HP HP Officejet Pro 8025e All-in-One Multifunction printer with 6 month of instant ink with HP plus
Quicklinx: GJDHWS00 Mfr#: 229W9B#687
Count on the fast print speeds up to 20 ppm, automatic two-sided printing, and reliable Wi-Fi connectivity. Choose HP+ and get 6 months of Instant Ink and 1 extra year of HP warranty with exclusive use of Original HP Ink.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
  • Customisable shortcuts on your phone
    Eliminate steps in repetitive tasks with Shortcuts in HP Smart app.
  • Hands-free. Auto-fed
    Work fast and hands-free with the 35 page auto-feeder.
  • Ready when you are
    Connect to cloud-based printing with Wi-Fi or your cellular network.
  • Printing just got more productive
    Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive.
  • Your reliable connection
    Reduce interruptions with self-healing Wi-Fi that keeps you connected.
HP Officejet Pro 8025e All-in-One - multifunction printer - colour - HP Instant Ink eligible
Fax Type
Plain paper
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
800 pages
Max Copying Speed
Up to 13 ppm (mono) / up to 7 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 20 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
Standard Media Capacity
225 sheets
Max Media Capacity
225 sheets
Output Trays Capacity
60 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, embedded web browser, Mopria certified, scan to SharePoint, HP Auto-On/Auto-Off Technology, HP Instant Ink, IPP printing, scan to network folder
AC 120/230 V (50/60Hz)
46 cm x 34.12 cm x 23.4 cm
8.2 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
20000 pages
800 pages
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy, margin shift, 2-sided copy orientation change, resize
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1760 nozzles
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
Ink Palette Supported (Colours)
Pigment cyan, pigment magenta, pigment yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
13 sec
First Print Out Time Colour
16 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Printing Speed
Up to 15 ppm
Fax Printing Resolution
203 x 196 dpi
PC Faxing
Fax Machine Features
Speed Dialing
99 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
Min Original Size
76.2 x 127 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
110 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Borderless Photo Sizes
225 sheets
Max Media Capacity
225 sheets
60 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 225 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W (ISO) , Printing: up to 10 ppm (A4) - colour (ISO) , Printing: up to 29 ppm (A4) - B/W draft , Printing: up to 25 ppm (A4) - colour draft , Copying: up to 29 ppm (A4) - B/W draft , Copying: up to 23 ppm (A4) - colour draft , Scanning: up to 8 ppm (A4) - B/W , Scanning: up to 3.5 ppm (A4) - colour , Copying: up to 3 ppm (A4) - B/W best , Copying: up to 2 ppm (A4) - colour best
1 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
SSL, TLS, WPA2, 802.1x, EAP-TLS, PEAP, WPA2-Enterprise
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Chrome OS, Apple Mac OS X 10.11, MS Windows Server 2016, macOS 10.13, macOS 10.12.x
Software Included
Software HP Printer
21 Watt
Power Consumption Standby
5.8 Watt
Power Consumption Sleep
1 Watt
First Copy Out Time B/W
18 sec
First Copy Out Time Colour
12 sec
Consumables Included
1 x ink cartridge (black) - HP 912 , 1 x ink cartridge (cyan) - HP 912 , 1 x ink cartridge (magenta) - HP 912 , 1 x ink cartridge (yellow) - HP 912
FCC CFR47 Part 15 B, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, EN 301 489-1, EN 61000-3-2:2014, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, UL 62368-1 Second Edition, ICES-003 issue 6 Class B, CISPR 32:2012, EN 301 489-17, EN 55032:2012 Class B, IEC 62368-1: 2014 Second Edition, RED 2014/53/EU, EN 62368-1:2014+A11:2017, ES 203 021-2, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
ENERGY STAR Certified
Limited warranty - parts - 1 year , Technical support - web support - 1 year
46 cm
34.12 cm
23.4 cm
8.2 kg
Shipping Width
50.6 cm
Shipping Depth
29.8 cm
Shipping Height
40.8 cm
Shipping Weight
10.4 kg
Sound Emission
62 dBA (operating)
5 °C
20 - 80%
Ink (7)
GJDH HP 912 Black Original Ink Cartridge In Stock £12.02
GJDH HP 912 Cyan Original Ink Cartridge In Stock £7.20
GJDH HP 912 Magenta Original Ink Cartridge In Stock £7.20
GJDH HP 912 Yellow Original Ink Cartridge In Stock £7.20
GJDH HP 912XL High Yield Black Original Ink Cartridge In Stock £26.81
GJDH HP 912XL High Yield Cyan Original Ink Cartridge In Stock £14.09
GJDH HP 912XL High Yield Magenta Original Ink Cartridge In Stock £14.09
Other bundles (1)
GJDH HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £32.80
