The HP ProBook 450 Laptop provides growing businesses with the commercial-grade performance, HP Wolf Security for Business, and durability in a compact design. This PC is powered by an Intel processor and protected with always-on security you can trust.
Windows 11
Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology. -
High performance, high portability
Get the exceptional combination of responsive performance, connectivity and speed with a 12th Gen Intel Core processor that lets you launch, create, and connect fast and reliably. -
Security is your top priority
The HP Wolf Pro Security Edition provides preconfigured enterprise-level PC protection for small and medium sized businesses. -
Fast and efficient wireless LAN
The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6. -
Preserve your privacy
Never wonder if someone is watching you with the added peace-of-mind that comes from the integrated HP Privacy Camera, with a physical shutter to protect from malicious surveillance. -
HP Sure Sense
Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
- HP ProBook 450 G9 Notebook - 15.6" - Intel Core i5 - 1235U - 16 GB RAM - 256 GB SSD - UK - with HP Wolf Pro Security Edition (1 year)
- Product Type
- Notebook
- Operating System
- Win 11 Pro - English
- Processor
- Intel Core i5 (12th Gen) - 1235U / 1.3 GHz, up to 4.4 GHz / 12 MB Cache
- Memory
- 16 GB DDR4 (1 x 16 GB)
- Storage
- 256 GB SSD - NVMe
- Display
- 15.6" WLED 1920 x 1080 / Full HD @ 60 Hz
- Graphics
- Intel Iris Xe Graphics
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3, Gigabit Ethernet
- Battery
- 3-cell - up to 12.25 hours
- HP Tamper Lock
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 35.94 cm x 23.39 cm x 1.99 cm
- 1.74 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
- Bundled with
- HP Wolf Pro Security Edition (1 year)
- Product Type
- Notebook
- Operating System
- Windows 11 Pro - English
- Bundled with
Processor / Chipset
- CPU
- Intel Core i5 (12th Gen) 1235U / 1.3 GHz
- Max Turbo Speed
- 4.4 GHz
- Number of Cores
- 10-core
- Cache
- L3 - 12 MB
- Hyper-Threading Technology, Intel Turbo Boost Technology, Intel Smart Cache
- RAM
- 16 GB (1 x 16 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 3200 MHz
- Rated Speed
- 3200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
- 15.6" - IPS
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, narrow bezel bent
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- Video System Features
- Functions as Intel UHD graphics (for single-channel memory)
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- Privacy shutter, IR camera
- Sound
- Dual stereo speakers, dual array microphone
- Codec
- Realtek ALC3247-CG
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-touch clickpad, gesture function, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6E AX 211 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Miracast, Wake-on-LAN (WOL), dual stream (2x2), MU-MIMO, CNVi
- Wi-Fi CERTIFIED
- Technology
- 3-cell lithium polymer
- Capacity
- 51.3 Wh
- Run Time
- Up to 12.25 hours
AC Adapter
- Input
- AC 115/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V, 8 A
Connections & Expansion
- Interfaces Details
- USB 3.2 Gen 1 (powered) , USB 3.2 Gen 1 (charging) , USB 3.2 Gen 1 , USB-C 3.2 Gen 2 (supports DisplayPort 1.4 Alt Mode) (Power Delivery) , LAN , Headphone/microphone combo jack , HDMI
Software
- Software Included
- HP Support Assistant, HP Hotkey Support, HP Secure Erase, HP Client Catalogue (free download), HP Image Assistant (free download), HP PC Hardware Diagnostics, HP Notifications, HP Connection Optimizer, HP Sure Click, HP Privacy Settings, HP Sure Sense, HP Sure Admin, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, HP DriveLock, myHP, HP Quick Touch, HP Sure Start Gen7
- Integrated Options
- HP Tamper Lock
- Security
- BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, HP Fast Charge, BIOS Update via Network, MIL-STD-810H tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP 45 Watt Smart nPFC AC Adapter
- CSA, UL, VCCI, BSMI, GOST, GS, SABS, FIPS 140-2 Level 2, FCC, RoHS, WEEE, A-Tick, ICES, Common Criteria EAL4+, KC, EAC, CIT, UL 1642, low halogen, IEEE 1680, ICCP, BNCI
- Localization
- 1.74 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 1.043 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 3.5 g @ RMS (random)
Essential Accessories (10)
Get more from your purchase from one of our essential accessories
HP 65W Smart AC Adapter | In Stock | £16.11 |
HP 65W Smart AC Adapter | In Stock | £16.69 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £111.61 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £142.46 |
HP USB-C TO RJ45 Adapter | In Stock | £185.96 |
HP USB-C Power Adapter - 65 Watt | In Stock | £56.59 |
HP Prelude Top Load 15.6" Notebook Carrying Case | In Stock | £10.06 |
HP Smart AC Adapter - 65 Watt | In Stock | £17.24 |
HP Nano - Security Cable Lock | In Stock | £15.46 |
HP Renew Business - Notebook carrying shoulder bag - 17.3" | In Stock | £18.56 |
Warranty Packs (4)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site | In Stock | £82.73 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £120.04 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site | In Stock | £72.06 |
HP Care Pack NBD HW Support with Defective Media Retention Extended Service Agreement 3 Yrs On-Site | In Stock | £83.56 |
Other bundles (50)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.11 |
HP USB G2 Stereo Headset | In Stock | £19.85 |
HP 128 Wired Mouse | In Stock | £8.31 |
HP 455 Programmable Keyboard - Wireless - UK | In Stock | £25.68 |
HP 325 Webcam | In Stock | £18.52 |
Poly Voyager Focus 2 UC-M C USB-A WW | In Stock | £99.99 |
Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter | In Stock | £214.79 |
Poly Voyager 4320 UC V4320-M C USB-A WW | In Stock | £110.85 |
Poly Voyager 4320 UC V4320 C USB-C WW | In Stock | £103.93 |
Poly DA85-M Sound Card | In Stock | £44.79 |
Poly Blackwire C3225 USB-A Headset | In Stock | £51.63 |
Poly Voyager 4320 UC V4320-M C USB-A CS WW | In Stock | £108.73 |
Poly Voyager 4320 UC V4320-M C USB-C WW | In Stock | £110.85 |
Poly Voyager 4320 UC V4320 C USB-A CS WW | In Stock | £119.53 |
Poly Voyager 4310 UC V4310-M C USB-A WW | In Stock | £100.88 |
Poly Voyager 4320 UC V4320 C USB-C CS WW | In Stock | £120.20 |
Poly Voyager 4320 UC V4320-M C USB-C CS WW | In Stock | £110.60 |
Poly Voyager 4310 UC V4310-M C USB-A CS WW | In Stock | £110.24 |
Poly Voyager 4320 UC V4320 C USB-A WW | In Stock | £86.60 |
Poly Voyager 4310 UC V4310 C USB-A CS WW | In Stock | £110.24 |
Poly Sync 10 SY10-M USB-A/C WW | In Stock | £55.19 |
Poly Voyager Focus 2 UC-M USB-C Headset with Stand | In Stock | £141.12 |
Poly EncorePro 525 USB EP525-M USB-A Headset | In Stock | £42.79 |
Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C | In Stock | £108.13 |
Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified | In Stock | £30.52 |
Poly Poly Blackwire 3320 Stereo USB-C/A Adapter | In Stock | £30.52 |
Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C | In Stock | £68.11 |
Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified | In Stock | £49.32 |
HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £161.91 |
HP OMEN 24" Full HD 165Hz Gaming Monitor | In Stock | £121.33 |
HP OMEN 27" Full HD 165Hz Gaming Monitor | In Stock | £145.60 |
Poly Blackwire 3210 headset - on-ear - wired - USB-C - black | In Stock | £25.20 |
Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter | In Stock | £62.91 |
Poly Blackwire 3310 headset - on-ear - wired - USB-A - black | In Stock | £25.49 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £27.57 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £26.20 |
Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter | In Stock | £28.00 |
Poly EncorePro 515-M headset - on-ear - wired - USB-A - black | In Stock | £75.67 |
HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £320.60 |
HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor | In Stock | £608.47 |
Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams | In Stock | £110.24 |
Poly EncorePro HW520D - headset - Quick Disconnect | In Stock | £105.92 |
HP E24m G4 23.8" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor | In Stock | £211.64 |
Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £49.49 |
HP 230 - keyboard and mouse set - UK Input Device | In Stock | £36.17 |
Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £49.77 |
HP 715 - mouse - multi-device, rechargeable - Bluetooth 3.0, 2.4 GHz - black | In Stock | £49.60 |
HP E27 G5 27" 1920x1080 5ms HDMI DisplayPort USB IPS LED Monitor | In Stock | £132.34 |
