This HP Colour LaserJet MFP with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network with the industry's deepest security.
The world's most secure printing
With HP Sure Start, each printer regularly checks its operating code and repairs itself from attempted hacks.Run-time intrusion detection continually monitors to detect and stop attacks, then automatically reboots.Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency.Give workgroups what they need to succeed. Easily choose and deploy over 180 HP and third-party solutions. -
High speed performance meets energy efficiency
Scanning is now faster than ever; duplex scan speeds up to 111 ipm. Scan to SharePoint and more.This MFP wakes up fast and prints your first page faster – in as quickly as 9 seconds (M681dh and M681f).This MFP uses exceptionally low amounts of energy thanks to its innovative design and toner technology.Paper handling options include a wheeled stand and 550-sheet input feeder for paper sizes 10.16 x 15.24 cm (4 x 6") to legal. -
More
ColorSphere3 toner formulation, combined with an automatic media sensor, help provide leading print quality.Original HP Toner cartridges with JetIntelligence supply 39% more pages per colour cartridge vs predecessor.Help retain the Original HP quality you paid for with anti-fraud and cartridge authentication technology.Spend less time replacing toner, and more on business. Choose high-yield toner cartridges.
- HP Color LaserJet Enterprise MFP M681dh - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 2000 - 14000 pages
- Max Copying Speed
- Up to 47 ppm (mono) / up to 47 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 8"
- Original Size
- 216 x 863 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 150 sheets
- Media Size
- 76 x 127 mm (min) - 216 x 863 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, film, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, glossy paper, punched paper, preprinted paper
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 3200 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, automatic paper sensor, HP High-Performance Secure Hard Disk, Instant-on Technology, scan to SharePoint, HP Auto-On/Auto-Off Technology
- Power
- AC 230 V (50Hz)
- 51 cm x 55.5 cm x 65.8 cm
- 42.3 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Laser - colour
- 100000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Max Supported Memory
- 2.5 GB
- Hard Disk Drive
- 320 GB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- ID Card Copy, Manual Color Adjustment, collation copy, Job Build, Edge Erase, blank page skipping, Book Copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.7, URF
- Image Enhancement Technology
- HP ProRes 1200, HP ImageREt 3600, Pantone Calibrated
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 9 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 863 mm
- Original Type
- Sheets
- 150 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 45 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, 216 x 863 mm, 99 x 148 mm, Oficio (216 x 343 mm), 216 x 356 mm, JIS B6 (128 x 182 mm), DL (210 x 99 mm), RA4 (215 x 305 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 650 sheets
- 3200 sheets
- 100 sheets
- 500 sheets
- ADF - 150 sheets size: 68 x 147 mm - 216 x 863 mm weight: 45 g/m² - 199 g/m² , Input tray - 500 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Bypass tray - 100 sheets size: 101.6 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 500 sheets
- Speed Details
- Printing: up to 74 ppm (A5) - B/W , Printing: up to 47 ppm (A4) - B/W normal , Printing: up to 74 ppm (A5) - colour normal , Printing: up to 47 ppm (A4) - colour normal , Printing: up to 47 ppm (A4) - B/W duplex , Printing: up to 47 ppm (A4) - colour duplex , Copying: up to 47 ppm (A4) - B/W normal , Copying: up to 47 ppm (A4) - colour normal , Copying: up to 47 ppm (A4) - B/W duplex , Copying: up to 50 ppm (Letter A) - colour normal , Copying: up to 47 ppm (A4) - colour duplex , Scanning: up to 69 ppm (A4) - B/W normal , Scanning: up to 69 ppm (A4) - colour normal , Scanning: up to 111 ipm (A4) - B/W normal , Scanning: up to 111 ipm (A4) - colour normal
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Operating System Support
- UNIX, Novell NetWare 6.5, MS Windows Server 2008 R2, Red Hat Enterprise Linux 6, Ubuntu Linux 12.04, MS Windows Server 2012, Novell Open Enterprise Server, Android, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 SP2 (32/64-bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Boss 5.0, Debian Linux 7.x, Linux Mint 17, Ubuntu Linux 14.04, Red Hat Enterprise Linux 7, Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition, Novell NetWare 6.5 SP8, Novell Open Enterprise Server 11 SP1, Novell Open Enterprise Server 2, Debian Linux 8.0, Novell Open Enterprise Server 11, macOS 10.12, Linux Mint 17.1, Linux Mint 17.2, Linux Mint 18, Linux Mint 17.3, SuSe Linux 13.2, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10, Debian Linux 8.1, Debian Linux 8.2, Debian Linux 8.3, Debian Linux 8.4, Debian Linux 8.5, Debian Linux 8.6, Fedora Linux 22, Fedora Linux 23, Fedora Linux 24
- Software Included
- Drivers & Utilities, HP Web Jetadmin, HP Device Experience (DXP), HP Connected
- Voltage Required
- AC 230 V (50Hz)
- 900 watt
- Power Consumption Sleep
- 0.9 watt
- First Copy Out Time B/W
- 6.5 sec
- First Copy Out Time Colour
- 7.2 sec
- UL, cUL, GS, EMC, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 62479:2010, EMC 2004/108/EC, LVD 2006/95/EC, 21 CFR 1040.10, 21 CFR 1040.11, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008, EN 60950-1:2006+A1:2010+A2:2013+A11:2009+A12:2011, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60825-1:2007, R&TTE Directive 1999/5/EC, IEC 60825-1:2007 Class 1
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year - on-site - response time: next business day
- 51 cm
- 55.5 cm
- 65.8 cm
- 42.3 kg
- Shipping Width
- 71.4 cm
- Shipping Depth
- 67.7 cm
- Shipping Height
- 81.6 cm
- Shipping Weight
- 49.5 kg
- Sound Emission
- 32 dBA (idle) / 58 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
Ink (3)
HP Laserjet Toner Collection Unit | In Stock | £29.18 |
HP 657X High Yield Magenta Original LaserJet Toner Cartridge | In Stock | £352.23 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £16.72 |
Other bundles (3)
HP Colour LaserJet CE247A 220V Fuser Kit | In Stock | £233.65 |
HP Foreign Interface Harness (FIH) | In Stock | £77.76 |
HP 655A Black Original LaserJet Toner Cartridge | In Stock | £194.68 |
