This HP LaserJet MFP with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network from attacks with the industry's deepest security.
The world's most secure printing
With HP Sure Start, each printer regularly checks its operating code and repairs itself from attempted hacks.Help prevent potential attacks and take immediate action with instant notification of security issues.Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency. -
High-speed performance meets energy efficiency
Speed through tasks and save paper. Print two-sided documents nearly as fast as single-sided.This MFP wakes up fast and prints your first page faster – in as quickly as 7.9 seconds.This MFP uses exceptionally low amounts of energy thanks to its innovative design and toner technology.A variety of paper handling options are available. -
More
Produce sharp text, bold blacks, and crisp graphics with precision black toner.Original HP Toner cartridges with JetIntelligence deliver more pages per cartridge than predecessors.Help retain the Original HP quality you paid for with anti-fraud and cartridge authentication technology.Spend less time replacing toner, and more on business. Choose high-yield toner cartridges. -
Give workgroups the speed they need
Help workgroups capture every page easily and detect potential errors or missed pages – every time.Enter data more quickly and accurately using the pull-out keyboard.Help ensure every scanned document is properly oriented, cropped to size, and greyscale-optimised.Load up to 150 pages into the automatic document feeder for fast, unattended scanning.
- HP LaserJet Enterprise Flow MFP M631h - multifunction printer - B/W
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 300000 pages
- Recommended Monthly Volume
- 5000 - 30000 pages
- Max Copying Speed
- Up to 52 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 52 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Display
- 8"
- Original Size
- 216 x 863 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 150 sheets
- Media Size
- 76 x 127 mm (min) - 216 x 863 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 3750 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, Instant-on Technology, scan to SharePoint, scan to OCR, HP Auto-On/Auto-Off Technology, Instant-on Copy
- Power
- AC 230 V (50Hz)
- 51.2 cm x 55.8 cm x 64 cm
- 33.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Laser - monochrome
- 300000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 2.5 GB
- Max Supported Memory
- 3 GB
- Hard Disk Drive
- 320 GB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Up to 52 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- ID Card Copy, Manual Color Adjustment, collation copy, Job Build, Edge Erase, blank page skipping, Book Copy
Printing
- Up to 52 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.7, PCL 5
- Image Enhancement Technology
- HP FastRes 1200
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 863 mm
- Original Type
- Sheets
- 150 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 45 g/m²
- Max Media Weight
- 199 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, 216 x 863 mm, 99 x 148 mm, Oficio (216 x 343 mm), 216 x 356 mm, JIS B6 (128 x 182 mm), DL (210 x 99 mm), RA4 (215 x 305 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 650 sheets
- 3750 sheets
- 100 sheets
- 500 sheets
- ADF - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 45 g/m² - 199 g/m² , Input tray - 550 sheets size: 99 x 148 mm - 216 x 297 mm weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets , Output tray - 500 sheets
- Speed Details
- Printing: up to 80 ppm (A5) - B/W landscape , Printing: up to 52 ppm (A4) - B/W (ISO) , Printing: up to 43 ppm (A4) - B/W duplex , Copying: up to 52 ppm (A4) - B/W (ISO) , Copying: up to 43 ppm (A4) - B/W duplex , Printing: up to 55 ppm (Letter A) - B/W (ISO) , Copying: up to 55 ppm (Letter A) - B/W (ISO)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Operating System Support
- UNIX, Novell NetWare 6.5, MS Windows Server 2008 R2, Red Hat Enterprise Linux 6, Ubuntu Linux 12.04, MS Windows Server 2012, Novell Open Enterprise Server, Android, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 SP2 (32/64-bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Boss 5.0, Debian Linux 7.x, Linux Mint 17, Ubuntu Linux 14.04, Red Hat Enterprise Linux 7, Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition, Novell NetWare 6.5 SP8, Novell Open Enterprise Server 11 SP1, Novell Open Enterprise Server 2, Debian Linux 8.0, Novell Open Enterprise Server 11, macOS 10.12, Linux Mint 17.1, Linux Mint 17.2, Linux Mint 18, Linux Mint 17.3, SuSe Linux 13.2, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10, Debian Linux 8.1, Debian Linux 8.2, Debian Linux 8.3, Debian Linux 8.4, Debian Linux 8.5, Debian Linux 8.6, Fedora Linux 22, Fedora Linux 23, Fedora Linux 24
- Software Included
- Drivers & Utilities, HP Web Jetadmin, HP Device Experience (DXP), HP Connected
- Voltage Required
- AC 230 V (50Hz)
- GS, EMC, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 62479:2010, EMC 2004/108/EC, LVD 2006/95/EC, 21 CFR 1040.10, 21 CFR 1040.11, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008, EN 60950-1:2006+A1:2010+A2:2013+A11:2009+A12:2011, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 60825-1:2007, IEC 60825-1:2007 Class 1
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site - response time: next business day
- 51.2 cm
- 55.8 cm
- 64 cm
- 33.2 kg
- Shipping Width
- 70 cm
- Shipping Depth
- 63.9 cm
- Shipping Height
- 78.5 cm
- Shipping Weight
- 38 kg
- Sound Emission
- 59 dBA (operating)
- 15 °C
- 27 °C
- 10 - 80%
Ink (5)
HP 37X - High Yield Black Laserjet Toner Cartridge | In Stock | £252.28 |
HP 37A Black Original Laserjet Toner | In Stock | £163.37 |
HP 37Y Extra High Yield Black Original LaserJet Toner Cartridge | In Stock | £348.84 |
HP LaserJet 220V Maintenance Kit | In Stock | £291.43 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £16.68 |
Other bundles (1)
HP Foreign Interface Harness (FIH) | In Stock | £77.76 |
