Accelerate processes and turn documents into dynamic digital files, using a desktop MFP that produces standout colour. Versatile scanning, processing, routing, and retrieval tools help boost productivity. Simplify management and strengthen security.
20.3 cm color touchscreen (printer)
Manage jobs directly at the MFP, using the HP color touchscreen.
- HP LaserJet Enterprise Flow MFP M575c - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 75000 impressions
- Recommended Monthly Volume
- 2000 - 6000 pages
- Max Copying Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 204 x 98 dpi, 204 x 196 dpi
- Scanning
- 600 x 600 dpi
- Display
- 8"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, film, heavy-weight paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Collator
- Included
- Stapler
- Included
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Document send function, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, HP EveryPage, pull-out keyboard
- Power
- AC 230 V (50Hz)
- 66.3 cm x 55.5 cm x 58.5 cm
- 47.7 kg
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - colour
- 75000 impressions
- 2000 - 6000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1536 MB 1.5 GB
- Max Supported Memory
- 1536 MB 1.5 GB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- Auto colour select
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.4
- Image Enhancement Technology
- HP ImageREt 3600
- First Print Out Time B/W
- 10.5 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Scan Element
- CIS / CCD
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Fax Printing Resolution
- 400 x 400 dpi
- PC Faxing
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, fax polling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 350 sheets
- 850 sheets
- 100 sheets
- 250 sheets
- ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets size: A5 (148 x 210 mm) - Letter A (216 x 279 mm) weight: 60 g/m² - 220 g/m² , Input tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 30 ppm (A4) - B/W normal , Copying: up to 30 ppm (A4) - B/W normal , Printing: up to 30 ppm (A4) - colour normal , Copying: up to 30 ppm (A4) - colour normal , Scanning: up to 30 ppm - B/W , Scanning: up to 30 ppm - colour
Finishing Equipment
- Collator
- Included
- Stapler
- Included
- 1 x USB 2.0 , 2 x USB host , 1 x Gigabit LAN
- SSL, TLS, IPsec, 802.1x
- Operating System Support
- MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, Apple Mac OS X 10.5, MS Windows 7, MS Windows Server 2008, Apple Mac OS X 10.6, MS Windows Server 2008 R2, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later
- Software Included
- HP Web Jetadmin
- Voltage Required
- AC 230 V (50Hz)
- 665 Watt
- Power Consumption Standby
- 52 Watt
- Power Consumption Sleep
- 11.3 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 5500 pages , 1 x toner cartridge (cyan) - up to 6000 pages , 1 x toner cartridge (magenta) - up to 6000 pages , 1 x toner cartridge (yellow) - up to 6000 pages
- FCC Class A certified, UL, CISPR 22 Class A, cUL, EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, GB 17625.1, LVD, GB 9254-2008
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 66.3 cm
- 55.5 cm
- 58.5 cm
- 47.7 kg
- Shipping Width
- 75 cm
- Shipping Depth
- 64 cm
- Shipping Height
- 72.5 cm
- Shipping Weight
- 53 kg
- Sound Emission
- 54 dBA (operating)
- 10 °C
- 30 °C
- 10 - 70%
HP 507A Black Original LaserJet Toner Cartridge | In Stock | £131.31 |
HP 507A Cyan Original LaserJet Toner Cartridge | In Stock | £195.61 |
HP 507A Yellow Original LaserJet Toner Cartridge | In Stock | £195.61 |
HP 507A Magenta Original LaserJet Toner Cartridge | In Stock | £200.34 |
HP 507X High Yield Black Original LaserJet Toner Cartridge | In Stock | £176.66 |
