Boost productivity with flexible send options, versatile paper-handling tools, two-sided scanning and professional finishing touches – on paper sizes up to A3. Print on the go with wireless direct printing and touch-to-print technology.
Give workgroups the speed they need
Scan two-sided documents in a single pass with super-fast scan speeds. HP EveryPage allows employees to scan without worry and detect potential errors or missed pages on the spot – even when the weight, size or condition of pages varies.Enter data more quickly and accurately, using the pull-out keyboard.Make your scanned documents easy to locate and retrieve. Create easily searchable scanned files, using built-in optical character recognition (OCR) software.Easily scan and send documents to Microsoft SharePoint in one step. -
Keep your business moving
Make it easy to be efficient: preview and edit scans, adjust images and launch standard processes, all at the 20.3 cm (8-inch) colour touchscreen.Tackle high volume printing: load the MFP with a paper capacity of up to 4,600 sheets and high-capacity Original HP cartridges, and let it go to work.Add finishing touches - give employees the tools to organise documents faster and more conveniently. Staple, stack, fold and punch holes with the MFP's built-in finishing options.Simplicity all around – make it easy for all to print with one common driver, the HP Universal Print Driver (UPD), for all HP devices. -
Protect your business – now and in the future
Expand your options: easily upgrade firmware with the latest new features and integrate tomorrow's solutions with ease.Manage centrally your printing fleet with HP Web Jetadmin and Apply fleet-wide policies to help protect all your HP devices with the HP Imaging and Printing Center.Confidently safeguard sensitive business data sent to your MFP with advanced security features and encrypted hard disk.Safeguard security keys, passwords and certificates with the optional HP Trusted Platform Module.
- HP LaserJet Enterprise Flow MFP M830z - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 300000 pages
- Recommended Monthly Volume
- 15000 - 50000 pages
- Max Printing Speed
- Up to 56 ppm
- Max Printing Resolution
- Up to 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 100 dpi
- Scanning
- 600 dpi
- Original Size
- A3/Ledger (297 x 432 mm) (max)
- Document Feeder Capacity
- 100 sheets
- Media Size
- 98 x 191 mm (min) - 312 x 470 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, card stock
- Standard Media Capacity
- 1100 sheets
- Output Trays Capacity
- 3000 sheets
- Stacker
- Optional
- Stapler
- Optional
- Binder
- Optional
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, Hard Disk Drive Encryption, save to network folder, HP EveryPage, pull-out keyboard
- Power
- AC 230 V (50/60Hz)
- 165 cm x 71.5 cm x 110 cm
- 223 kg
- Environmental Standards
- ENERGY STAR Qualified, EPEAT Silver
- 1-year warranty
- Fax Type
- Plain paper
- Laser - monochrome
- 300000 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 384 MB
- Max Supported Memory
- 512 MB
- Hard Disk Drive
- 20 GB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Copying Features
- Auto colour select, Job Build
Printing
- Up to 1200 dpi
- Up to 56 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF 1.4
- Image Enhancement Technology
- HP FastRes 1200 / HP ProRes 1200
- First Print Out Time B/W
- 9.5 sec
Scanning
- Optical Resolution
- 600 dpi
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Fax Printing Resolution
- 300 x 300 dpi
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Fax forwarding, automatic redialing, auto reduction, fax polling
Document & Media Handling
- Max Original Size
- 100 sheets
- Min Media Size
- 98 x 191 mm
- Max Media Size
- A3
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ARCH B (304.8 x 457.2 mm), JIS B5 (182 x 257 mm), 312 x 470 mm, RA3 (305 x 430 mm), 297 x 431.8 mm, 215.9 x 330.2 mm, 98 x 191 mm, JIS B6 (128 x 182 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 1100 sheets
- 3000 sheets
- ADF - 100 sheets size: A5 (148 x 210 mm) - 297 x 431.8 mm weight: 145 g/m² - 199 g/m² , Input tray - 100 sheets size: 98 x 191 mm - 312 x 470 mm weight: 60 g/m² - 220 g/m² , 2 x input tray - 500 sheets size: A5 (148 x 210 mm) - 297 x 431.8 mm weight: 60 g/m² - 199 g/m² , Output tray - 3000 sheets
- Speed Details
- Printing: up to 56 ppm (A4) - B/W , Printing: up to 55 ppm (Letter A) - B/W , Printing: up to 28 ppm (A3) - B/W , Scanning: up to 70 ppm (A4) - B/W , Scanning: up to 70 ppm (Letter A) - B/W , Scanning: up to 68 ppm (A4) - colour , Scanning: up to 68 ppm (Letter A) - colour , Scanning: up to 85 ipm (A4) - B/W duplex , Scanning: up to 85 ipm (Letter A) - B/W duplex , Scanning: up to 63 ipm (A4) - colour duplex , Scanning: up to 63 ipm (Letter A) - colour duplex
Finishing Equipment
- Stacker
- Optional
- Stapler
- Optional
- Binder
- Optional
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 4 x USB 2.0 - 4 pin USB Type A , 1 x modem - RJ-11
- SSL, Apple Bonjour, TLS, IPsec, 802.1x, AES
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, MS Windows Server 2008 R2, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2003 SP2, MS Windows Server 2012 x64 Edition
- Software Included
- Drivers & Utilities
- Voltage Required
- 1030 Watt
- Power Consumption Standby
- 60 Watt
- Power Consumption Sleep
- 6 Watt
- Included Accessories
- Keyboard, phone cable
- UL, cUL, GS, ICES-003, NOM, EN55024, CISPR 22, FCC Part 68, CCC, CS-03, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60825-1, LVD, GB 9254-2008, EN 61000-3-3:2008, GB 17625.1-2003 EMC, IEC 60825, EN 61000-3-2:2006+A1:2009+A2:2009
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site , Limited warranty - phone consulting - 1 year
- 165 cm
- 71.5 cm
- 110 cm
- 223 kg
- Shipping Weight
- 155.9 kg
- Sound Emission
- 37 dBA (idle) / 59 dBA (operating)
- 10 °C
- 32.5 °C
- 10 - 80%
