Product
HP LaserJet Enterprise M630f Mono Laser Multifunction Printer
Quicklinx: B290WS00 Mfr#: B3G85A#B19
Rely on a full-featured HP Enterprise MFP that accelerates productivity and streamlines digital workflow, safeguards business data and documents with a robust suite of top-flight security features and offers simple, efficient mobile printing.
  • Get powerful performance to enhance workflow
    Finish faster – without missing a page – using single-pass, dual-head scanning and the automatic document feeder.Preview and edit scans, adjust images, and launch standard processes, all at the 20.3 cm colour touchscreen.Keep productivity high – choose a robust MFP that can print up to 28,000 pages per month at a speed of 57 ppm (A4).Tackle high volume printing with a paper capacity of up to 3,100 sheets, high yield toner cartridge, automatic job sorting and finishing, using the 3-bin stapling mailbox.
  • Protect your business – now and in the future
    Safeguard and manage centrally your printing fleet with the HP Imaging and Printing Security Center and HP Web Jetadmin.Confidently safeguard the sensitive data sent to your MFP with the encrypted hard drive.Secure your investment – depend on an MFP that can expand with your business, whenever solutions advance.Safeguard security keys, passwords and certificates with the optional HP Trusted Platform Module.
  • Enjoy easy and secure mobile printing
    Enjoy mobile printing at a touch: enable optional touch-to-print and touch-to-authenticate convenience from mobile devices.Enable secure peer-to-peer direct-access mobile printing without connecting to the corporate network.Easily print from a variety of smartphones and tablets – generally no setup or apps required.Pull print jobs from your pocket – walk up and print or scan from your USB drive.
HP LaserJet Enterprise MFP M630f - multifunction printer - B/W
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
250000 pages
Recommended Monthly Volume
5000 - 28000 pages
Max Copying Speed
Up to 57 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 57 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 100 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
68 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper
Standard Media Capacity
1100 sheets
Max Media Capacity
1100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to folder
AC 230 V (50Hz)
73.7 cm x 64.3 cm x 111 cm
73.5 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Printing Technology
Laser - monochrome
250000 pages
5000 - 28000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1.5 GB
Max Supported Memory
2 GB
Hard Disk Drive
320 GB
Copying
Max Copying Speed
Up to 57 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Printing
Max Printing Speed
Up to 57 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF 1.7, PCL 5
Image Enhancement Technology
HP FastRes 1200, HP ProRes 1200
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
PC Faxing
Fax Machine Features
Speed Dialing
100 station(s)
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, poll receive
Document & Media Handling
Min Original Size
68 x 148 mm
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, Oficio (216 x 343 mm), 216 x 356 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
1100 sheets
Max Media Capacity
1100 sheets
100 sheets
500 sheets
ADF - 100 sheets size: 68 x 148 mm - Legal (216 x 356 mm) , 2 x input tray - 500 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m²
Speed Details
Printing: up to 57 ppm (A4) - B/W , Copying: up to 57 ppm (A4) - B/W , Scanning: up to 60 ppm - B/W , Scanning: up to 45 ppm - colour , Scanning: up to 60 ppm - B/W duplex , Scanning: up to 44 ppm - colour duplex , Printing: up to 39 ppm (A4) - B/W duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A , 1 x modem - RJ-11
Security Protocols & Features
SSL, TLS, IPsec, EAP-TLS, PEAP
Operating System Support
Sun Solaris 8, Sun Solaris 9, MS Windows 7, MS Windows XP SP3, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows XP 64-bit Edition SP3 or later, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, Linux 9.4, Linux 9.5, Ubuntu Linux 8.04.1, Ubuntu Linux 8.04.2
Software Included
Drivers & Utilities, HP Web Jetadmin
AC 230 V (50Hz)
970 Watt
Power Consumption Sleep
6.5 Watt
Phone cable
EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, CISPR 22, EMC
ENERGY STAR Certified
Limited warranty - 1 year - on-site
73.7 cm
64.3 cm
111 cm
73.5 kg
Shipping Width
85.6 cm
Shipping Depth
76 cm
Shipping Height
147.4 cm
Shipping Weight
93.58 kg
Sound Emission
58 dBA (operating)
15 °C
32.5 °C
10 - 80%
B290 HP 81A Black Original LaserJet Toner Cartridge In Stock £131.43
B290 HP 81X High Yield Black Original LaserJet Toner Cartridge In Stock £214.04
