Professional-quality colour for an exceptional value – up to 16,000 pages per cartridge at an ultra-low cost per page. Get the results you expect with extra-high-yield cartridges designed and engineered for HP PageWide Enterprise devices.
Print up to 16,000 color pages at a significantly lower cost per page than standard cartridges.1 Extra-high-yield cartridges lock in the exceptional value your HP PageWide Enterprise printer was built to deliver.
Produce professional-quality documents at speeds your printer was built for. Original HP PageWide cartridges are precisely engineered to match the high-speed performance of HP PageWide Enterprise printers and MFPs and to deliver consistent results.
Get professional-quality pages and enterprise-level performance every day. Protect your investment with Original HP PageWide cartridges specially designed and precisely engineered for HP printers and MFPs—so you can count on fast, consistent results.
Easily replace cartridges in a snap, and tackle high-volume print jobs without interruptions. Original HP PageWide cartridges make printing easy, so work flows smoothly.
Print up to 16,000 colour pages
Lock in tremendous value and an impressively low cost per page for high-volume printing. -
Print at high speeds – without sacrificing quality
Count on professional-quality results at high speeds, using Original HP PageWide cartridges. -
Cartridges designed for business results
Avoid wasting time troubleshooting device issues, using consistent, reliable Original HP PageWide cartridges. -
Hassle-free cartridges that simply work
Replace cartridges quickly and correctly with easy-open packaging and simple, fast installation.
- HP 981Y - Extra High Yield - magenta - original - PageWide - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- HP Sub-brand
- PageWide
- Printing Colour
- Magenta (pigmented)
- Capacity
- 185 ml
- Cartridge Yield
- Extra High Yield
- Yield
- Up to 16000 pages ISO/IEC 24711
- Compatible with
- PageWide Enterprise Color 556dn, 556xh, MFP 586dn, MFP 586f; PageWide Enterprise Color Flow MFP 586z; PageWide Managed Color E55650dn, MFP E58650dn; PageWide Managed Color Flow MFP E58650z
- Dimensions (WxDxH) / Weight
- 370 g
- Shipping Width
- 22 cm
- Shipping Depth
- 5.2 cm
- Shipping Height
- 4.8 cm
- Shipping Weight
- 390 g
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- HP Sub-brand
- PageWide
- Included Qty
- 1-pack
- Capacity
- 185 ml
- Cartridge Yield
- Extra High Yield
- Yield
- Compatible with
- HP PageWide Enterprise Color 556dn, 556xh, MFP 586dn, MFP 586f , HP PageWide Enterprise Color Flow MFP 586z , HP PageWide Managed Color E55650dn, MFP E58650dn , HP PageWide Managed Color Flow MFP E58650z
