HP LaserJet Enterprise M608dn
Quicklinx: DC6LWS00 Mfr#: K0Q18A#B19
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: Legal (216 x 356 mm), RA4 (215 x 305 mm)
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£624.88 ex VAT
£749.85 inc VAT
This HP LaserJet Printer with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network from attacks with the industry's deepest security.
  • The world's most secure printing
    With HP Sure Start, each printer regularly checks its operating code and repairs itself from attempted hacks.Whitelisting checks firmware during startup to help ensure it's authentic, good code – digitally signed by HP.Run-time intrusion detection continually monitors activity to detect and stop attacks, then automatically reboots.Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency.
  • High-speed performance meets energy efficiency
    Speed through tasks and save paper. Print two-sided documents nearly as fast as single-sided.This printer wakes up fast and prints your first page faster – in as quickly as 7.9 seconds.This printer uses exceptionally low amounts of energy thanks to its innovative design and toner technology.
  • More
    Produce sharp text, bold blacks, and crisp graphics with precision black toner.Original HP Toner cartridges with JetIntelligence deliver more pages per cartridge than predecessors.Help retain the Original HP quality you paid for with anti-fraud and cartridge authentication technology.Spend less time replacing toner, and more on business. Choose high-yield toner cartridges.
HP LaserJet Enterprise M608dn - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
21.6 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 61 ppm - B/W - A4 (210 x 297 mm) , Up to 65 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 50 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 53 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Image Enhancement Technology
HP FastRes 1200
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Preview Screen Size
2.7"
1.2 GHz
RAM Installed (Max)
512 MB (1.5 GB) - DDR3 SDRAM - DIMM 90-pin
Language Simulation
PCL 5, PostScript 3, PCL 6, PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, light-weight paper, punched paper, preprinted paper
Total Media Capacity
650 sheets
Media Handling
100-sheet multipurpose tray, 550-sheet input tray
Monthly Duty Cycle (max)
275000 pages
Recommended Monthly Volume
5000 - 25000 pages
Print server
Printer Features
Hardware integration pocket, Instant-on Technology, Auto Power On, Auto Power Off, JetIntelligence Cartridge Technology
AC 230V
UNIX, Microsoft Windows Vista (32-bit versions), Android, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Ubuntu Linux 12.04, Red Hat Enterprise Linux 7, Apple OS X 10.10 Yosemite, Windows 10 (32/64 bits), Linux Mint 17, BOSS GNU/Linux 5.0, Debian Linux 7.x, Ubuntu Linux 14.04, Apple OS X 10.11 El Capitan, Debian Linux 8.x, Linux Mint 17.1, Linux Fedora, Apple macOS Sierra 10.12 or later, Linux Mint 17.2, Linux Mint 17.3, SUSE Linux 13.2, Linux Mint 18, SUSE Linux 42.1, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10
1-year warranty
43.1 cm x 46.6 cm x 38 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
2.7 inch QVGA LCD display
Preview Screen Size
2.7"
Wired
AirPrint Enabled
1200 x 1200 dpi
HP FastRes 1200
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
7.9 sec
Language Simulation
Fonts Included
105 x TrueType , 92 x PostScript 3
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
512 MB / 1.5 GB (max)
Technology / Form Factor
Slots Qty
1
Empty Slots
0
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, 215.9 x 330.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
Media Weight
60 g/m² - 199 g/m²
650 sheets
Media Feeders
Input tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m² , Input tray: 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m²
Max Media Capacity
4400 sheets
Output Trays Capacity
500 sheets
Duty Cycle
275000 pages
5000 - 25000 pages
Print server
Network Controller Name
HP Jetdirect
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, IPP 2.0, SLP
Security Protocols & Features
Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
FCC Class A certified, UL, cUL, GS, FCC CFR47 Part 15, Directive 2006/95/EC, EN 62479:2010, 21 CFR 1040.10, 21 CFR 1040.11, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60825-1:2007, IEC 60825-1:2007 Class 1
Security Slot Type
Kensington security slot
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
780 Watt
Power Consumption Stand by
15.3 Watt
Power Consumption Sleep
3.1 Watt
Environmental Standards
Blue Angel
ENERGY STAR
Limited warranty - 1 year - on-site - response time: next business day
15 °C
32.5 °C
10 - 90%
Sound Emission (Operating)
55 dBA
43.1 cm
46.6 cm
38 cm
21.6 kg
Width (Shipping)
59.7 cm
Depth (Shipping)
53.9 cm
Height (Shipping)
49.7 cm
Weight (Shipping)
27.2 kg
Ink (3)
DC6L HP 37X - High Yield Black Laserjet Toner Cartridge In Stock £226.92
DC6L HP 37A Black Original Laserjet Toner In Stock £137.84
DC6L HP 37Y Extra High Yield Black Original LaserJet Toner Cartridge In Stock £292.31
Other bundles (1)
DC6L HP Media Tray / Feeder 550 sheets For LaserJet In Stock £220.69
Type: Printer
Max Paper Size: RA4 (215 x 305 mm)
Brand: HP
Price Range Ex VAT: £500 - £750
