HP Multi-Protocol proximity card readers are designed to leverage your existing card system for applications beyond physical security.
- HP LEGIC - RF proximity reader - USB
- Interface Type
- USB
- Frequency
- 13.56 MHz
- 7.66 cm x 5.12 cm x 1.17 cm
- 26 g
- Jack black
- OS Required
- Linux, Microsoft Windows XP / 7 / 8.1 / 10
- Designed For
- Color LaserJet Enterprise M455, M554, M555, MFP 6800, MFP M480, MFP M578; LaserJet Enterprise M406, M554, M555, M610, M611, M612, MFP M430, MFP M634, MFP M635, MFP M636; LaserJet Enterprise Flow MFP M578, MFP M634, MFP M635, MFP M636; LaserJet Managed MFP E42540, MFP E72425-E72430, MFP E77422-E77428
- Interface Type
- USB
- Frequency
- 13.56 MHz
- 7.66 cm
- 5.12 cm
- 1.17 cm
- 26 g
- Jack black
- Connections
- 1 x USB
- Device Features
- USB powered, LED indicator
- FCC, RCM, IC, RoHS, REACH
- Software Included
- HP Card Reader Configuration Utility
- OS Required
- -30 °C
- 65 °C
- 5 - 95% (non-condensing)
- Designed For
- HP Color LaserJet Enterprise M455dn, M554dn, M555dn, M555x, M751dn, M751n, M856dn, M856x, MFP 6800dn, MFP M480f, MFP M578dn, MFP M578f, MFP M776dn , HP Color LaserJet Managed E65150dn, E65160dn, E85055dn , HP Color LaserJet Managed Flow MFP E67660z , HP LaserJet Enterprise M406dn, M507dn, M507dng, M507x, M554dn, M555dn, M610dn, M611dn, M611x, M612dn, M612x, MFP M430f, MFP M528dn, MFP M528f, MFP M634dn, MFP M634z, MFP M635fht, MFP M635h, MFP M636fh , HP LaserJet Enterprise Flow MFP M528c, MFP M528z, MFP M578c, MFP M578z, MFP M634h, MFP M635z, MFP M636z, MFP M776z, MFP M776zs , HP LaserJet Managed E60155dn, E60165dn, E60175dn, MFP E42540f, MFP E62655dn, MFP E62665hs, MFP E72425-E72430dn, MFP E77422dn, MFP E77422dv, MFP E77422-E77428dn, MFP E77428dn , HP LaserJet Managed Flow MFP E62665h, MFP E62665z
