HP LaserJet Enterprise M527dn Mono Laser Multifunction Printer
Quicklinx: BT6JWS00 Mfr#: F2A76A#B19
Finish tasks faster with an MFP that starts right away and helps conserve energy. Multi-level device security helps protect from threats. Original HP Toner cartridges with JetIntelligence and this printer produce more high-quality pages.
  • Accelerate your work and use less energy
    Don't wait for documents. Print your first page in as few as 8.7 seconds from energy-efficient sleep mode and 5.7 seconds from ready.Print two-sided documents without sacrificing performance slowdowns for duplexing and let high-volume jobs handle themselves with a 2,300-sheet maximum input capacity.Scan two-sided documents in a single pass with super-fast scan speeds. HP EveryPage allows employees to scan without worry, detect potential errors or missed pages on the spot and save time with the advanced workflow features with the Flow MFP M527c.This MFP leads its class in low energy use – thanks to its innovative design and toner technology.
  • Unparalleled fleet security and management
    Embedded features detect security threats and heal your MFP, protecting it from boot up to shutdown.Protect sensitive data stored on the MFP and in transit, using embedded and optional security features.Protect sensitive business data with embedded and optional HP JetAdvantage Security Solutions.Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency.
  • More
    Produce sharp text, bold blacks, and crisp graphics with precision black toner.Get more. Original HP Toner with JetIntelligence delivers more pages per cartridge than predecessors.Get the professional results you expect from HP with a choice of JetIntelligence cartridges to fit your budget.Help ensure the Original HP quality you paid for with anti-fraud and cartridge authentication technology.
  • Stay connected with secure mobile printing options
    Use optional, 128-bit encrypted wireless direct printing from mobile devices – no network needed.Add the option to print with a touch of your NFC-enabled mobile device to this printer – no network needed.Easily access, print, and share resources with Ethernet and optional wireless networking.
HP LaserJet Enterprise MFP M527dn - multifunction printer - B/W
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
2000 - 7500 pages
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 43 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 dpi
Display
8"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
Standard Media Capacity
650 sheets
Max Media Capacity
2300 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, Internet faxing, scan to e-mail, save to network folder, Instant-on Technology, scan to FTP, security lock slot
AC 230 V (50Hz)
48.2 cm x 49.6 cm x 49.7 cm
21.9 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Printing Technology
Laser - monochrome
150000 pages
2000 - 7500 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Supported Flash Memory
USB flash drive
Copying
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Printing
Max Printing Speed
Up to 43 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF 1.7, PCL 5
Image Enhancement Technology
HP ProRes 1200
Automatic Duplexing
First Print Out Time B/W
5.7 sec
Scanning
Automatic Duplexing
Optical Resolution
600 dpi
Document & Media Handling
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
199 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, 101.6 x 152.4 mm, 76 x 127 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm, 102 x 148 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
650 sheets
Max Media Capacity
2300 sheets
100 sheets
250 sheets
Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m² , Input tray - 550 sheets size: 102 x 148 mm - 216 x 297 mm weight: 60 g/m² - 120 g/m² , Output tray - 250 sheets , ADF - 100 sheets - Legal (216 x 356 mm) weight: 45 g/m² - 199 g/m²
Speed Details
Printing: up to 43 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 45 ppm (Letter A) - B/W (ISO/IEC 24734) , Printing: up to 34 ipm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 36 ipm (Letter A) - B/W duplex (ISO/IEC 24734) , Scanning: up to 43 ppm (A4) - B/W , Scanning: up to 45 ppm (Letter A) - B/W , Scanning: up to 38 ppm (A4) - colour , Scanning: up to 40 ppm (Letter A) - colour , Scanning: up to 45 ipm (Letter A) - B/W duplex , Scanning: up to 40 ipm (Letter A) - colour duplex , Scanning: up to 43 ipm (A4) - B/W duplex , Scanning: up to 38 ipm (A4) - colour duplex
2 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
Operating System Support
Apple Mac OS X 10.x, Ubuntu Linux 10.04, Apple Mac OS X 10.7, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Fedora 17, Android, iOS, Fedora 18, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, Apple Mac OS X 10.9, Fedora 19, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Linux Mint 15, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Ubuntu Linux 13.10, Windows 10 (32/64-bits), SuSe Linux 12.2, SuSe Linux 12.3, SuSe Linux 13.1, Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, Debian Linux 7.x, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0.x
Software Included
Drivers & Utilities
AC 230 V (50Hz)
671 Watt
Power Consumption Standby
27.8 Watt
Power Consumption Sleep
3.2 Watt
Consumables Included
1 x Cartridge (black) - up to 9000 pages - HP 87A
FCC Class A certified, UL, cUL, GS, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, EN 60950-1:2006+A11:2009+A1:2010+A12:2011, EN 62479:2010, EMC 2004/108/EC, LVD 2006/95/EC, ICES-003 issue 4, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008, IEC60950-1:2005+A1, IEC 62479:2010
Security Slot Type
Kensington security slot
ENERGY STAR Certified
Blue Angel Compliant
48.2 cm
49.6 cm
49.7 cm
21.9 kg
Shipping Width
73.5 cm
Shipping Depth
61.3 cm
Shipping Height
59.2 cm
Shipping Weight
27.5 kg
Sound Emission
25 dBA (idle) / 56 dBA (operating)
15 °C
32.5 °C
10 - 80%
BT6J HP 87A Black Original LaserJet Toner Cartridge In Stock £159.12
BT6J HP 87X High Yield Black Original LaserJet Toner Cartridge In Stock £211.33
