HP LaserJet M209dwe Printer
Quicklinx: GJZ9WS00 Mfr#: 6GW62E#B19
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
A super compact mono laser printer with the fastest two-sided printing in its class and the time-saving HP Smart app. Includes HP+, the smart printing system that keeps you connected and ready to print from virtually anywhere.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits. HP+ requires an HP account, ongoing connection to the internet, and exclusive use of Original HP Ink cartridges for the life of the printer. More at:
  • Fastest in-class two-sided printing speed
    Speed through multipage documents with the fastest in-class two-sided printing speed.
  • Small size. Big performance
    A LaserJet so compact it can fit almost anywhere.
  • Your reliable connection
    Get better range and faster, more reliable connections using dual-band Wi-Fi with self-reset.
  • Seamless setup
    Get started fast with simple setup that guides you through each step, with HP Smart app.
  • Amazing scanning, now on your smartphone
    Get high-quality scanning, and share to Dropbox, Google Drive, email, or the cloud – from virtually anywhere.
  • Printing just got more productive
    Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive.
HP LaserJet M209dwe - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
Number of Users
1-5 users
5.6 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
102 mm x 152 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 29 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 29 ppm - black landscape - A5 (148 x 210 mm) , Up to 7 ppm - black portrait - A5 (148 x 210 mm) , Up to 19 inch/min - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 18 inch/min - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
600 x 600 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n), Bluetooth LE
AirPrint Enabled
500 MHz
Flash Memory Installed (Max)
64 MB (64 MB)
Language Simulation
URF, PWG, PCLmS
Media Type
Envelopes, labels, plain paper, card stock, postcards
Total Media Capacity
150 sheets
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
200 - 2000 pages
Print server
Linux, Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows Server 2008 R2 SP1 (64-bits), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit), Apple macOS 10.13, Apple macOS 10.14, Apple macOS 10.15
35.5 cm x 27.95 cm x 20.5 cm
Printer Type
Workgroup printer - laser - monochrome
Number of Users
1-5 users
Printer
Print Speed
Wireless
AirPrint Enabled
600 x 600 dpi
Automatic Duplexing
Language Simulation
URF, PWG, PCLmS
500 MHz
Flash Memory
Flash Memory
64 MB (installed) / 64 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
102 mm x 152 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 102 x 152 mm, JIS B5 (182 x 257 mm), 216 x 356 mm
Media Weight
60 g/m² - 163 g/m²
Media Weight (lbs)
16 lbs - 43 lbs
150 sheets
Media Feeders
Input tray: 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² - (16 lbs (min) - 43 lbs (max)) , Output tray: 1 - 100 sheets - Legal (216 x 356 mm)
Output Trays Capacity
100 sheets
Duty Cycle
20000 pages
200 - 2000 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, SLP, DHCP
Security Protocols & Features
SSL, Apple Bonjour, TLS
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 700 pages
Dust cover
UL, TUV GS, BSMI, CCC, FCC, IEC 60825-1, FCC CFR47 Part 15 C, EN 60825-1, KC, EAC, EN 62479:2010, RCM, BIS, EN 61000-3-3:2013, EN 62311:2008, EN 61000-3-2:2014, IEC 62479:2010, IEC 62311:2007, FCC CFR47 Part 15 B Class B, EN 55032:2012, RSS-102 Issue 5, SIRIM, RSS-247 Issue 1, FCC CFR47 Part 15 E, ICES-003 issue 6, EN 62368-1:2014, CAN/CSA-C22.2 No. 62368-1, CISPR 32:2012, EN 300 328 V2.1.1, UL 62368-1, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, CISPR 32:2015, EN 55032:2015+AC:2016 Class B, RED 2014/53/EU, EN 55035:2017, Mercury-free, EN 301 893 V2.1.1, DE-UZ 205, EN 301 489-17 V3.2.0, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 300 440-1 V2.1.1, EN 301 489-1 V2.2.3
Power supply - internal
420 Watt
Power Consumption Stand by
2 Watt
Power Consumption Sleep
0.5 Watt
Environmental Standards
Blue Angel
ENERGY STAR
15 °C
32.5 °C
10 - 80%
Sound Emission (Idle)
15 dBA
Sound Emission (Operating)
54 dBA
35.5 cm
27.95 cm
20.5 cm
5.6 kg
Width (Shipping)
43.2 cm
Depth (Shipping)
33.1 cm
Height (Shipping)
27.2 cm
Weight (Shipping)
7.3 kg
