Boost productivity with flexible send options, versatile paper-handling tools, two-sided scanning and professional finishing touches – on paper sizes up to A3. Print on the go with wireless direct printing and touch-to-print technology.
Unleash your printing
Print wirelessly from your mobile device without a Wi-Fi code or password. -
Scan to email
Save time by sending scanned documents or photos directly from your printer to email recipients.
- HP LaserJet Enterprise Flow MFP M830z - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 300000 pages
- Recommended Monthly Volume
- 15000 - 50000 pages
- Max Copying Speed
- Up to 56 ppm
- Max Printing Speed
- Up to 56 ppm
- Max Printing Resolution
- Up to 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 100 dpi
- Scanning
- 600 dpi
- Original Size
- A3/Ledger (297 x 432 mm) (max)
- Document Feeder Capacity
- 100 sheets
- Media Size
- 98 x 191 mm (min) - 312 x 470 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, card stock
- Standard Media Capacity
- 1100 sheets
- Output Trays Capacity
- 3000 sheets
- Stacker
- Optional
- Stapler
- Optional
- Binder
- Optional
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, Hard Disk Drive Encryption, save to network folder, HP EveryPage, pull-out keyboard
- Power
- AC 230 V (50/60Hz)
- 165 cm x 71.5 cm x 110 cm
- 223 kg
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Laser - monochrome
- 300000 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 384 MB
- Max Supported Memory
- 512 MB
- Hard Disk Drive
- 20 GB
Copying
- Max Copying Speed
- Up to 56 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Copying Features
- Auto colour select, Job Build
Printing
- Up to 1200 dpi
- Up to 56 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF 1.4
- Image Enhancement Technology
- HP FastRes 1200 / HP ProRes 1200
- First Print Out Time B/W
- 9.5 sec
Scanning
- Optical Resolution
- 600 dpi
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Fax Printing Resolution
- 300 x 300 dpi
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Fax forwarding, automatic redialing, auto reduction, fax polling
Document & Media Handling
- Max Original Size
- 100 sheets
- Min Media Size
- 98 x 191 mm
- Max Media Size
- A3
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ARCH B (304.8 x 457.2 mm), JIS B5 (182 x 257 mm), 312 x 470 mm, RA3 (305 x 430 mm), 297 x 431.8 mm, 215.9 x 330.2 mm, 98 x 191 mm, JIS B6 (128 x 182 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 1100 sheets
- 3000 sheets
- ADF - 100 sheets size: A5 (148 x 210 mm) - 297 x 431.8 mm weight: 145 g/m² - 199 g/m² , Input tray - 100 sheets size: 98 x 191 mm - 312 x 470 mm weight: 60 g/m² - 220 g/m² , 2 x input tray - 500 sheets size: A5 (148 x 210 mm) - 297 x 431.8 mm weight: 60 g/m² - 199 g/m² , Output tray - 3000 sheets
- Speed Details
- Scanning: up to 70 ppm (A4) - B/W , Scanning: up to 70 ppm (Letter A) - B/W , Scanning: up to 68 ppm (A4) - colour , Scanning: up to 68 ppm (Letter A) - colour , Scanning: up to 85 ipm (A4) - B/W duplex , Scanning: up to 85 ipm (Letter A) - B/W duplex , Scanning: up to 63 ipm (A4) - colour duplex , Scanning: up to 63 ipm (Letter A) - colour duplex , Printing: up to 56 ppm (A4) - B/W (ISO) , Printing: up to 28 ppm (Tabloid) - B/W normal , Printing: up to 28 ppm (A3) - B/W normal , Printing: up to 55 ppm (Letter A) - B/W (ISO) , Copying: up to 56 ppm (A4) - B/W (ISO) , Copying: up to 55 ppm (Letter A) - B/W (ISO)
Finishing Equipment
- Stacker
- Optional
- Stapler
- Optional
- Binder
- Optional
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 4 x USB 2.0 - 4 pin USB Type A , 1 x modem - RJ-11
- SSL, Apple Bonjour, TLS, IPsec, 802.1x, AES
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, MS Windows Server 2008 R2, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2003 SP2, MS Windows Server 2012 x64 Edition
- Software Included
- Drivers & Utilities
- Voltage Required
- 1030 watt
- Power Consumption Standby
- 60 watt
- Power Consumption Sleep
- 6 watt
- Included Accessories
- Keyboard, phone cable
- UL, cUL, GS, ICES-003, NOM, EN55024, CISPR 22, FCC Part 68, CCC, CS-03, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60825-1, LVD, GB 9254-2008, EN 61000-3-3:2008, GB 17625.1-2003 EMC, IEC 60825, EN 61000-3-2:2006+A1:2009+A2:2009
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site , Limited warranty - phone consulting - 1 year
- 165 cm
- 71.5 cm
- 110 cm
- 223 kg
- Shipping Weight
- 155.9 kg
- Sound Emission
- 37 dBA (idle) / 59 dBA (operating)
- 10 °C
- 32.5 °C
- 10 - 80%
HP 2000 STAPLER CARTRIDGE-TWIN PACK | In Stock | £14.61 |
HP LaserJet ADF Roller Replacement Kit | In Stock | £68.49 |
HP LaserJet 220V Maintenance/Fuser Kit | In Stock | £563.14 |
HP 25X High Yield Black Original LaserJet Toner Cartridge | In Stock | £272.84 |
HP 828A Yellow LaserJet Image Drum | In Stock | £240.68 |
HP 828A Black LaserJet Image Drum | In Stock | £86.99 |
HP 828A Cyan LaserJet Image Drum | In Stock | £240.68 |
HP 828A Magenta LaserJet Image Drum | In Stock | £240.68 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £16.69 |
