HP LaserJet Enterprise P3015dn Mono Laser Printer
HP Laserjet P3015 Series
YOU BUY. YOU TRY. YOU DECIDE!
Quicklinx: 6483WS00 Mfr#: CE528A#B19
Get fast, high-performance printing with advanced security features. Expand as your business needs change, using an open EIO slot, open memory slot, two internal accessory ports for connecting HP and partner solutions and optional paper trays.
  • Count on HP for performance and durability
    Help prevent unauthorized network admission with 802.1X, which provides device authentication prior to admission.All-in-one Original HP print cartridges with built-in intelligence deliver reliable, consistently outstanding results, page after page, cartridge after cartridge. Get more out of each cartridge with the optional high capacity toner cartridge.Save time and reduce costs and your environmental impact. Print high-quality, two-sided documents and use up to 50 percent less paper using automatic, two-sided printing. This device uses up to 13 percent less energy per page than previous models.Twenty-five years of continuous innovation and reliable, professional-quality printing – HP LaserJet remains the brand businesses count on.
  • Get peace of mind with advanced security features
    Help secure business-critical data using IPSec and other advanced security features.Easily retrieve stored confidential print jobs. Retrieve a list of stored jobs using the "menu" button and enter your PIN using the 10-number key pad on the printer's control panel.Add a secure hard disk to the printer's open EIO slot. The optional HP High-Performance Secure EIO Hard Disk provides advanced security features to protect sensitive data at rest on HP printers and MFPs – without impacting device performance.
  • Gain the flexibility to expand with your business
    Improve your productivity. Get the capacity to do more with a 1600-sheet maximum input capacity. Add an optional 500-sheet paper tray for better paper handling.Meet your business needs with robust paper handling. Automatically print on different types and sizes of media – up to A6 – with easy-to-load, adjustable paper trays.
  • Easy to use and manage
    Get convenient, walk-up printing, using the front-panel Hi-Speed host USB 2.0 port. Increase your manageability with a full portfolio of innovative HP Certified Partner solutions that integrate easily into your existing infrastructure.Reduce calls to IT. Users may easily use and maintain the printer with convenient features like the four-line LCD control panel and the "Show-Me-How" menu.Easily setup and manage your print fleet with industry leading, award winning HP Web Jetadmin, and the HP Universal Print Driver. Easily install, configure, monitor, troubleshoot and manage your printing devices from anywhere on the network.Enjoy easy recycling – cartridges returned via HP Planet Partners are recycled responsibly.
HP LaserJet Enterprise P3015dn - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
15.9 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB, Gigabit LAN
540 MHz
RAM Installed (Max)
128 MB (640 MB) - DDR2 SDRAM - SO-DIMM 144-pin
Language Simulation
PCL 5E, PostScript 3, PCL 6
Media Type
Envelopes, transparencies, labels, plain paper, cards
Total Media Capacity
600 sheets
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
1500 - 5000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - integrated
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 2000 SP4, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008
Microsoft Certification
Works with Windows Vista
Environmental Standards
EPEAT Silver
1-year warranty
44.8 cm x 41.2 cm x 31.6 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD, USB Hub
Wired
USB, Gigabit LAN
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
7.5 sec
Language Simulation
540 MHz
RAM
RAM Installed (Max)
128 MB / 640 MB (max)
Technology / Form Factor
Slots Qty
1
Empty Slots
1
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm
Media Weight
60 g/m² - 199 g/m²
600 sheets
Max Media Capacity
1600 sheets
Output Trays Capacity
250 sheets
Duty Cycle
100000 pages
1500 - 5000 pages
Print server - integrated
Expansion Slots
1 x EIO
1 x USB 2.0
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
780 watt
EPEAT Compliant
EPEAT Silver
ENERGY STAR
Limited warranty - 1 year
15 °C
32.5 °C
10 - 80%
Sound Emission (Idle)
54 dBA
44.8 cm
41.2 cm
31.6 cm
15.9 kg
Width (Shipping)
60 cm
Depth (Shipping)
50 cm
Height (Shipping)
43.9 cm
Weight (Shipping)
19.9 kg
6483 HP 55A Black Original LaserJet Toner Cartridge In Stock £137.19
6483 HP 55X High Yield Black Original LaserJet Toner Cartridge In Stock £213.31
6483 HP 55X 2-pack High Yield Black Original LaserJet Toner Cartridges In Stock £421.23
