HP LaserJet M110w - Printer - B/W - laser - A4/Letter - 600
Quicklinx: H7PZWS00 Mfr#: 7MD66F#B19
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Max Paper Size: A4 (210 x 297 mm)
More than 50 In Stock
£90.45 ex VAT
£108.54 inc VAT
An efficient, high-quality laser printer that fits your space and budget. Get fast printing from HP's smallest laser in its class, plus the time-saving HP Smart app. Count on professional-quality laser printing and seamless setup.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Small size. Big performance
    A LaserJet so small it can fit almost anywhere.
  • Fast printing
    Get print speeds up to 21/20ppm.
  • Seamless setup
    Get started fast with simple setup that guides you through each step, with HP Smart app.
  • Legendary laser quality
    This surprisingly small laser delivers exceptional quality, page after page.
  • Amazing scanning, now on your smartphone
    Get high-quality scanning, and share to Dropbox, Google Drive, or cloud – from your phone with HP Smart app.
  • Printing just got more productive
    Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive.
HP LaserJet M110w - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
Number of Users
1-3 users
3.8 kg
English, French, Spanish, German, Italian / Europe
Media Size Class
A4/Letter
Max Media Size
A4 (210 x 297 mm)
Min Media Size (Custom)
105 mm x 148 mm
Max Media Size (Custom)
216 mm x 355.6 mm
Print Speed
Up to 20 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 21 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
600 x 600 dpi
Image Enhancement Technology
HP FastRes 600
USB 2.0, Wi-Fi(n), Bluetooth LE
AirPrint Enabled
500 MHz
RAM Installed (Max)
32 MB
Flash Memory Installed (Max)
16 MB
Language Simulation
URF, PWG, PCLmS, PCLm
Media Type
Envelopes, labels, plain paper, postcards
Total Media Capacity
150 sheets
Monthly Duty Cycle (max)
8000 pages
Recommended Monthly Volume
100 - 1000 pages
Print server
AC 100-240 V
Linux, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2008 R2 SP1 (64-bits), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit), Apple macOS 10.13, Apple macOS 10.14, Apple macOS 10.15
1-year warranty
34.6 cm x 18.9 cm x 15.9 cm
Printer Type
Workgroup printer - laser - monochrome
Number of Users
1-3 users
Printer
Print Speed
Wireless
AirPrint Enabled
600 x 600 dpi
HP FastRes 600
Language Simulation
500 MHz
RAM
RAM Installed (Max)
32 MB
Flash Memory
Flash Memory
16 MB
Media Handling
Media Type
Media Size Class
A4/Letter
Max Media Size
A4 (210 x 297 mm)
105 mm x 148 mm
216 mm x 355.6 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm)
Media Weight
65 g/m² - 120 g/m²
Media Weight (lbs)
17 lbs - 32 lbs
150 sheets
Media Feeders
Input tray: 1 - 150 sheets - 216 x 297 mm , Output tray: 1 - 100 sheets
Output Trays Capacity
100 sheets
Duty Cycle
8000 pages
100 - 1000 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, SLP, DHCP
Security Protocols & Features
Apple Bonjour
1 x USB 2.0 - 4 pin USB Type B
Setup poster
Consumables Included
1 x toner cartridge (black) - up to 300 pages ISO/IEC 19752
UL, TUV GS, BSMI, CCC, FCC, IEC 60825-1, FCC CFR47 Part 15 C, EN 60825-1, KC, EAC, EN 62479:2010, RCM, BIS, EN 61000-3-3:2013, EN 62311:2008, EN 61000-3-2:2014, IEC 62479:2010, IEC 62311:2007, FCC CFR47 Part 15 B Class B, EN 55032:2012, RSS-102 Issue 5, SIRIM, RSS-247 Issue 1, FCC CFR47 Part 15 E, ICES-003 issue 6, EN 62368-1:2014, CAN/CSA-C22.2 No. 62368-1, CISPR 32:2012, EN 300 328 V2.1.1, UL 62368-1, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, CISPR 32:2015, EN 55032:2015+AC:2016 Class B, RED 2014/53/EU, EN 55035:2017, Mercury-free, EN 301 893 V2.1.1, DE-UZ 205, EN 301 489-17 V3.2.0, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 300 440-1 V2.1.1, EN 301 489-1 V2.2.3
Power supply - internal
AC 100-240 V
Frequency Required
50/60 Hz
361 Watt
Power Consumption Stand by
2.3 Watt
Power Consumption Sleep
1 Watt
Environmental Standards
Blue Angel
ENERGY STAR
ENERGY STAR Version
3.0
Limited warranty - 1 year
15 °C
32.5 °C
10 - 80%
Sound Emission (Idle)
16 dBA
Sound Emission (Operating)
48 dBA
34.6 cm
18.9 cm
15.9 cm
3.8 kg
Width (Shipping)
37.8 cm
Depth (Shipping)
19.8 cm
Height (Shipping)
22.2 cm
Weight (Shipping)
4.8 kg
Type: Printer
Wireless Capability: Wireless
Brand: HP
