HP LaserJet Enterprise M830z Multifunction Printer
Quicklinx: 9HDYWS00 Mfr#: CF367A#B19
Functionality: Printer, Scanner, Copier, Fax
Output Type: Monochrome
Wireless Capability: Wired, Wireless
Technology: Laser
£7,017.43 ex VAT
£8,420.91 inc VAT
Boost productivity with flexible send options, versatile paper-handling tools, two-sided scanning and professional finishing touches – on paper sizes up to A3. Print on the go with wireless direct printing and touch-to-print technology.
  • Unleash your printing
    Print wirelessly from your mobile device without a Wi-Fi code or password.
  • Scan to email
    Save time by sending scanned documents or photos directly from your printer to email recipients.
HP LaserJet Enterprise Flow MFP M830z - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
300000 pages
Recommended Monthly Volume
15000 - 50000 pages
Max Copying Speed
Up to 56 ppm
Max Printing Speed
Up to 56 ppm
Max Printing Resolution
Up to 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 100 dpi
Scanning
600 dpi
Original Size
A3/Ledger (297 x 432 mm) (max)
Document Feeder Capacity
100 sheets
Media Size
98 x 191 mm (min) - 312 x 470 mm (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, card stock
Standard Media Capacity
1100 sheets
Output Trays Capacity
3000 sheets
Stacker
Optional
Stapler
Optional
Binder
Optional
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, Hard Disk Drive Encryption, save to network folder, HP EveryPage, pull-out keyboard
AC 230 V (50/60Hz)
165 cm x 71.5 cm x 110 cm
223 kg
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
300000 pages
15000 - 50000 pages
Display Features
Touch screen
AirPrint Enabled
Standard Memory
384 MB
Max Supported Memory
512 MB
Hard Disk Drive
20 GB
Copying
Max Copying Speed
Up to 56 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Copying Features
Auto colour select, Job Build
Printing
Up to 1200 dpi
Max Printing Speed
Up to 56 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF 1.4
Image Enhancement Technology
HP FastRes 1200 / HP ProRes 1200
Automatic Duplexing
First Print Out Time B/W
9.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 dpi
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Printing Resolution
300 x 300 dpi
Fax Machine Features
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Fax forwarding, automatic redialing, auto reduction, fax polling
Document & Media Handling
Max Original Size
100 sheets
Min Media Size
98 x 191 mm
Max Media Size
A3
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ARCH B (304.8 x 457.2 mm), JIS B5 (182 x 257 mm), 312 x 470 mm, RA3 (305 x 430 mm), 297 x 431.8 mm, 215.9 x 330.2 mm, 98 x 191 mm, JIS B6 (128 x 182 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
1100 sheets
3000 sheets
ADF - 100 sheets size: A5 (148 x 210 mm) - 297 x 431.8 mm weight: 145 g/m² - 199 g/m² , Input tray - 100 sheets size: 98 x 191 mm - 312 x 470 mm weight: 60 g/m² - 220 g/m² , 2 x input tray - 500 sheets size: A5 (148 x 210 mm) - 297 x 431.8 mm weight: 60 g/m² - 199 g/m² , Output tray - 3000 sheets
Speed Details
Scanning: up to 70 ppm (A4) - B/W , Scanning: up to 70 ppm (Letter A) - B/W , Scanning: up to 68 ppm (A4) - colour , Scanning: up to 68 ppm (Letter A) - colour , Scanning: up to 85 ipm (A4) - B/W duplex , Scanning: up to 85 ipm (Letter A) - B/W duplex , Scanning: up to 63 ipm (A4) - colour duplex , Scanning: up to 63 ipm (Letter A) - colour duplex , Printing: up to 56 ppm (A4) - B/W (ISO) , Printing: up to 28 ppm (Tabloid) - B/W normal , Printing: up to 28 ppm (A3) - B/W normal , Printing: up to 55 ppm (Letter A) - B/W (ISO) , Copying: up to 56 ppm (A4) - B/W (ISO) , Copying: up to 55 ppm (Letter A) - B/W (ISO)
Finishing Equipment
Stacker
Optional
Stapler
Optional
Binder
Optional
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 4 x USB 2.0 - 4 pin USB Type A , 1 x modem - RJ-11
Security Protocols & Features
SSL, Apple Bonjour, TLS, IPsec, 802.1x, AES
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, MS Windows Server 2008 R2, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2003 SP2, MS Windows Server 2012 x64 Edition
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
1030 watt
Power Consumption Standby
60 watt
Power Consumption Sleep
6 watt
Keyboard, phone cable
UL, cUL, GS, ICES-003, NOM, EN55024, CISPR 22, FCC Part 68, CCC, CS-03, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60825-1, LVD, GB 9254-2008, EN 61000-3-3:2008, GB 17625.1-2003 EMC, IEC 60825, EN 61000-3-2:2006+A1:2009+A2:2009
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 1 year - on-site , Limited warranty - phone consulting - 1 year
165 cm
71.5 cm
110 cm
223 kg
Shipping Weight
155.9 kg
Sound Emission
37 dBA (idle) / 59 dBA (operating)
10 °C
32.5 °C
10 - 80%
9HDY HP 2000 STAPLER CARTRIDGE-TWIN PACK In Stock £14.61
9HDY HP LaserJet ADF Roller Replacement Kit In Stock £68.43
9HDY HP LaserJet 220V Maintenance/Fuser Kit In Stock £562.67
9HDY HP 25X High Yield Black Original LaserJet Toner Cartridge In Stock £272.34
9HDY HP 828A Yellow LaserJet Image Drum In Stock £240.47
9HDY HP 828A Black LaserJet Image Drum In Stock £87.16
9HDY HP 828A Cyan LaserJet Image Drum In Stock £240.47
9HDY HP 828A Magenta LaserJet Image Drum In Stock £240.47
9HDY HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £16.68
Functionality: Scanner
Functionality: Copier
Functionality: Fax
Wireless Capability: Wireless
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: 312 x 470 mm
Brand: HP
Price Range Ex VAT: £1500+
