Performance you can count on: high-volume, professional-quality, two-sided colour documents with outstanding reliability. Efficient one-touch printing and mobile printing options plus simple management help you be productive wherever work takes you.
Invest in reliable printing performance
Get results you can depend on, with a printer designed for quiet performance and minimal intervention.Stay on firm ground – maintain printing productivity thanks to reliable, upgradable firmware.Print your best – equip every department with vibrant, consistent, professional-quality colour printing. -
Keep your business moving from virtually anywhere
Print without wires or a network. Get easy access to the printer through optional wireless direct printing.Mobile printing at a touch with Near Field Communications (NFC): enable touch-to-print convenience from mobile devices.Easily print from smartphone, tablets, and notebooks at work, home, or on the go; Mopria-certified.Print from virtually anywhere with Apple AirPrint . Print from your mobile device with built-in print capability or the HP ePrint app and software. -
Be ready for the future
Keep up with the times: easily update this printer as solutions advance, with HP FutureSmart Firmware.Depend on a printer that can expand with your business, with easy and feature upgrades.Monitor and control your printers, no matter where you are, with HP Web Jetadmin.Help protect sensitive business data with advanced security solutions and an encrypted hard disk. -
Achieve high-volume productivity
Get exceptional value from Original HP high-capacity toner cartridges.Easy control at your fingertips: select settings using the 11 cm (4.3-inch) colour touchscreen.Meet the demands of high-volume print jobs – this printer has a paper input capacity of up to 3,100 sheets.
- HP Color LaserJet Enterprise M651n - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 39.1 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 42 ppm - black normal - A4 (210 x 297 mm) , Up to 42 ppm - colour normal - A4 (210 x 297 mm) , Up to 45 ppm - black normal - ANSI A (Letter) (216 x 279 mm) , Up to 45 ppm - colour normal - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Image Enhancement Technology
- HP ImageREt 4800 / HP ProRes 1200
- Interface
- USB 2.0, Gigabit LAN, USB host
- Processor
- 800 MHz
- RAM Installed (Max)
- 1.5 GB (1.5 GB)
- Language Simulation
- PCL 5, PostScript 3, PCL 6, PDF, URF
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy-weight paper, heavy-weight glossy paper, bond paper, recycled paper, opaque film, card stock, extra heavy-weight paper, light-weight paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Monthly Duty Cycle (max)
- 120000 pages
- Recommended Monthly Volume
- 2500 - 17000 pages
- Networking
- Print server
- Printer Features
- On paper calibration technology
- System Requirements
- HP-UX 10.20, SunSoft Solaris 2.5 or later, IBM AIX 3.2.5 or later, Microsoft Windows 2000, HP-UX 11.x, HP MPE/iX, HP-UX 11i, Novell NetWare 5.1 or later, Microsoft Windows Server 2003 x64 Edition SP2 or later, Apple MacOS X 10.6, Microsoft Windows XP SP3 or later, Microsoft Windows Server 2003 SP2 or later, Citrix MetaFrame, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows XP Professional x64 Edition SP3 or later, Apple MacOS X Lion 10.7, Microsoft Windows 7 (32/64 bits) SP1 or later, Red Hat Linux 7.x or later, SuSE Linux 8.x or later, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Apple OS X 10.9 Mavericks
- 55 cm x 52 cm x 45.5 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- 4.3 inch LCD touch screen
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 9 sec
- Fonts Included
- 105 x TrueType , 92 x scalable PostScript
- Printer Features
- Media Handling
- Processor
- 800 MHz
RAM
- 1.5 GB / 1.5 GB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Max Media Capacity
- 3100 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 120000 pages
- Networking
- Print server
- Network Controller Name
- HP Jetdirect
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDPS, NDS, HTTPS, TFTP, IPPS
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- FCC Class A certified, UL, CISPR 22 Class A, cUL, GS, ICES-003, EN55022 Class A, EMC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60825-1, LVD, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 62479, IEC 60825-1:2007, EN 62479:2010, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- Security Slot Type
- Kensington security slot
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 650 Watt
- Power Consumption Stand by
- 67 Watt
- Power Consumption Sleep
- 8.5 Watt
- Software Included
- Drivers & Utilities, HP Web JetAdmin
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- 10 °C
- 30 °C
- 10 - 80%
- Sound Emission (Idle)
- 34 dBA
- Sound Emission (Operating)
- 55 dBA
- 55 cm
- 52 cm
- 45.5 cm
- 39.1 kg
- Width (Shipping)
- 75 cm
- Depth (Shipping)
- 67.8 cm
- Height (Shipping)
- 59.7 cm
- Weight (Shipping)
- 44.6 kg
HP 652A Black Original LaserJet Toner Cartridge | In Stock | £182.07 |
HP 654A Cyan Original LaserJet Toner Cartridge | In Stock | £333.69 |
HP 654A Magenta Original LaserJet Toner Cartridge | In Stock | £333.69 |
HP 654A Yellow Original LaserJet Toner Cartridge | In Stock | £333.69 |
HP 654X High Yield Black Original LaserJet Toner Cartridge | In Stock | £239.27 |
