HP's entry-level Enterprise-class printer with speeds up to 42 ppm and strongest security.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
                Easy to use, simple to manageHP FutureSmart firmware can be updated with the latest features to optimize your investment for years to come. Centralize control of your printing environment with HP Web Jetadmin - and help build business efficiency. Easily enable workflows across your fleet with a consistent user experience and intuitive, tablet-like icons. Set up this printer fast, and easily manage device settings to help increase efficiency. The world's most secure printing the operating code (BIOS) is automatically checked during startup and repairs itself if compromised. Common Criteria certified to continually monitor memory activity to detect and stop attacks in real time. Firmware is automatically checked during startup to determine if it's authentic code - digitally signed by HP. The printer's outgoing network connections are inspected to stop suspicious requests and thwart malware.
                Enhanced productivity to empower work teamsGive workgroups what they need to succeed with hundreds of HP and third-party solutions and card reader support. Help ensure the security of confidential information with PIN/Pull printing to retrieve print jobs. Stay connected with an optional accessory for wireless, Bluetooth Low Energy, and NFC touch-to-print. Print directly from the 2.7-inch (6.9 cm) color display.
                Sustainability is smart businessHelp save paper right out of the box. Two-sided (duplex) printing is set at default for automatic savings. Help reduce wasted paper and toner by only printing jobs that are truly needed, using HP Roam for Business. Save energy without sacrificing performance - this printer is ENERGY STAR and Blue Angel certified. Remove barriers and help meet compliance and accessibility standards with the HP Accessibility Kit (which includes Braille overlay and tactile adhesives, an HP Access Handle, and BigKeys LX Keyboard) and compatibility with HP Accessibility Assistant.
- HP LaserJet Enterprise M406dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- Number of Users
- 3-10 users
- 8.5 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 40 ppm - high speed - A4 (210 x 297 mm) , Up to 40 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 42 ppm - high speed - ANSI A (Letter) (216 x 279 mm) , Up to 31 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 33 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Image Enhancement Technology
- HP ProRes 1200 / HP FastRes 1200
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Processor
- 800 MHz
- RAM Installed (Max)
- 1 GB (1 GB)
- Flash Memory Installed (Max)
- 4 GB
- Language Simulation
- PCL 5, PostScript 3, PCL 6, PDF 1.7
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, light-weight paper, punched paper, preprinted paper, letterheaded paper, coloured paper
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet input tray
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 900 - 4800 pages
- Networking
- Print server
- Printer Features
- Instant-on Technology, JetIntelligence Cartridge Technology
- System Requirements
- Microsoft Windows 7 Ultimate, Android, Microsoft Windows Server 2008 R2 x64 Edition, Apple iOS, Microsoft Windows Server 2012 x64 Edition, Windows 8.1, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows Server 2008 R2 SP1 (64-bits), Citrix XenServer 6.5, Windows 10, Microsoft Windows Server 2016 (64-bit), Citrix XenApp 7.6, Citrix XenDesktop 7.6, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Microsoft Windows Server 2019 (64-bit), Apple macOS Catalina 10.15
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 38.1 cm x 35.7 cm x 22 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Number of Users
- 3-10 users
- Localisation
Printer
- Print Speed
- Built-in Devices
- 24-key pad, 2.7 inch LCD display
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.5 sec
- Fonts Included
- 105 x TrueType , 92 x PostScript 3
- Printer Features
- Media Handling
- Processor
- 800 MHz
RAM
- 1 GB / 1 GB (max)
Flash Memory
- Flash Memory
- 4 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 216 x 356 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm), Japanese postcard (100 x 148 mm), Japanese Postcard Double (148 x 200 mm)
- Media Weight
- 60 g/m² - 175 g/m²
- 350 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 175 g/m² - (16 lbs (min) - 46.6 lbs (max)) , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² - (16 lbs (min) - 32 lbs (max))
- Max Media Capacity
- 900 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 100000 pages
- 900 - 4800 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 2, SNMP 3, IPP, HTTP, HTTPS, SLP, DHCP, IPv4, IPv6
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN , 1 x USB 2.0 host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages ISO/IEC 19798
- Security lock slot (cable lock sold separately), auto on/off, mercury free
- FCC Class A certified, UL, cUL, GS, CECP, EN 62479:2010, IPsec/IKE, 21 CFR 1040.10, 21 CFR 1040.11, EN 61000-3-3:2013, CoC, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, FCC CFR47 Part 15 A, LVD 2014/35/EU, EN 55024:2010+A1:2015, EN 55032:2012, ICES-003 issue 6 Class A, EN 62368-1:2014, CISPR 32:2012, CISPR 35, EN 60825-1:2014, RAL-UZ 205, EN 55035:2017, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, IEC 60825-1:2014 Class 1
- Security Slot Type
- Kensington security slot
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 531 Watt
- Power Consumption Stand by
- 8.1 Watt
- Power Consumption Sleep
- 1.2 Watt
- OS Required
- System Requirements Details
- Windows 7/8.1/10 - HD 2 GB , MacOS - HD 2 GB
- EPEAT Compliant
- EPEAT Silver
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 15 °C
- 32.5 °C
- 10 - 90%
- Sound Emission (Operating)
- 54 dBA
- 38.1 cm
- 35.7 cm
- 22 cm
- 8.5 kg
- Width (Shipping)
- 44.3 cm
- Depth (Shipping)
- 27.8 cm
- Height (Shipping)
- 46.4 cm
- Weight (Shipping)
- 11.37 kg
Ink (3)
|  | HP 59A Black Original LaserJet Toner Cartridge | In Stock | £89.63 |
|  | HP 59X High Yield Black Original LaserJet Toner Cartridge | In Stock | £187.74 |
|  | HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £16.88 |
Other bundles (1)
|  | HP 550 sheet paper tray for LaserJet Pro M402d, M402n, M402dn | In Stock | £97.84 |
