The 400-sheet Custom Media Tray gives you the flexibility to print small jobs on different media. It has been designed to support some of the smaller media sizes (as small as A6) that currently are not supported on the standard input tray.
- HP media tray
- Product Type
- Media tray
- Designed For
- LaserJet P4014, P4014dn, P4014n, P4515n, P4515tn, P4515x, P4515xm; LaserJet Enterprise 600 M601dn, 600 M601m, 600 M601n, 600 M602dn, 600 M602m, 600 M602n, 600 M602x, 600 M603dn, 600 M603n, 600 M603xh
- Product Type
- Media tray
- Shipping Dimensions (WxDxH) / Weight
- 59 cm x 43 cm x 24.5 cm / 3 kg
- Designed For
- HP LaserJet P4014, P4014dn, P4014n, P4515n, P4515tn, P4515x, P4515xm , HP LaserJet Enterprise 600 M601dn, 600 M601m, 600 M601n, 600 M602dn, 600 M602m, 600 M602n, 600 M602x, 600 M603dn, 600 M603n, 600 M603xh
