Help keep your notebook safe in the office and high-traffic areas by tethering it to a secure surface with the HP Master Keyed Cable Lock 10mm, designed specifically for ultra-thin profile notebooks.
                Loop and lockWrap the 6 ft (1.83 m) vinyl-coated, galvanized steel cable around any secure object and attach to your notebook. Insert the master key into the lock and turn clockwise 90 degrees for a great IT manager solution.
                Room to moveThe cable head swivels 360-degrees to help you position the cable as needed before you lock.
                Rest easyGet the reassurance of a one-year limited warranty.
