HP Keyed Cable Lock 10mm
Quicklinx: CKKYWS00 Mfr#: T1A62AA
£27.00 ex VAT
£32.40 inc VAT
Help keep your notebook safe in the office and high-traffic areas by tethering it to a secure surface with the HP Master Keyed Cable Lock 10mm, designed specifically for ultra-thin profile notebooks.
  • Loop and lock
    Wrap the 6 ft (1.83 m) vinyl-coated, galvanized steel cable around any secure object and attach to your notebook. Insert the master key into the lock and turn clockwise 90 degrees for a great IT manager solution.
  • Room to move
    The cable head swivels 360-degrees to help you position the cable as needed before you lock.
  • Rest easy
    Get the reassurance of a one-year limited warranty.
HP Keyed Cable Lock - security cable lock
Security cable lock
Package Content
2 x keys
Length
1.83 m
Security cable lock
Package Content
2 x keys
Length
1.83 m
