Enable large-volume professional-quality colour printing on a wide range of paper sizes up to A3, with paper capacity up to 4,350 sheets. Preview and edit scanning jobs. Centrally manage printing policies. Safeguard sensitive business information.
2-sided printing
Allows you to print on both sides of the page, cutting your paper use by up to 50%. -
20.3 cm colour touchscreen (printer)
Manage jobs directly at the MFP, using the HP colour touchscreen.
- HP Color LaserJet Enterprise MFP M775dn - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 120000 impressions
- Recommended Monthly Volume
- 2500 - 7500 pages
- Max Copying Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Scanning
- 600 x 600 dpi
- Display
- 8.07"
- Original Size
- 101.6 x 152.4 mm (min) - A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - 320 x 470 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, photo paper, bond paper, film, heavy-weight paper, card stock
- Standard Media Capacity
- 350 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host, 2 x USB host (internal)
- AirPrint Enabled
- Office Machine Features
- Document send function, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, automatic paper sensor, Foreign Interface Harness (FIH)
- Power
- AC 230 V (50/60Hz)
- 59.2 cm x 63.9 cm x 59.5 cm
- 63.7 kg
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- Copier Type
- Digital
- Laser - colour
- 2500 - 7500 pages
- Display Diagonal Size
- 8.07"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1536 MB 1.5 GB
- Max Supported Memory
- 1536 MB 1.5 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- Auto colour select
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.4
- Image Enhancement Technology
- HP ImageREt 3600
- First Print Out Time B/W
- 10.5 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Min Original Size
- 101.6 x 152.4 mm
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 49 g/m²
- Max Media Weight
- 120 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ANSI B (Ledger) (279 x 432 mm), ARCH B (304.8 x 457.2 mm), Folio (216 x 330 mm), 297 x 432 mm, 148 x 182 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76 x 127 mm, RA3 (305 x 430 mm), 127 x 177.8 mm, 320 x 470 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 350 sheets
- 100 sheets
- 250 sheets
- Output tray - 250 sheets , Bypass tray - 100 sheets size: 76 x 127 mm - 320 x 470 mm weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 148 x 182 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , ADF - 100 sheets size: 101.6 x 152.4 mm - A3/Ledger (297 x 432 mm)
- Speed Details
- Printing: up to 30 ppm (A4) - B/W normal , Printing: up to 30 ppm (A4) - colour normal , Copying: up to 30 ppm (A4) - B/W normal , Copying: up to 30 ppm (A4) - colour normal , Scanning: up to 30 ppm (A4) - B/W normal , Scanning: up to 30 ppm (A4) - colour normal
- 1 x USB 2.0 , 1 x USB host , 2 x USB host (internal) , 1 x Gigabit LAN
- Operating System Support
- UNIX, Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Windows 8
- Software Included
- Drivers & Utilities
- Voltage Required
- 703 Watt
- Power Consumption Standby
- 85 Watt
- Power Consumption Sleep
- 14.8 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 13500 pages , 1 x toner cartridge (cyan) - up to 16000 pages , 1 x toner cartridge (magenta) - up to 16000 pages , 1 x toner cartridge (yellow) - up to 16000 pages
- FCC Class A certified, UL, cUL, GS, ICES-003, EN55024, EN55022 Class A, CISPR 22, EMC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, LVD, GB 9254-2008, EN 61000-3-2:2006, EN 61000-3-3:2008, GB 17625.1-2003 EMC
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 59.2 cm
- 63.9 cm
- 59.5 cm
- 63.7 kg
- Shipping Width
- 76 cm
- Shipping Depth
- 74.5 cm
- Shipping Height
- 83.2 cm
- Shipping Weight
- 76.5 kg
- Sound Emission
- 53 dBA (operating)
- 15 °C
- 27 °C
- 10 - 70%
HP 651A Black Original LaserJet Toner Cartridge | In Stock | £158.54 |
HP 651A Cyan Original LaserJet Toner Cartridge | In Stock | £399.18 |
HP 651A Yellow Original LaserJet Toner Cartridge | In Stock | £399.18 |
HP 651A Magenta Original LaserJet Toner Cartridge | In Stock | £399.18 |
