Designed to deliver efficiency and versatility, this powerful wide-format A3+ monochrome laser printer is flexible and easily manageable to meet your office printing needs.
Get perfect results on media up to A3+ from this efficient monochrome HP LaserJet printer
Get great results on media up to A3+ with this high performance mono HP LaserJet. It delivers fast print and first page out speeds, 460 MHz processor for handling complex print jobs, expandable memory up to 512 MB and industry-leading networking. -
Supporting a wide range of solutions and media sizes, this printer keeps pace with your business
Benefit from more options with this versatile printer. A3+ printing capabilities expand the printable area, CompactFlash support enables third-party solutions and the open EIO slot enhances productivity with the HP high-performance EIO hard disk. -
Make your job easier with this simple and intuitive printer which is both easy to use and manage
Experience worry-free printing, simple operation, and effortless printer management with tools like HP Web Jetadmin. Easily replace the HP all-in-one print cartridge that assures quality and reliability with its HP Smart printing technology.
- HP LaserJet 5200tn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 30.2 kg
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Max Media Size (Custom)
- 312 mm x 470 mm
- Print Speed
- Up to 35 ppm - black best - A4 (210 x 297 mm) , Up to 18.5 ppm - black normal - A3 (297 x 420 mm) , Up to 18.5 ppm - black best - A3 (297 x 420 mm) , Up to 35 ppm - black normal - A4 (210 x 297 mm) , Up to 35 ppm - black draft - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Image Enhancement Technology
- HP ProRes 1200 / HP FastRes 1200
- Interface
- Parallel, USB, LAN
- Processor
- MIPS 460 MHz
- RAM Installed (Max)
- 64 MB (512 MB) - DDR SDRAM - DIMM 100-PIN
- Language Simulation
- PCL 5E, PostScript 3, PCL 6
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper, vellum paper
- Total Media Capacity
- 850 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet input tray, 500-sheet input tray
- Monthly Duty Cycle (max)
- 65000 pages
- Networking
- Print server - Ethernet, Fast Ethernet - integrated
- Printer Features
- Optional duplex
- System Requirements
- Apple MacOS X 10.2, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Apple MacOS X 10.3, Apple MacOS X 10.4
- Microsoft Certification
- Certified for Windows Vista
- 49 cm x 60 cm x 40.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Up to 35 ppm - black best - 1200x1200 dpi - A4 (210 x 297 mm) , Up to 18.5 ppm - black normal - 1200x1200 dpi - A3 (297 x 420 mm) , Up to 18.5 ppm - black best - 1200x1200 dpi - A3 (297 x 420 mm) , Up to 35 ppm - black normal - 1200x1200 dpi - A4 (210 x 297 mm) , Up to 35 ppm - black draft - 600x600 dpi - A4 (210 x 297 mm)
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 10 sec
- Fonts Included
- 93 x PostScript , 103 x PCL
- Printer Features
- Optional duplex
- Media Handling
- Processor
- MIPS 460 MHz
RAM
- 64 MB / 512 MB (max)
- Technology / Form Factor
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- 312 mm x 470 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), 297 x 432 mm, Tabloid Extra (305 x 457 mm), JIS B5 (182 x 257 mm), 312 x 470 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76.2 x 127 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 199 g/m²
- 850 sheets
- Media Feeders
- 1 x automatic - 100 sheets - 312 x 470 mm weight: 60 g/m² - 199 g/m² , 1 x automatic - 250 sheets - 297 x 432 mm weight: 60 g/m² - 120 g/m² , 1 x automatic - 500 sheets - 297 x 432 mm weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 65000 pages
- Networking
- Print server - integrated
- Data Link Protocol
- AppleTalk
- Expansion Slots
- 2 x CompactFlash Card , 1 x EIO
- Connections
- 1 x parallel , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 12000 pages
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- TUV, CISPR 22 Class A, EN 60950, EN 61000-3-2, ICES-003, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class A, FCC Part 15 B, EMC
- Power Device
- Power supply - internal
- 600 Watt
- Power Consumption Stand by / Sleep
- 27 Watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows 98 - Pentium - 90 MHz - RAM 16 MB - HD 220 MB , Windows ME - Pentium - 150 MHz - RAM 32 MB - HD 220 MB , Windows 2000 - 133 MHz - RAM 64 MB - HD 220 MB , Windows XP - 233 MHz - RAM 64 MB - HD 220 MB , Windows Server 2003 - 550 MHz - RAM 128 MB - HD 220 MB , MacOS X 10.2 or later - HD 160 MB
Environmental Standards
- ENERGY STAR
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 31 dBA
- Sound Emission (Operating)
- 54 dBA
- 49 cm
- 60 cm
- 40.5 cm
- 30.2 kg
- Width (Shipping)
- 79.9 cm
- Depth (Shipping)
- 73.1 cm
- Height (Shipping)
- 60 cm
- Weight (Shipping)
- 42.7 kg
HP 16A Black Original LaserJet Toner Cartridge | In Stock | £179.13 |
