The HP Integrated Work Center Stand is designed to help maximize the use of limited desk space without compromising performance or productivity by accommodating an HP Compaq 6005 Pro, or 8000 Series HP Ultra-slim Desktop PC or an HP Thin Client and most HP 17 to 24-inch (43.18 to 60.96 cm) diagonal LCD monitors (please refer to compatibility in the Quick Spec) with VESA standard mounting brackets.
- HP Integrated Work Center Stand - monitor/desktop stand
- Product Type
- Monitor/desktop stand
- Package Content
- VGA cable, mounting bracket
- Black, meteorite
- 36.19 cm x 25.05 cm x 37.35 cm
- 3.1 kg
- Tilt adjustment, swivel adjustment, adjustable height, HP Quick Release
- Designed For
- HP L2206tm, L2311c, LA1956x, LA2206xc, LE1711, LE1911, LE1911i, LV2011, LV2011q, LV241, t310, t310 G2, t430, t430 v2, t530, t540, t628, V241, V241a, Z22i; EliteDesk 800 G1; EliteDisplay E201, E221, E221c, E231; Flexible t520, t620; ProDesk 600 G3; ProDisplay P191, P19A, P201, P201m, P221, P231
- Product Type
- Package Content
- 36.19 cm
- 25.05 cm
- 37.35 cm
- 3.1 kg
- Black, meteorite
- Designed For
- HP LE1711, LV2011, LV2011q, LV241, t310, t310 G2, t430, t430 v2, t530, t540, t628, V241, V241a, Z22i , HP EliteDesk 800 G1 , HP EliteDisplay E201, E221, E221c, E231 , HP Flexible t520, t620 , HP ProDesk 600 G3 , HP ProDisplay P191, P19A, P201, P201m, P221, P231 , HP Compaq L2206tm, L2311c, L2311c Notebook Docking Monitor, LA1956x, LA2206xc, LE1711, LE1911, LE1911i
