HP LaserJet Enterprise 500 M525DN Mono Laser Multifunction Printer
Quicklinx: 85WMWS00 Mfr#: CF116A#B19
Accelerate processes and turn documents into dynamic digital files, using advanced workflow tools in a desktop MFP. Versatile scanning, processing, routing and retrieval tools help boost productivity. Simplify management and strengthen security.
  • Get breakthrough performance, with best-in-class scanning
    Get fast results from two-sided, single-pass scanning and HP EveryPage. Automatically remove blank pages.Manage big jobs easily with the 100-sheet automatic document feeder. Enter data on a large, pull-out keyboard.Do more with data using built-in OCR and multiple scan-to options. Produce clean, readable scans using auto-orientation, auto-page-crop, auto-tone and auto-deskew tools.Preview, edit, insert and delete scanned pages on-screen. Launch one-touch processes from the touchscreen.
  • Increase productivity with this easy-to-use desktop MFP
    Manage jobs directly at this desktop-size MFP, using the 20.3 cm (8-inch) HP Easy Select colour touchscreen.Get exceptional value from using an optional, high-capacity Original HP LaserJet black toner cartridge.Improve efficiency by sending scanned documents directly to email, fax, or network folder.Print from your smartphone or tablet with HP ePrint. Save and print files directly via an easy-access USB port.
  • Enjoy top-flight manageability and robust security features
    Rely on powerful solutions for deploying, managing and safeguarding your printing fleet.Robust encryption helps secure sensitive information – at rest on the MFP or in transit over the network.Protect documents with PIN printing capabilities, and add security solutions through the hardware integration pocket.Extend the capabilities of work-team print environments with a rich array of easy-to-integrate solutions.
  • Reduced energy costs and your environmental impact
    Reduce energy use with HP Auto-On/Auto-Off Technology which turns your printer on when you need it and off when you don't. Conserve power with Instant-on Technology.Prevent wasted paper: use automatic two-sided printing and PIN printing.Easily recycle Original HP LaserJet toner cartridges through HP Planet Partners.
HP LaserJet Enterprise MFP M525dn - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
75000 impressions
Recommended Monthly Volume
2000 - 5000 pages
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, film, heavy-weight paper
Standard Media Capacity
600 sheets
Max Media Capacity
1100 sheets
Output Trays Capacity
350 sheets
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Security lock slot
AC 230 V (50Hz)
51.6 cm x 54.7 cm x 57.6 cm
29.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Laser - monochrome
75000 impressions
2000 - 5000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Security lock slot
Standard Memory
1 GB 1 GB
Max Supported Memory
1 GB 1 GB
Copying
Max Copying Speed
Up to 40 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.4
Image Enhancement Technology
HP FastRes 1200
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), JIS B6 (128 x 182 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
600 sheets
Max Media Capacity
1100 sheets
350 sheets
ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 500 sheets - Legal (216 x 356 mm) , Input tray - 100 sheets - Legal (216 x 356 mm) , Output tray - 250 sheets , Output tray - 100 sheets
Speed Details
Printing: up to 40 ppm (A4) - B/W , Copying: up to 40 ppm (A4) - B/W
Finishing Equipment
Stapler
Included
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Operating System Support
MS Windows XP SP2 or later, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, MS Windows Server 2008 R2, Apple Mac OS X 10.7, MS Windows Server 2003 SP1 or later
Software Included
Drivers & Utilities
AC 230 V (50Hz)
785 watt
Power Consumption Standby
30 watt
Power Consumption Sleep
9.6 watt
Consumables Included
1 x toner cartridge (black) - up to 5500 pages - HP 55A
UL, cUL, EN 61000-3-2, EN55022, GS, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, GB 17625.1, GB 9254 Class A
Security Slot Type
Kensington security slot
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
51.6 cm
54.7 cm
57.6 cm
29.4 kg
Shipping Width
73.3 cm
Shipping Depth
61.3 cm
Shipping Height
60 cm
Shipping Weight
35.6 kg
Sound Emission
57 dBA (operating)
10 °C
32.5 °C
10 - 80%
85WM HP 55A Black Original LaserJet Toner Cartridge In Stock £137.19
85WM HP 55X High Yield Black Original LaserJet Toner Cartridge In Stock £213.31
85WM HP 55X 2-pack High Yield Black Original LaserJet Toner Cartridges In Stock £421.23
