Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
- HP LaserJet Enterprise M554dn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- Number of Users
- 5-15 users
- 27.5 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 33 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 33 ipm - duplex - A4 (210 x 297 mm) , Up to 35 ipm - duplex - ANSI A (Letter) (216 x 279 mm) , Up to 33 ppm - colour - A4 (210 x 297 mm) , Up to 35 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 4.6 ppm - black portrait - A5 (148 x 210 mm) , Up to 4.6 ppm - colour - A5 (148 x 210 mm) , Up to 55 ppm - black landscape - A5 (148 x 210 mm) , Up to 55 ppm - colour - A5 (148 x 210 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Image Enhancement Technology
- HP ImageREt 3600
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Preview Screen Size
- 2.7"
- Processor
- 1.2 GHz
- RAM Installed (Max)
- (1 GB)
- Flash Memory Installed (Max)
- 4 GB
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF 1.7
- Media Type
- Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, opaque film, paper, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper
- Total Media Capacity
- 650 sheets
- Media Handling
- 100-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 2000 - 8500 pages
- Networking
- Print server
- Printer Features
- Hardware integration pocket, PANTONE calibrated, Instant-on Technology, Mopria certified, Auto Power On, Auto Power Off
- System Requirements
- UNIX, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Apple MacOS X Lion 10.7, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), openSUSE 12.2, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Microsoft Windows RT 8.1, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Microsoft Windows RT 8, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 45.8 cm x 47.9 cm x 40 cm
- Printer Type
- Number of Users
- 5-15 users
- Localisation
Printer
- Print Speed
- Built-in Devices
- 2.7 inch QVGA LCD display, 24-key pad
- 2.7"
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- HP ImageREt 3600
- PostScript Support
- Standard
- First Print Out Time B/W
- 6 sec
- First Print Out Time Colour
- 7 sec
- Fonts Included
- 105 x TrueType , 92 x PostScript 3
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 1 GB (max)
Flash Memory
- Flash Memory
- 4 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), 102 x 148 mm, RA4 (215 x 305 mm)
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 650 sheets
- Media Feeders
- Bypass tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray: 1 x automatic - 550 sheets - 216 x 297 mm weight: 60 g/m² - 220 g/m² , Output tray: automatic - 250 sheets
- Max Media Capacity
- 1200 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 80000 pages
- 2000 - 8500 pages
- Networking
- Print server
- Network Controller Name
- HP Jetdirect
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDS, HTTPS, TFTP, IPPS, SLP
- Kerberos, LDAP, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 5500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 3500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 3500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 3500 pages ISO/IEC 19798 , 1 x waste toner collector
- FCC Class A certified, CISPR 22 Class A, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 62479:2010, EN 55022:2010 Class A, ICES-003 issue 5 Class A, IEC 62479:2010, EN 60825-1:2007, FCC CFR47 Part 15 A
- Power Device
- Power supply - internal
- 589 watt
- Power Consumption Stand by
- 28.5 watt
- Power Consumption Sleep
- 2.17 watt
- Software Included
- Drivers & Utilities
- OS Required
- EPEAT Compliant
- EPEAT Silver
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year - on-site - response time: next business day
- 15 °C
- 30 °C
- 10 - 80%
- Sound Emission (Idle)
- 32 dBA
- Sound Emission (Operating)
- 51 dBA
- 45.8 cm
- 47.9 cm
- 40 cm
- 27.5 kg
- Width (Shipping)
- 60 cm
- Depth (Shipping)
- 50 cm
- Height (Shipping)
- 59.8 cm
- Weight (Shipping)
- 31.3 kg
Ink (4)
HP M522 Laserjet Toner Collection Unit | In Stock | £19.68 |
HP M522 220V Fuser Unit | In Stock | £212.99 |
HP 212X High Yield Yellow Original LaserJet Toner Cartridge | In Stock | £293.59 |
HP 212X High Yield Black Original LaserJet Toner Cartridge | In Stock | £207.92 |
