HP HP Officejet Pro 9022e All-in-One - Multifunction printer -
Quicklinx: GJDNWS00 Mfr#: 226Y0B#687
Count on fast print speeds up to to 24 ppm, single-pass two-sided copy/scan, automatic two-sided printing, and a 500 sheet paper tray. Choose HP+ and get 6 months of Instant Ink and 1 extra year HP warranty with use of Original HP Ink.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
  • Customisable shortcuts on your phone or printer
    Eliminate steps in repetitive tasks with Shortcuts in HP app.
  • Create editable, searchable documents
    With Shortcuts in HP app, you can create editable, searchable documents by scanning from your phone or printer.
  • Two-sided. Hands-free. Auto-fed
    Work fast and hands-free with the 35 page auto-feeder. Quickly scan both sides of a page at once.
  • Print at high volumes with dual-tray capacity
    Take on high-volume jobs with confidence, using two 250 sheet paper trays that fit a full ream of paper.
  • Printing just got more productive
    Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive.
HP Officejet Pro 9022e All-in-One - multifunction printer - colour - HP Instant Ink eligible
Fax Type
Plain paper
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
2000 pages
Max Copying Speed
Up to 23 ppm (mono) / up to 17 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 24 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, embedded web browser, Mopria certified, scan to SharePoint, HP Auto-On/Auto-Off Technology, HP Instant Ink, IPP printing, scan to network folder
AC 120/230 V (50/60Hz)
43.7 cm x 39.6 cm x 31.83 cm
11.66 kg
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
2000 pages
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy, margin shift, 2-sided copy orientation change, resize
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
6272 nozzles
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
Ink Palette Supported (Colours)
Pigment cyan, pigment magenta, pigment yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
10 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Printing Speed
Up to 15 ppm
Fax Printing Resolution
203 x 196 dpi
PC Faxing
Fax Machine Features
Speed Dialing
99 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
Min Original Size
76.2 x 127 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
110 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Borderless Photo Sizes
250 sheets
Max Media Capacity
250 sheets
100 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 24 ppm (A4) - B/W (ISO) , Printing: up to 20 ppm (A4) - colour (ISO) , Printing: up to 39 ppm (A4) - B/W draft , Printing: up to 39 ppm (A4) - colour draft , Copying: up to 39 ppm (A4) - B/W draft , Copying: up to 39 ppm (A4) - colour draft , Scanning: up to 15 ppm (A4) - B/W , Scanning: up to 8 ipm (A4) - colour , Scanning: up to 15 ppm (A4) - B/W duplex , Scanning: up to 6 ppm (A4) - colour duplex , Copying: up to 5 ppm (A4) - B/W best , Copying: up to 4 ppm (A4) - colour best
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
SSL, TLS, WPA2, 802.1x, WPA2-Enterprise
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Chrome OS, Apple Mac OS X 10.11, MS Windows Server 2016, macOS 10.13, macOS 10.12.x
Software Included
Software HP Printer
30 Watt
Power Consumption Standby
5.8 Watt
Power Consumption Sleep
1.22 Watt
First Copy Out Time B/W
7 sec
First Copy Out Time Colour
9 sec
Consumables Included
1 x ink cartridge (black) - HP 963 , 1 x ink cartridge (cyan) - HP 963 , 1 x ink cartridge (magenta) - HP 963 , 1 x ink cartridge (yellow) - HP 963
FCC CFR47 Part 15 B, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, EN 301 489-1, EN 61000-3-2:2014, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, UL 62368-1 Second Edition, ICES-003 issue 6 Class B, CISPR 32:2012, EN 301 489-17, EN 55032:2012 Class B, IEC 62368-1: 2014 Second Edition, RED 2014/53/EU, EN 62368-1:2014+A11:2017, ES 203 021-2, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Limited warranty - parts - 1 year , Technical support - web support - 1 year
43.7 cm
39.6 cm
31.83 cm
11.66 kg
Shipping Width
49.6 cm
Shipping Depth
37.7 cm
Shipping Height
48.9 cm
Shipping Weight
14.2 kg
Sound Emission
64 dBA (operating)
5 °C
20 - 80%
Ink (9)
GJDN HP 963 Black Original Ink Cartridge In Stock £23.81
GJDN HP 963 Cyan Original Ink Cartridge In Stock £17.43
GJDN HP 963 Magenta Original Ink Cartridge In Stock £17.43
GJDN HP 963 Yellow Original Ink Cartridge In Stock £17.43
GJDN HP 963XL High Yield Black Original Ink Cartridge In Stock £37.12
GJDN HP 963XL High Yield Cyan Original Ink Cartridge In Stock £27.69
GJDN HP 963XL High Yield Magenta Original Ink Cartridge In Stock £27.69
GJDN HP 963XL High Yield Yellow Original Ink Cartridge In Stock £27.69
GJDN HP HP 963 4-Pack Original Ink Cartridge In Stock £75.33
Other bundles (1)
GJDN HP Care Pack Next Business Day Hardware Exchange - Extended In Stock £60.66
