Firmware is automatically checked during startup to determine if it's authentic code - digitally signed by HP. The printer's outgoing network connections are inspected to stop suspicious requests and thwart malware.
  • Enhanced productivity to empower work teams
    Give workgroups what they need to succeed with hundreds of HP and third-party solutions and card reader support. Help ensure the security of confidential information with PIN/Pull printing to retrieve print jobs. Stay connected with an optional accessory for wireless, Bluetooth Low Energy, and NFC touch-to-print. Print directly from the 2.7-inch (6.9 cm) color display.
  • Sustainability is smart business
    Help save paper right out of the box. Two-sided (duplex) printing is set at default for automatic savings. Help reduce wasted paper and toner by only printing jobs that are truly needed, using HP Roam for Business. Save energy without sacrificing performance - this printer is ENERGY STAR and Blue Angel certified. Remove barriers and help meet compliance and accessibility standards with the HP Accessibility Kit (which includes Braille overlay and tactile adhesives, an HP Access Handle, and BigKeys LX Keyboard) and compatibility with HP Accessibility Assistant.
HP LaserJet Enterprise M406dn - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
Number of Users
3-10 users
8.5 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 40 ppm - high speed - A4 (210 x 297 mm) , Up to 40 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 42 ppm - high speed - ANSI A (Letter) (216 x 279 mm) , Up to 31 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 33 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Image Enhancement Technology
HP ProRes 1200 / HP FastRes 1200
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
800 MHz
RAM Installed (Max)
1 GB (1 GB)
Flash Memory Installed (Max)
4 GB
Language Simulation
PCL 5, PostScript 3, PCL 6, PDF 1.7
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, light-weight paper, punched paper, preprinted paper, letterheaded paper, coloured paper
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet input tray
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
900 - 4800 pages
Print server
Printer Features
Instant-on Technology, JetIntelligence Cartridge Technology
Microsoft Windows 7 Ultimate, Android, Microsoft Windows Server 2008 R2 x64 Edition, Apple iOS, Microsoft Windows Server 2012 x64 Edition, Windows 8.1, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows Server 2008 R2 SP1 (64-bits), Citrix XenServer 6.5, Windows 10, Microsoft Windows Server 2016 (64-bit), Citrix XenApp 7.6, Citrix XenDesktop 7.6, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Microsoft Windows Server 2019 (64-bit), Apple macOS Catalina 10.15
Environmental Standards
EPEAT Silver
1-year warranty
38.1 cm x 35.7 cm x 22 cm
Printer Type
Workgroup printer - laser - monochrome
Number of Users
3-10 users
Printer
Print Speed
Built-in Devices
24-key pad, 2.7 inch LCD display
Wired
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.5 sec
Language Simulation
Fonts Included
105 x TrueType , 92 x PostScript 3
Printer Features
Media Handling
800 MHz
RAM
RAM Installed (Max)
1 GB / 1 GB (max)
Flash Memory
Flash Memory
4 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 216 x 356 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm), Japanese postcard (100 x 148 mm), Japanese Postcard Double (148 x 200 mm)
Media Weight
60 g/m² - 175 g/m²
350 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 175 g/m² - (16 lbs (min) - 46.6 lbs (max)) , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² - (16 lbs (min) - 32 lbs (max))
Max Media Capacity
900 sheets
Output Trays Capacity
150 sheets
Duty Cycle
100000 pages
900 - 4800 pages
Print server
Remote Management Protocol
SNMP 2, SNMP 3, IPP, HTTP, HTTPS, SLP, DHCP, IPv4, IPv6
Security Protocols & Features
Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN , 1 x USB 2.0 host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 3000 pages ISO/IEC 19798
Security lock slot (cable lock sold separately), auto on/off, mercury free
FCC Class A certified, UL, cUL, GS, CECP, EN 62479:2010, IPsec/IKE, 21 CFR 1040.10, 21 CFR 1040.11, EN 61000-3-3:2013, CoC, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, FCC CFR47 Part 15 A, LVD 2014/35/EU, EN 55024:2010+A1:2015, EN 55032:2012, ICES-003 issue 6 Class A, EN 62368-1:2014, CISPR 32:2012, CISPR 35, EN 60825-1:2014, RAL-UZ 205, EN 55035:2017, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, IEC 60825-1:2014 Class 1
Security Slot Type
Kensington security slot
Power supply - internal
Frequency Required
50/60 Hz
531 watt
Power Consumption Stand by
8.1 watt
Power Consumption Sleep
1.2 watt
System Requirements Details
Windows 7/8.1/10 - HD 2 GB , MacOS - HD 2 GB
EPEAT Compliant
EPEAT Silver
Blue Angel
ENERGY STAR
Limited warranty - 1 year - on-site
15 °C
32.5 °C
10 - 90%
Sound Emission (Operating)
54 dBA
38.1 cm
35.7 cm
22 cm
8.5 kg
Width (Shipping)
44.3 cm
Depth (Shipping)
27.8 cm
Height (Shipping)
46.4 cm
Weight (Shipping)
11.37 kg
Ink (3)
G9WH HP 59A Black Original LaserJet Toner Cartridge In Stock £88.46
G9WH HP 59X High Yield Black Original LaserJet Toner Cartridge In Stock £184.01
G9WH HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £16.54
Other bundles (1)
G9WH HP 550 sheet paper tray for LaserJet Pro M402d, M402n, M402dn In Stock £100.51
Type: Printer
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
