HP Laserjet Enterprise Flow M632z Mono Laser 61ppm Multifunction Printer
Quicklinx: DZWKWS00 Mfr#: J8J72A#B19
Functionality: Copier, Fax, Printer, Scanner
Output Type: Monochrome
Technology: Laser
Max Print Speed: 61ppm
Hurry, only 2 left in stock!
£3,498.74 ex VAT
£4,198.48 inc VAT
This HP LaserJet MFP with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network from attacks with the industry's deepest security.
  • The world's most secure printing
    With HP Sure Start, each printer regularly checks its operating code and repairs itself from attempted hacks.Run-time intrusion detection continually monitors to detect and stop attacks, then automatically reboots.Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency.Give workgroups what they need to succeed. Easily choose and deploy over 180 HP and third-party solutions.
  • High-speed performance meets energy efficiency
    Speed through tasks and save paper. Print two-sided documents nearly as fast as single-sided.This printer wakes up fast and prints your first page faster – in as quickly as 12.1 seconds.This MFP uses exceptionally low amounts of energy thanks to its innovative design and toner technology.Paper handling options include a wheeled stand and 550-sheet input feeder for paper sizes 10.16 x 15.24 cm (4 x 6") to legal.
  • More
    Produce sharp text, bold blacks, and crisp graphics with precision black toner.Original HP Toner cartridges with JetIntelligence deliver more pages per cartridge than predecessors.Help retain the Original HP quality you paid for with anti-fraud and cartridge authentication technology.Spend less time replacing toner, and more on business. Choose high-yield toner cartridges.
  • Give workgroups the speed they need
    Help workgroups capture every page easily and detect potential errors or missed pages – every time.Enter data more quickly and accurately using the pull-out keyboard.Help ensure every scanned document is properly oriented, cropped to size, and greyscale-optimised.Load up to 150 pages into the automatic document feeder for fast, unattended scanning.
HP LaserJet Enterprise Flow MFP M632z - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
300000 pages
Recommended Monthly Volume
5000 - 30000 pages
Max Copying Speed
Up to 61 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 61 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 203 x 392 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
216 x 863 mm (max)
Original Type
Sheets
Document Feeder Capacity
150 sheets
Media Size
76 x 127 mm (min) - 216 x 863 mm (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper
Standard Media Capacity
3200 sheets
Max Media Capacity
3750 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
1000 sheets
Stacker
Included
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, Instant-on Technology, scan to SharePoint, scan to OCR, HP Auto-On/Auto-Off Technology, Instant-on Copy
AC 230 V (50Hz)
66.1 cm x 65.8 cm x 123.4 cm
64.3 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
300000 pages
5000 - 30000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1.5 GB
Max Supported Memory
2 GB
Hard Disk Drive
320 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Up to 61 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
ID Card Copy, Manual Color Adjustment, collation copy, Job Build, Edge Erase, blank page skipping, Book Copy
Printing
Max Printing Speed
Up to 61 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF 1.7, PCL 5
Image Enhancement Technology
HP FastRes 1200
Automatic Duplexing
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 500 pages
Fax Printing Resolution
400 x 400 dpi
PC Faxing
Fax Machine Features
Speed Dialing
1000 station(s)
Remote Fax Retrieval (Polling)
Fax forwarding, automatic redialing, junk fax barrier, LAN fax, auto reduction, fax polling, fax archiving
Document & Media Handling
Max Original Size
216 x 863 mm
Original Type
Sheets
150 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
45 g/m²
Max Media Weight
199 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, 216 x 863 mm, 99 x 148 mm, Oficio (216 x 343 mm), 216 x 356 mm, JIS B6 (128 x 182 mm), DL (210 x 99 mm), RA4 (215 x 305 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
3200 sheets
Max Media Capacity
3750 sheets
100 sheets
1000 sheets
ADF - 150 sheets size: 68 x 147 mm - 216 x 863 mm weight: 45 g/m² - 199 g/m² , Input tray - 550 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m² , Input tray - 550 sheets size: 99 x 148 mm - 216 x 297 mm weight: 60 g/m² - 120 g/m² , Input tray - 2000 sheets size: 99 x 148 mm - Legal (216 x 356 mm) , Bypass tray - 100 sheets , Output tray - 500 sheets
Speed Details
Printing: up to 100 ppm (A5) - B/W normal , Printing: up to 61 ppm (A4) - B/W normal , Printing: up to 50 ppm (A4) - B/W duplex , Copying: up to 61 ppm (A4) - B/W normal , Copying: up to 50 ppm (A4) - B/W duplex
Finishing Equipment
Stacker
Included
Stapler
Included
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
Security Protocols & Features
Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
Operating System Support
UNIX, Novell NetWare 6.5, MS Windows Server 2008 R2, Red Hat Enterprise Linux 6, Ubuntu Linux 12.04, MS Windows Server 2012, Novell Open Enterprise Server, Android, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 SP2 (32/64-bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Boss 5.0, Debian Linux 7.x, Linux Mint 17, Ubuntu Linux 14.04, Red Hat Enterprise Linux 7, Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition, Novell NetWare 6.5 SP8, Novell Open Enterprise Server 11 SP1, Novell Open Enterprise Server 2, Debian Linux 8.0, Novell Open Enterprise Server 11, macOS 10.12, Linux Mint 17.1, Linux Mint 17.2, Linux Mint 18, Linux Mint 17.3, SuSe Linux 13.2, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10, Debian Linux 8.1, Debian Linux 8.2, Debian Linux 8.3, Debian Linux 8.4, Debian Linux 8.5, Debian Linux 8.6, Fedora Linux 22, Fedora Linux 23, Fedora Linux 24
Software Included
Drivers & Utilities, HP Web Jetadmin, HP Device Experience (DXP), HP Connected
AC 230 V (50Hz)
GS, EMC, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 62479:2010, EMC 2004/108/EC, LVD 2006/95/EC, 21 CFR 1040.10, 21 CFR 1040.11, ETSI ES203 021, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008, EN 60950-1:2006+A1:2010+A2:2013+A11:2009+A12:2011, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 60825-1:2007, R&TTE Directive 1999/5/EC, IEC 60825-1:2007 Class 1
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year - on-site - response time: next business day
66.1 cm
65.8 cm
123.4 cm
64.3 kg
Shipping Width
85.6 cm
Shipping Depth
76 cm
Shipping Height
166 cm
Shipping Weight
86.3 kg
Sound Emission
60 dBA (operating)
15 °C
27 °C
10 - 80%
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Technology: Laser
Max Paper Size: 216 x 863 mm
Brand: HP
Price Range Ex VAT: 1500+
