A super compact mono laser printer with the fastest two-sided printing in its class and the time-saving HP Smart app. Includes HP+, the smart printing system that keeps you connected and ready to print from virtually anywhere.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits. HP+ requires an HP account, ongoing connection to the internet, and exclusive use of Original HP Ink cartridges for the life of the printer. More at:
Fastest in-class two-sided printing speed
Speed through multipage documents with the fastest in-class two-sided printing speed. -
Small size. Big performance
A LaserJet so compact it can fit almost anywhere. -
Your reliable connection
Get better range and faster, more reliable connections using dual-band Wi-Fi with self-reset. -
Seamless setup
Get started fast with simple setup that guides you through each step, with HP Smart app. -
Amazing scanning, now on your smartphone
Get high-quality scanning, and share to Dropbox, Google Drive, email, or the cloud – from virtually anywhere. -
Printing just got more productive
Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive.
- HP LaserJet M209dwe - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- Number of Users
- 1-5 users
- 5.6 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 102 mm x 152 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 29 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 29 ppm - black landscape - A5 (148 x 210 mm) , Up to 7 ppm - black portrait - A5 (148 x 210 mm) , Up to 19 inch/min - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 18 inch/min - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 600 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n), Bluetooth LE
- AirPrint Enabled
- Processor
- 500 MHz
- Flash Memory Installed (Max)
- 64 MB (64 MB)
- Language Simulation
- URF, PWG, PCLmS
- Media Type
- Envelopes, labels, plain paper, card stock, postcards
- Total Media Capacity
- 150 sheets
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 200 - 2000 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows Server 2008 R2 SP1 (64-bits), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit), Apple macOS 10.13, Apple macOS 10.14, Apple macOS 10.15
- 2-year warranty
- 35.5 cm x 27.95 cm x 20.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Number of Users
- 1-5 users
- Localisation
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 600 x 600 dpi
- URF, PWG, PCLmS
- Processor
- 500 MHz
Flash Memory
- Flash Memory
- 64 MB (installed) / 64 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 102 mm x 152 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 102 x 152 mm, JIS B5 (182 x 257 mm), 216 x 356 mm
- Media Weight
- 60 g/m² - 163 g/m²
- Media Weight (lbs)
- 16 lbs - 43 lbs
- 150 sheets
- Media Feeders
- Input tray: 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² - (16 lbs (min) - 43 lbs (max)) , Output tray: 1 - 100 sheets - Legal (216 x 356 mm)
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 20000 pages
- 200 - 2000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, SLP, DHCP
- SSL, Apple Bonjour, TLS
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- Dust cover
- UL, TUV GS, BSMI, CCC, FCC, IEC 60825-1, FCC CFR47 Part 15 C, EN 60825-1, KC, EAC, EN 62479:2010, RCM, BIS, EN 61000-3-3:2013, EN 62311:2008, EN 61000-3-2:2014, IEC 62479:2010, IEC 62311:2007, FCC CFR47 Part 15 B Class B, EN 55032:2012, RSS-102 Issue 5, SIRIM, RSS-247 Issue 1, FCC CFR47 Part 15 E, ICES-003 issue 6, EN 62368-1:2014, CAN/CSA-C22.2 No. 62368-1, CISPR 32:2012, EN 300 328 V2.1.1, UL 62368-1, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, CISPR 32:2015, EN 55032:2015+AC:2016 Class B, RED 2014/53/EU, EN 55035:2017, Mercury-free, EN 301 893 V2.1.1, DE-UZ 205, EN 301 489-17 V3.2.0, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 300 440-1 V2.1.1, EN 301 489-1 V2.2.3
- Power Device
- Power supply - internal
- 420 Watt
- Power Consumption Stand by
- 2 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 2 years
- 15 °C
- 32.5 °C
- 10 - 80%
- Sound Emission (Idle)
- 15 dBA
- Sound Emission (Operating)
- 54 dBA
- 35.5 cm
- 27.95 cm
- 20.5 cm
- 5.6 kg
- Width (Shipping)
- 43.2 cm
- Depth (Shipping)
- 33.1 cm
- Height (Shipping)
- 27.2 cm
- Weight (Shipping)
- 7.3 kg
