Professional-quality colour for an exceptional value – up to 16,000 pages per cartridge at an ultra-low cost per page. Get the results you expect with extra-high-yield cartridges designed and engineered for HP PageWide Enterprise devices.
Print up to 16,000 color pages at a significantly lower cost per page than standard cartridges. Extra-high-yield cartridges lock in the exceptional value your HP PageWide Enterprise printer was built to deliver.
Produce professional-quality documents at speeds your printer was built for. Original HP PageWide cartridges are precisely engineered to match the high-speed performance of HP PageWide Enterprise printers and MFPs and to deliver consistent results.
Get professional-quality pages and enterprise-level performance every day. Protect your investment with Original HP PageWide cartridges specially designed and precisely engineered for HP printers and MFPs—so you can count on fast, consistent results.
Easily replace cartridges in a snap, and tackle high-volume print jobs without interruptions. Original HP PageWide cartridges make printing easy, so work flows smoothly.
Designed to work the first time, every time
Be assured that Original HP Cartridges will consistently deliver quality results and premium performance. -
Quality prints you can take pride in
Experience premium print quality with Original HP Cartridges designed for vibrant colour, crisp text, and rich blacks for big impact. -
The environmental choice
Print with confidence – Original HP Cartridges designed with the planet in mind for easy recycling and less waste. -
Low cost per page for high-volume printing
Lock in tremendous value and an impressively low cost per page for high-volume printing. -
Extra-high yields, ultra-low cost per page
Get an impressively low cost per page with extra-high-yield cartridges for high-volume printing. -
High-yield options available
Print more pages and replace supplies less often with optional high-yield cartridges.
- HP 981Y - Extra High Yield - cyan - original - PageWide - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- HP Sub-brand
- PageWide
- Printing Colour
- Cyan (pigmented)
- Capacity
- 185 ml
- Cartridge Yield
- Extra High Yield
- Yield
- Up to 16000 pages ISO/IEC 24711
- Compatible with
- PageWide Enterprise Color 556dn, 556xh, MFP 586dn, MFP 586f; PageWide Enterprise Color Flow MFP 586z; PageWide Managed Color E55650dn, MFP E58650dn; PageWide Managed Color Flow MFP E58650z
- Dimensions (WxDxH) / Weight
- 370 g
- Shipping Width
- 22 cm
- Shipping Depth
- 5.2 cm
- Shipping Height
- 4.8 cm
- Shipping Weight
- 390 g
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- HP Sub-brand
- PageWide
- Cyan (pigmented)
- Included Qty
- 1-pack
- Capacity
- 185 ml
- Cartridge Yield
- Extra High Yield
- Yield
- Compatible with
- HP PageWide Enterprise Color 556dn, 556xh, MFP 586dn, MFP 586f , HP PageWide Enterprise Color Flow MFP 586z , HP PageWide Managed Color E55650dn, MFP E58650dn , HP PageWide Managed Color Flow MFP E58650z
