An efficient, high-quality laser printer that fits your space and budget. Get fast printing from HP's smallest laser in its class, plus the time-saving HP Smart app. Count on professional-quality laser printing and seamless setup.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Small size. Big performance
A LaserJet so small it can fit almost anywhere. -
Fast printing
Get print speeds up to 21/20ppm. -
Seamless setup
Get started fast with simple setup that guides you through each step, with HP Smart app. -
Legendary laser quality
This surprisingly small laser delivers exceptional quality, page after page. -
Amazing scanning, now on your smartphone
Get high-quality scanning, and share to Dropbox, Google Drive, or cloud – from your phone with HP Smart app. -
Printing just got more productive
Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive.
- HP LaserJet M110w - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- Number of Users
- 1-3 users
- 3.8 kg
- Localisation
- English, French, Spanish, German, Italian / Europe
- Media Size Class
- A4/Letter
- Max Media Size
- A4 (210 x 297 mm)
- Min Media Size (Custom)
- 105 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 355.6 mm
- Print Speed
- Up to 20 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 21 ppm - B/W (ISO/IEC 24734) - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 600 x 600 dpi
- Image Enhancement Technology
- HP FastRes 600
- Interface
- USB 2.0, Wi-Fi(n), Bluetooth LE
- AirPrint Enabled
- Processor
- 500 MHz
- RAM Installed (Max)
- 32 MB
- Flash Memory Installed (Max)
- 16 MB
- Language Simulation
- URF, PWG, PCLmS, PCLm
- Media Type
- Envelopes, labels, plain paper, postcards
- Total Media Capacity
- 150 sheets
- Monthly Duty Cycle (max)
- 8000 pages
- Recommended Monthly Volume
- 100 - 1000 pages
- Networking
- Print server
- Power
- AC 100-240 V
- System Requirements
- Linux, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2008 R2 SP1 (64-bits), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit), Apple macOS 10.13, Apple macOS 10.14, Apple macOS 10.15
- 1-year warranty
- 34.6 cm x 18.9 cm x 15.9 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Number of Users
- 1-3 users
- Localisation
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 600 x 600 dpi
- HP FastRes 600
- Processor
- 500 MHz
RAM
- 32 MB
Flash Memory
- Flash Memory
- 16 MB
Media Handling
- Media Type
- Media Size Class
- A4/Letter
- Max Media Size
- A4 (210 x 297 mm)
- 105 mm x 148 mm
- 216 mm x 355.6 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
- Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm)
- Media Weight
- 65 g/m² - 120 g/m²
- Media Weight (lbs)
- 17 lbs - 32 lbs
- 150 sheets
- Media Feeders
- Input tray: 1 - 150 sheets - 216 x 297 mm , Output tray: 1 - 100 sheets
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 8000 pages
- 100 - 1000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS, SLP, DHCP
- Apple Bonjour
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Included Accessories
- Setup poster
- Consumables Included
- 1 x toner cartridge (black) - up to 300 pages ISO/IEC 19752
- UL, TUV GS, BSMI, CCC, FCC, IEC 60825-1, FCC CFR47 Part 15 C, EN 60825-1, KC, EAC, EN 62479:2010, RCM, BIS, EN 61000-3-3:2013, EN 62311:2008, EN 61000-3-2:2014, IEC 62479:2010, IEC 62311:2007, FCC CFR47 Part 15 B Class B, EN 55032:2012, RSS-102 Issue 5, SIRIM, RSS-247 Issue 1, FCC CFR47 Part 15 E, ICES-003 issue 6, EN 62368-1:2014, CAN/CSA-C22.2 No. 62368-1, CISPR 32:2012, EN 300 328 V2.1.1, UL 62368-1, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, CISPR 32:2015, EN 55032:2015+AC:2016 Class B, RED 2014/53/EU, EN 55035:2017, Mercury-free, EN 301 893 V2.1.1, DE-UZ 205, EN 301 489-17 V3.2.0, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 300 440-1 V2.1.1, EN 301 489-1 V2.2.3
- Power Device
- Power supply - internal
- Voltage Required
- AC 100-240 V
- Frequency Required
- 50/60 Hz
- 361 Watt
- Power Consumption Stand by
- 2.3 Watt
- Power Consumption Sleep
- 1 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- ENERGY STAR Version
- 3.0
- Limited warranty - 1 year
- 15 °C
- 32.5 °C
- 10 - 80%
- Sound Emission (Idle)
- 16 dBA
- Sound Emission (Operating)
- 48 dBA
- 34.6 cm
- 18.9 cm
- 15.9 cm
- 3.8 kg
- Width (Shipping)
- 37.8 cm
- Depth (Shipping)
- 19.8 cm
- Height (Shipping)
- 22.2 cm
- Weight (Shipping)
- 4.8 kg
