HP HP 450G9 I51235U 16GB/256GB W11P
Quicklinx: HNJ7WS00 Mfr#: 85D69EA#ABU
  • Core i5
  • IEEE 802.11n
The HP ProBook 450 Laptop provides growing businesses with the commercial-grade performance, HP Wolf Security for Business, and durability in a compact design. This PC is powered by an Intel processor and protected with always-on security you can trust.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • High performance, high portability
    Get the exceptional combination of responsive performance, connectivity and speed with a 12th Gen Intel Core processor that lets you launch, create, and connect fast and reliably.
  • Security is your top priority
    The HP Wolf Pro Security Edition provides preconfigured enterprise-level PC protection for small and medium sized businesses.
  • Fast and efficient wireless LAN
    The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6.
  • Preserve your privacy
    Never wonder if someone is watching you with the added peace-of-mind that comes from the integrated HP Privacy Camera, with a physical shutter to protect from malicious surveillance.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
HP ProBook 450 G9 Notebook - 15.6" - Intel Core i5 - 1235U - 16 GB RAM - 256 GB SSD - UK - with HP Wolf Pro Security Edition (1 year)
Notebook
Operating System
Win 11 Pro - English
Intel Core i5 (12th Gen) - 1235U / 1.3 GHz, up to 4.4 GHz / 12 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
256 GB SSD - NVMe
Display
15.6" WLED 1920 x 1080 / Full HD @ 60 Hz
Graphics
Intel Iris Xe Graphics
Input Device
ClickPad
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3, Gigabit Ethernet
3-cell - up to 12.25 hours
HP Tamper Lock
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
35.94 cm x 23.39 cm x 1.99 cm
1.74 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Bundled with
Notebook
Operating System
Windows 11 Pro - English
Bundled with
Processor / Chipset
CPU
Intel Core i5 (12th Gen) 1235U / 1.3 GHz
Max Turbo Speed
4.4 GHz
Number of Cores
10-core
Cache
L3 - 12 MB
Hyper-Threading Technology, Intel Turbo Boost Technology, Intel Smart Cache
RAM
16 GB (1 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
3200 MHz
Rated Speed
3200 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
15.6" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, narrow bezel bent
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Video System Features
Functions as Intel UHD graphics (for single-channel memory)
Camera
Yes - HD
Video Resolutions
720p
Camera Features
Privacy shutter, IR camera
Sound
Dual stereo speakers, dual array microphone
Codec
Realtek ALC3247-CG
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Multi-touch clickpad, gesture function, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6E AX 211 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Miracast, Wake-on-LAN (WOL), dual stream (2x2), MU-MIMO, CNVi
Wi-Fi CERTIFIED
3-cell lithium polymer
51.3 Wh
Run Time
Up to 12.25 hours
AC Adapter
Input
AC 115/230 V (50/60 Hz)
Output
45 watt, 19.5 V, 8 A
Connections & Expansion
Interfaces Details
USB 3.2 Gen 1 (powered) , USB 3.2 Gen 1 (charging) , USB 3.2 Gen 1 , USB-C 3.2 Gen 2 (supports DisplayPort 1.4 Alt Mode) (Power Delivery) , LAN , Headphone/microphone combo jack , HDMI
Software
Software Included
HP Support Assistant, HP Hotkey Support, HP Secure Erase, HP Client Catalogue (free download), HP Image Assistant (free download), HP PC Hardware Diagnostics, HP Notifications, HP Connection Optimizer, HP Sure Click, HP Privacy Settings, HP Sure Sense, HP Sure Admin, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, HP DriveLock, myHP, HP Quick Touch, HP Sure Start Gen7
Integrated Options
HP Tamper Lock
Security
BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, HP Fast Charge, BIOS Update via Network, MIL-STD-810H tested
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
HP 45 Watt Smart nPFC AC Adapter
CSA, UL, VCCI, BSMI, GOST, GS, SABS, FIPS 140-2 Level 2, FCC, RoHS, WEEE, A-Tick, ICES, Common Criteria EAL4+, KC, EAC, CIT, UL 1642, low halogen, IEEE 1680, ICCP, BNCI
Localization
1.74 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Essential Accessories (8)
Get more from your purchase from one of our essential accessories
HNJ7 HP 65W Smart AC Adapter In Stock £17.30
HNJ7 HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £185.94
HNJ7 HP USB-C Power Adapter - 65 Watt In Stock £56.88
HNJ7 HP Prelude Top Load 15.6" Notebook Carrying Case In Stock £10.26
HNJ7 HP USB-C LC Power Adapter - 65 Watt In Stock £15.15
HNJ7 HP Smart AC Adapter - 65 Watt In Stock £16.61
HNJ7 HP Nano - Security Cable Lock In Stock £15.78
HNJ7 HP Renew Business - Notebook carrying shoulder bag - 17.3" In Stock £18.95
Warranty Packs (4)
Protect your investment by taking out one of our great value warranty packs
HNJ7 HP Care Pack NBD Hardware Support for Travelers with Defective Media Retention 3 Years On-Site In Stock £88.90
HNJ7 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £122.54
HNJ7 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £78.09
HNJ7 HP Care Pack NBD HW Support with Defective Media Retention Extended Service Agreement 3 Yrs On-Site In Stock £85.30
Other bundles (53)
HNJ7 HP USB-C To VGA Adapter In Stock £23.07
HNJ7 HP USB Travel Mouse In Stock £9.28
HNJ7 HP USB-C to HDMI 2.0 Adapter In Stock £47.48
HNJ7 HP USB G2 Stereo Headset In Stock £20.27
HNJ7 HP 128 Wired Mouse In Stock £8.49
HNJ7 HP 455 Programmable Keyboard - Wireless - UK In Stock £46.54
HNJ7 HP 325 Webcam In Stock £18.90
HNJ7 Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £208.06
HNJ7 Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A In Stock £216.07
HNJ7 Poly DA75 Sound Card In Stock £27.52
HNJ7 Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £103.25
HNJ7 Poly Voyager 4320 UC V4320 C USB-C WW In Stock £106.60
HNJ7 Poly TRIO C60 EXPANSION MICROPHONES In Stock £147.98
HNJ7 Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £43.34
HNJ7 Poly Voyager 4320 UC V4320-M C USB-A CS WW In Stock £108.73
HNJ7 Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £103.25
HNJ7 Poly Voyager 4320 UC V4320 C USB-A CS WW In Stock £117.00
HNJ7 Poly Voyager 4320 UC V4320 C USB-C CS WW In Stock £120.32
HNJ7 Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £111.68
HNJ7 Poly Voyager 4310 UC V4310-M C USB-A CS WW In Stock £108.17
HNJ7 Poly Voyager 4320 UC V4320 C USB-A WW In Stock £103.25
HNJ7 Poly Voyager 4310 UC V4310 C USB-A WW In Stock £98.17
HNJ7 Poly Voyager 4310 UC V4310 C USB-A CS WW In Stock £108.17
HNJ7 Poly Sync 10 SY10-M USB-A/C WW In Stock £55.47
HNJ7 Poly EncorePro 525 USB EP525 USB-A Headset In Stock £87.67
HNJ7 Poly Voyager Focus 2 UC-M USB-C Headset with Stand In Stock £141.12
HNJ7 Poly Sync 40 SY40-M WW In Stock £123.47
HNJ7 Poly EncorePro 525 USB EP525-M USB-A Headset In Stock £90.57
HNJ7 Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £109.67
HNJ7 Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £29.68
HNJ7 Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £68.27
HNJ7 Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £45.23
HNJ7 HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £167.73
HNJ7 Poly Blackwire 3210 headset - on-ear - wired - USB-C - black In Stock £25.87
HNJ7 Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £59.09
HNJ7 Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £24.80
HNJ7 Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £29.67
HNJ7 Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £25.27
HNJ7 Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £24.80
HNJ7 Poly EncorePro 515-M headset - on-ear - wired - USB-A - black In Stock £77.77
HNJ7 HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £501.52
HNJ7 HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £621.41
HNJ7 Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams In Stock £108.17
HNJ7 Poly EncorePro HW520D - headset - Quick Disconnect In Stock £106.47
HNJ7 Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £49.75
HNJ7 HP 230 - keyboard and mouse set - UK Input Device In Stock £36.36
HNJ7 Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £48.40
HNJ7 HP 715 - mouse - multi-device, rechargeable - Bluetooth 3.0, 2.4 GHz - black In Stock £50.45
HNJ7 Poly HP Poly Blackwire 3215 - headset - 3.5 mm jack, USB-C In Stock £46.27
HNJ7 Poly Blackwire 5210 - headset - 3.5 mm jack, USB-C In Stock £53.80
HNJ7 Poly Blackwire 3220 USB-C HS +USB-C/A Headset In Stock £26.96
HNJ7 Poly Blackwire 5220 USB-C HS +USB-C/A Headset In Stock £55.67
