Choose an HP LaserJet Enterprise MFP designed to handle business solutions securely and efficiently, and helps conserve energy with HP EcoSmart toner black. Keep up with the demands of growing business with a printer you can rely on.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
- HP LaserJet Enterprise Flow MFP M528z - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 2000 - 7500 pages
- Max Copying Speed
- Up to 43 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 43 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 203 x 392 dpi
- Scanning
- 600 x 600 dpi
- Display
- 8"
- Original Size
- 105 x 127 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 2300 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Stapler
- Included
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), NFC, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, Internet faxing, scan to e-mail, Hard Disk Drive Encryption, save to network folder, HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, Instant-on Technology, touch-to-print, scan to FTP, scan to SharePoint, scan to OCR, ultrasonic multi-feed detection, security lock slot
- Power
- AC 230 V (50/60Hz)
- 48.2 cm x 49.6 cm x 49.7 cm
- 22.13 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Printer Fonts
- TrueType x 105 ¦ PostScript 3 x 92
- Fax Type
- Plain paper
- Laser - monochrome
- 150000 pages
- 2000 - 7500 pages
- Display Diagonal Size
- 8"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1.75 GB
- Max Supported Memory
- 2.5 GB
- Hard Disk Drive
- 320 GB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Up to 43 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- Booklet creation, auto colour select, collation copy, Job Build, Book Copy, job storage, edge-to-edge, ID Copy
Printing
- Up to 43 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.7, PCL 5
- Image Enhancement Technology
- HP FastRes 1200, HP ProRes 1200
- First Print Out Time B/W
- 6 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 500 pages
- Fax Printing Resolution
- 400 x 400 dpi
- PC Faxing
Fax Machine Features
- Speed Dialing
- 1000 station(s)
- Broadcast Transmission
- 210 stations
- Remote Fax Retrieval (Polling)
- Fax forwarding, automatic redialing, junk fax barrier, LAN fax, auto reduction, poll receive, fax archiving
Document & Media Handling
- Min Original Size
- 105 x 127 mm
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 45 g/m²
- Max Media Weight
- 200 g/m²
- Min Media Weight (lb)
- 12 lbs
- Max Media Weight (lb)
- 53 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, 101.6 x 152.4 mm, 76 x 127 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm, 102 x 148 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 650 sheets
- 2300 sheets
- 100 sheets
- 250 sheets
- Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m²; weight (lbs): 16 lbs - 53 lbs , Input tray - 550 sheets size: 102 x 148 mm - 216 x 297 mm weight: 60 g/m² - 120 g/m²; weight (lbs): 16 lbs - 32 lbs , ADF - 100 sheets size: 105 x 127 mm - Legal (216 x 356 mm) weight: 45 g/m² - 200 g/m²; weight (lbs): 12 lbs - 53 lbs , Output tray - 250 sheets
- Speed Details
- Printing: up to 43 ppm (A4) - B/W (ISO) , Printing: up to 45 ppm (Letter A) - B/W (ISO) , Printing: up to 34 ipm (A4) - B/W duplex , Printing: up to 65 ppm (A5) - B/W landscape , Scanning: up to 45 ppm (A4) - B/W normal , Scanning: up to 45 ppm (A4) - colour normal , Scanning: up to 64 ipm (A4) - B/W duplex normal , Scanning: up to 58 ipm (A4) - colour duplex
Finishing Equipment
- Stapler
- Included
- 2 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
- Kerberos, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Operating System Support
- HP-UX 11.x, SunSoft Solaris 2.5 or later, MS Windows XP SP2 or later, Apple Mac OS X 10.5, HP-UX 11i, Novell NetWare 5.1, Apple Mac OS X 10.6, Red Hat Linux 7.x or later, SUSE Linux 8.x or later, IBM AIX 3.2.5 or later, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Apple Mac OS X 10.8.x, HP-UX 10.20, MS Windows XP 64-bit Edition SP2 or later, Apple Mac OS X 10.8, MS Windows Server 2012, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6.8, MS Windows Server 2003 x64 Edition SP1 or later, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5, MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.9.x, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), HP MPE/iX, Windows 8 Enterprise, Windows 8 Enterprise 64-bit, Windows 8 Enterprise N, Windows 8 Enterprise N 64-bit, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
- Software Included
- Drivers & Utilities, HP Update, HP Device Experience (DXP), HP Send Fax, Product Registration Assist, HP Connected, HP Software Installer/Uninstaller
- Voltage Required
- 629 Watt
- Power Consumption Standby
- 28.8 Watt
- Power Consumption Sleep
- 5.3 Watt
- Consumables Included
- 1 x toner cartridge (black)
- FCC Class A certified, UL, cUL, GS, FCC Part 68, CS-03, R&TTE, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55024:1998 + A1 + A2, NOM-151-SCTI-1999, IEC 62479, IEC 60825-1:2007, EN 62479:2010, EMC 2004/108/EC, LVD 2006/95/EC, EN55022:2010 Class A, ETSI ES203 021, ICES-003 issue 4, CISPR 22:2008, IEC60950-1:2005+A1, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- Security Slot Type
- Kensington security slot
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year - on-site - response time: next business day
- 48.2 cm
- 49.6 cm
- 49.7 cm
- 22.13 kg
- Shipping Width
- 73.5 cm
- Shipping Depth
- 59.2 cm
- Shipping Height
- 61.3 cm
- Shipping Weight
- 29.3 kg
- Sound Emission
- 25 dBA (idle) / 54 dBA (operating)
- 10 °C
- 32.5 °C
- 10 - 80%
Ink (3)
HP 89A Black Original LaserJet Toner Cartridge | In Stock | £131.06 |
HP 89X High Yield Black Original LaserJet Toner Cartridge | In Stock | £200.91 |
HP 89Y Extra High Yield Black Original LaserJet Toner Cartridge | In Stock | £263.51 |
Other bundles (1)
HP LaserJet 550 Sheet Paper Tray | In Stock | £110.33 |
