HP LaserJet Enterprise 500 M575f Colour Laser Multifunction Printer
YOU BUY. YOU TRY. YOU DECIDE!
Quicklinx: 82R9WS00 Mfr#: CD645A#b19
Accelerate processes and turn documents into dynamic digital files, using a desktop MFP that produces standout colour. Versatile scanning, processing, routing, and retrieval tools help boost productivity. Simplify management and strengthen security.
  • 2-sided printing
    Allows you to print on both sides of the page, cutting your paper use by up to 50%.
  • 20.3 cm color touchscreen (printer)
    Manage jobs directly at the MFP, using the HP color touchscreen.
  • Pull print jobs from your pocket
    Walk up and print from a USB drive, using the easy-access USB port.
HP Color LaserJet Enterprise MFP M575f - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
75000 impressions
Recommended Monthly Volume
2000 - 6000 pages
Max Copying Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 400 x 400 dpi, 204 x 98 dpi, 204 x 196 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, film, heavy-weight paper
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network
AC 230 V (50Hz)
66.3 cm x 55.5 cm x 58.5 cm
47 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
75000 impressions
2000 - 6000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1536 MB 1.5 GB
Max Supported Memory
1536 MB 1.5 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.4
Automatic Duplexing
First Print Out Time B/W
10.5 sec
First Print Out Time Colour
10.5 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
PC Faxing
Fax Machine Features
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, fax polling
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), JIS B6 (128 x 182 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
350 sheets
Max Media Capacity
850 sheets
250 sheets
ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) , Input tray - 100 sheets - Legal (216 x 356 mm) , Output tray - 250 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W , Copying: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Copying: up to 30 ppm (A4) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Operating System Support
MS Windows XP SP2 or later, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, MS Windows Server 2008 R2, Apple Mac OS X 10.7, MS Windows Server 2003 SP1 or later
Software Included
Drivers & Utilities
AC 230 V (50Hz)
665 watt
Power Consumption Standby
52 watt
Power Consumption Sleep
11.3 watt
Phone cable
Consumables Included
1 x toner cartridge (black) - up to 5500 pages , 1 x toner cartridge (cyan) - up to 6000 pages , 1 x toner cartridge (magenta) - up to 6000 pages , 1 x toner cartridge (yellow) - up to 6000 pages
UL, cUL, EN 61000-3-2, EN55022, GS, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, GB 17625.1, GB 9254 Class A
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
66.3 cm
55.5 cm
58.5 cm
47 kg
Shipping Width
75 cm
Shipping Depth
72.5 cm
Shipping Height
64 cm
Shipping Weight
52.5 kg
Sound Emission
54 dBA (operating)
10 °C
30 °C
10 - 70%
82R9 HP 507A Black Original LaserJet Toner Cartridge In Stock £139.34
82R9 HP 507A Cyan Original LaserJet Toner Cartridge In Stock £207.57
82R9 HP 507A Yellow Original LaserJet Toner Cartridge In Stock £207.57
82R9 HP 507A Magenta Original LaserJet Toner Cartridge In Stock £207.57
82R9 HP 507X High Yield Black Original LaserJet Toner Cartridge In Stock £187.46
