Accelerate processes and turn documents into dynamic digital files, using advanced workflow tools in a desktop MFP. Versatile scanning, processing, routing and retrieval tools help boost productivity. Simplify management and strengthen security.
Get breakthrough performance, with best-in-class scanning
Get fast results from two-sided, single-pass scanning and HP EveryPage. Automatically remove blank pages.Manage big jobs easily with the 100-sheet automatic document feeder. Enter data on a large, pull-out keyboard.Do more with data using built-in OCR and multiple scan-to options. Produce clean, readable scans using auto-orientation, auto-page-crop, auto-tone and auto-deskew tools.Preview, edit, insert and delete scanned pages on-screen. Launch one-touch processes from the touchscreen. -
Increase productivity with this easy-to-use desktop MFP
Manage jobs directly at this desktop-size MFP, using the 20.3 cm (8-inch) HP Easy Select colour touchscreen.Get exceptional value from using an optional, high-capacity Original HP LaserJet black toner cartridge.Improve efficiency by sending scanned documents directly to email, fax, or network folder.Print from your smartphone or tablet with HP ePrint. Save and print files directly via an easy-access USB port. -
Enjoy top-flight manageability and robust security features
Rely on powerful solutions for deploying, managing and safeguarding your printing fleet.Robust encryption helps secure sensitive information – at rest on the MFP or in transit over the network.Protect documents with PIN printing capabilities, and add security solutions through the hardware integration pocket.Extend the capabilities of work-team print environments with a rich array of easy-to-integrate solutions. -
Reduced energy costs and your environmental impact
Reduce energy use with HP Auto-On/Auto-Off Technology which turns your printer on when you need it and off when you don't. Conserve power with Instant-on Technology.Prevent wasted paper: use automatic two-sided printing and PIN printing.Easily recycle Original HP LaserJet toner cartridges through HP Planet Partners.
- HP LaserJet Enterprise MFP M525f - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 75000 impressions
- Recommended Monthly Volume
- 2000 - 6000 pages
- Max Copying Speed
- Up to 42 ppm
- Max Copying Resolution
- Up to 1200 x 1200 dpi
- Max Printing Speed
- Up to 42 ppm
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 400 x 400 dpi, 204 x 98 dpi, 204 x 196 dpi
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 1600 sheets
- Stapler
- Included
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network, security lock slot
- Power
- AC 110/230 V (50/60Hz)
- 51.6 cm x 54.7 cm x 57.6 cm
- 29.8 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - monochrome
- 75000 impressions
- 2000 - 6000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- Localisation
- Standard Memory
- 1 GB 1 GB
- Max Supported Memory
- 1 GB 1 GB
Copying
- Max Copying Speed
- Up to 42 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
Printing
- Up to 42 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.4
- Image Enhancement Technology
- HP FastRes 1200
- First Print Out Time B/W
- 8.5 sec
Scanning
- Optical Resolution
- 600 dpi
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, fax polling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm)
- 600 sheets
- 1600 sheets
- ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 500 sheets - Legal (216 x 356 mm) , Input tray - 100 sheets - Legal (216 x 356 mm) , Output tray - 250 sheets
- Speed Details
- Printing: up to 42 ppm (A4) - B/W , Copying: up to 42 ppm (A4) - B/W
Finishing Equipment
- Stapler
- Included
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Operating System Support
- MS Windows Server 2003, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5 or later
- Software Included
- Drivers & Utilities
- Voltage Required
- 785 Watt
- Power Consumption Standby
- 30 Watt
- Power Consumption Sleep
- 9.6 Watt
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages
- EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EMC, IEC 60950-1, EN 60950-1, FCC CFR47, IEC 60825-1, EN 60825-1
- Security Slot Type
- Kensington security slot
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site
- 51.6 cm
- 54.7 cm
- 57.6 cm
- 29.8 kg
- Shipping Width
- 73.3 cm
- Shipping Depth
- 61.3 cm
- Shipping Height
- 60 cm
- Shipping Weight
- 36 kg
- Sound Emission
- 57 dBA (operating)
- 10 °C
- 32.5 °C
- 10 - 90% (non-condensing)
