HP LaserJet Enterprise MFP M528dn
Quicklinx: GLHYWS00 Mfr#: 1PV64A#B19
Type: Printer / copier / scanner
Functionality: Scanner, Copier, Printer
Output Type: Monochrome
Wireless Capability: Wireless, Wired
Technology: Laser
20 In Stock
£1,186.12 ex VAT
£1,423.34 inc VAT
Choose an HP LaserJet Enterprise MFP designed to handle business solutions securely and efficiently, and helps conserve energy with HP EcoSmart toner black. Keep up with the demands of growing business with a printer you can rely on.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
HP LaserJet Enterprise MFP M528dn - multifunction printer - B/W
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
2000 - 7500 pages
Max Copying Speed
Up to 43 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 43 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
101.6 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, film, heavy-weight paper
Standard Media Capacity
650 sheets
Max Media Capacity
2300 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, HP EveryPage, pull-out keyboard, Mopria certified, Roam capable
AC 230 V (50/60Hz)
48.2 cm x 49.6 cm x 49.7 cm
21.41 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Printing Technology
Laser - monochrome
150000 pages
2000 - 7500 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1.75 GB
Max Supported Memory
2.75 GB
Hard Disk Drive
320 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Up to 43 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Booklet creation, collation copy, Book Copy, edge-to-edge, ID Copy
Printing
Max Printing Speed
Up to 43 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.4
Image Enhancement Technology
HP FastRes 1200, HP ProRes 1200
Automatic Duplexing
First Print Out Time B/W
6.5 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
101.6 x 148 mm
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
199 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, 127 x 177.8 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
650 sheets
Max Media Capacity
2300 sheets
100 sheets
250 sheets
ADF - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m² , Input tray - 550 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Input tray - 100 sheets - Legal (216 x 356 mm) , Output tray - 250 sheets
Speed Details
Printing: up to 43 ppm (A4) - B/W (ISO) , Printing: up to 34 ipm (A4) - B/W duplex , Printing: up to 65 ppm (A5) - B/W landscape , Printing: up to 45 ppm - B/W , Copying: up to 43 ppm (A4) - B/W normal , Copying: up to 34 ppm (A4) - B/W duplex , Scanning: up to 43 ppm (A4) - B/W normal , Scanning: up to 38 ppm (A4) - colour normal , Scanning: up to 43 ipm (A4) - B/W duplex , Scanning: up to 38 ipm (A4) - colour normal
2 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec, 802.1x
Operating System Support
MS Windows XP SP2 or later, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, MS Windows Server 2008 R2, Apple Mac OS X 10.7, MS Windows Server 2003 SP1 or later
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
629 Watt
Power Consumption Standby
28.8 Watt
Power Consumption Sleep
5.3 Watt
Consumables Included
1 x toner cartridge (black) - up to 5000 pages
UL, cUL, EN 61000-3-2, EN55022, GS, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, GB 17625.1, GB 9254 Class A
Security Slot Type
Kensington security slot
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year - on-site - response time: next business day
48.2 cm
49.6 cm
49.7 cm
21.41 kg
Shipping Width
73.5 cm
Shipping Depth
59.2 cm
Shipping Height
61.3 cm
Shipping Weight
28.6 kg
Sound Emission
26 dBA (idle) / 54 dBA (operating)
10 °C
32.5 °C
10 - 80%
Ink (4)
GLHY HP 89A Black Original LaserJet Toner Cartridge In Stock £130.91
GLHY HP 89X High Yield Black Original LaserJet Toner Cartridge In Stock £200.69
GLHY HP 89Y Extra High Yield Black Original LaserJet Toner Cartridge In Stock £263.22
GLHY HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £16.87
Other bundles (1)
GLHY HP LaserJet 550 Sheet Paper Tray In Stock £110.33
Functionality: Copier
Functionality: Printer
Wireless Capability: Wired
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
Price Range Ex VAT: £1000 - £1500
