HP LaserJet Enterprise Flow MFP M528z
Quicklinx: GLHZWS00 Mfr#: 1PV67A#B19
Functionality: Fax, Scanner, Copier, Printer
Output Type: Monochrome
Wireless Capability: Wired, Wireless
Technology: Laser
£1,779.18 ex VAT
£2,135.01 inc VAT
Choose an HP LaserJet Enterprise MFP designed to handle business solutions securely and efficiently, and helps conserve energy with HP EcoSmart toner black. Keep up with the demands of growing business with a printer you can rely on.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
HP LaserJet Enterprise Flow MFP M528z - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
2000 - 7500 pages
Max Copying Speed
Up to 43 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 43 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 203 x 392 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
105 x 127 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
Standard Media Capacity
650 sheets
Max Media Capacity
2300 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), NFC, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, Internet faxing, scan to e-mail, Hard Disk Drive Encryption, save to network folder, HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, Instant-on Technology, touch-to-print, scan to FTP, scan to SharePoint, scan to OCR, ultrasonic multi-feed detection, security lock slot
AC 230 V (50/60Hz)
48.2 cm x 49.6 cm x 49.7 cm
22.13 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Printer Fonts
TrueType x 105 , PostScript 3 x 92
Fax Type
Plain paper
Printing Technology
Laser - monochrome
150000 pages
2000 - 7500 pages
Display Diagonal Size
8"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1.75 GB
Max Supported Memory
2.5 GB
Hard Disk Drive
320 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Up to 43 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Booklet creation, auto colour select, collation copy, Job Build, Book Copy, job storage, edge-to-edge, ID Copy
Printing
Max Printing Speed
Up to 43 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF 1.7, PCL 5
Image Enhancement Technology
HP FastRes 1200, HP ProRes 1200
Automatic Duplexing
First Print Out Time B/W
6 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 500 pages
Fax Printing Resolution
400 x 400 dpi
PC Faxing
Fax Machine Features
Speed Dialing
1000 station(s)
Broadcast Transmission
210 stations
Remote Fax Retrieval (Polling)
Fax forwarding, automatic redialing, junk fax barrier, LAN fax, auto reduction, poll receive, fax archiving
Document & Media Handling
Min Original Size
105 x 127 mm
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
45 g/m²
Max Media Weight
200 g/m²
Min Media Weight (lb)
12 lbs
Max Media Weight (lb)
53 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, 101.6 x 152.4 mm, 76 x 127 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm, 102 x 148 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
650 sheets
Max Media Capacity
2300 sheets
100 sheets
250 sheets
Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m²; weight (lbs): 16 lbs - 53 lbs , Input tray - 550 sheets size: 102 x 148 mm - 216 x 297 mm weight: 60 g/m² - 120 g/m²; weight (lbs): 16 lbs - 32 lbs , ADF - 100 sheets size: 105 x 127 mm - Legal (216 x 356 mm) weight: 45 g/m² - 200 g/m²; weight (lbs): 12 lbs - 53 lbs , Output tray - 250 sheets
Speed Details
Printing: up to 43 ppm (A4) - B/W (ISO) , Printing: up to 45 ppm (Letter A) - B/W (ISO) , Printing: up to 34 ipm (A4) - B/W duplex , Printing: up to 65 ppm (A5) - B/W landscape , Scanning: up to 45 ppm (A4) - B/W normal , Scanning: up to 45 ppm (A4) - colour normal , Scanning: up to 64 ipm (A4) - B/W duplex normal , Scanning: up to 58 ipm (A4) - colour duplex
Finishing Equipment
Stapler
Included
2 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
Security Protocols & Features
Kerberos, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
Operating System Support
HP-UX 11.x, SunSoft Solaris 2.5 or later, MS Windows XP SP2 or later, Apple Mac OS X 10.5, HP-UX 11i, Novell NetWare 5.1, Apple Mac OS X 10.6, Red Hat Linux 7.x or later, SUSE Linux 8.x or later, IBM AIX 3.2.5 or later, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Apple Mac OS X 10.8.x, HP-UX 10.20, MS Windows XP 64-bit Edition SP2 or later, Apple Mac OS X 10.8, MS Windows Server 2012, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6.8, MS Windows Server 2003 x64 Edition SP1 or later, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5, MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.9.x, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), HP MPE/iX, Windows 8 Enterprise, Windows 8 Enterprise 64-bit, Windows 8 Enterprise N, Windows 8 Enterprise N 64-bit, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
Software Included
Drivers & Utilities, HP Update, HP Device Experience (DXP), HP Send Fax, Product Registration Assist, HP Connected, HP Software Installer/Uninstaller
AC 230 V (50/60Hz)
629 Watt
Power Consumption Standby
28.8 Watt
Power Consumption Sleep
5.3 Watt
Consumables Included
1 x toner cartridge (black)
FCC Class A certified, UL, cUL, GS, FCC Part 68, CS-03, R&TTE, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55024:1998 + A1 + A2, NOM-151-SCTI-1999, IEC 62479, IEC 60825-1:2007, EN 62479:2010, EMC 2004/108/EC, LVD 2006/95/EC, EN55022:2010 Class A, ETSI ES203 021, ICES-003 issue 4, CISPR 22:2008, IEC60950-1:2005+A1, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
Security Slot Type
Kensington security slot
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year - on-site - response time: next business day
48.2 cm
49.6 cm
49.7 cm
22.13 kg
Shipping Width
73.5 cm
Shipping Depth
59.2 cm
Shipping Height
61.3 cm
Shipping Weight
29.3 kg
Sound Emission
25 dBA (idle) / 54 dBA (operating)
10 °C
32.5 °C
10 - 80%
Ink (4)
GLHZ HP 89A Black Original LaserJet Toner Cartridge In Stock £126.79
GLHZ HP 89X High Yield Black Original LaserJet Toner Cartridge In Stock £194.38
GLHZ HP 89Y Extra High Yield Black Original LaserJet Toner Cartridge In Stock £262.60
GLHZ HP Glossy Laser Paper 150GSM 150 SHT/A4 In Stock £15.58
Other bundles (1)
GLHZ HP LaserJet 550 Sheet Paper Tray In Stock £110.33
Functionality: Fax
Functionality: Scanner
Functionality: Copier
Functionality: Printer
Wireless Capability: Wireless
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
Price Range Ex VAT: £1500+
