Enable high-volume, black-and-white printing on paper sizes up to A3, with capacity up to 4,600 sheets. Control costs with energy-saving features and two-sided printing. Protect sensitive business data and centrally manage printing policies.
2-sided printing
Allows you to print on both sides of the page, cutting your paper use by up to 50%. -
Only the power you need
Help save energy with HP Auto-On/Auto-Off Technology. -
Prints in a flash, savings that last
Print right away with Instant-on Technology. -
On-the-go printing with HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint. -
Ethernet (printer)
Add this device to your office Ethernet network to share with your workgroup.
- HP LaserJet Enterprise 700 Printer M712dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 38.5 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A3/Ledger
- Max Media Size
- 312 x 470 mm
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 312 mm x 470 mm
- Print Speed
- Up to 40 ppm - black normal - ANSI A (Letter) (216 x 279 mm) , Up to 41 ppm - black normal - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Image Enhancement Technology
- HP ProRes 1200 / HP FastRes 1200
- Automatic Duplexing
- Interface
- USB, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- 800 MHz
- RAM Installed (Max)
- 512 MB (1 GB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF 1.4
- Media Type
- Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, vellum paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 2x 250-sheet input trays
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 5000 - 20000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - integrated
- Printer Features
- Hardware integration pocket
- System Requirements
- Microsoft Windows XP SP2 or later, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows Server 2003 SP1 or later, Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2008 (32/64-bits), Apple MacOS X Lion 10.7, Microsoft Windows Vista / 7 / 8
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver
- 56.8 cm x 59.6 cm x 39.2 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 10.5 sec
- Printer Features
- Media Handling
- Processor
- 800 MHz
RAM
- 512 MB / 1 GB (max)
Media Handling
- Media Type
- Media Size Class
- A3/Ledger
- Max Media Size
- 312 x 470 mm
- 76.2 mm x 127 mm
- 312 mm x 470 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 312 x 470 mm, 76.2 x 127 mm, 279.4 x 431.8 mm, 215.9 x 330.2 mm, 297.2 x 431.8 mm, 297 x 363 mm
- Media Weight
- 60 g/m² - 199 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - 312 x 470 mm weight: 60 g/m² - 199 g/m² , 1 x automatic - 250 sheets - 297 x 363 mm weight: 60 g/m² - 120 g/m² , 1 x automatic - 250 sheets - 297.2 x 431.8 mm weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 4600 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 100000 pages
- Networking
- Print server - integrated
- Data Link Protocol
- ICMP/IP, LPR/LPD, FTP, BOOTP, DHCP, Bonjour, SLP
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP
- Kerberos, Apple Bonjour, TLS, IPsec, 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 10000 pages
- UL, cUL, GS, ICES-003, EN55024, EN55022 Class A, CISPR 22, EMC, FCC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, LVD, EN 61000-3-2:2006, EN 61000-3-3:2008
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 786 watt
- Power Consumption Stand by / Sleep
- 22.1 watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows Server 2003/2008 - HD 200 MB , Windows XP/Vista/7/8 - HD 200 MB , MacOS X 10.6/10.7 - HD 200 MB
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- 10 °C
- 32.5 °C
- 20 - 80%
- Sound Emission (Operating)
- 54 dBA
- 56.8 cm
- 59.6 cm
- 39.2 cm
- 38.5 kg
- Width (Shipping)
- 81 cm
- Depth (Shipping)
- 78.5 cm
- Height (Shipping)
- 64.4 cm
- Weight (Shipping)
- 45.6 kg
HP 14A Black Original LaserJet Toner Cartridge | In Stock | £191.22 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £16.68 |
