Print high-quality documents with Original HP ink cartridges – designed with the printer for excellent worry-free performance.
Designed to work the first time, every time
Be assured that HP Original Cartridges will consistently deliver quality results and premium performance. -
Quality prints you can take pride in
Experience premium print quality with HP Original Cartridges designed for vibrant colour, crisp text, and rich blacks for big impact. -
The environmental choice
Print with confidence – HP Original Cartridges designed with the planet in mind for easy recycling and less waste. -
Better together. Better results
HP Original Cartridges are the only cartridges precisely developed with HP printers for reliable quality, results, and consistent performance. -
Get the most from your ink
Get the most from your HP printer – and your ink. Print the high-quality documents and store-quality photos you need, using HP Original Ink Cartridges. Choose between cartridge sizes to match your printing volume and budget. -
Crisp, sharp text and vivid colours
Make a good impression with HP Original Ink Cartridges – designed to deliver vivid colour and crisp, sharp text.
- HP 305 - 2-pack - black, colour (cyan, magenta, yellow) - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Black, colour (cyan, magenta, yellow)
- Yield
- Up to 120 pages (black) , Up to 100 pages (yellow/cyan/magenta)
- Included Qty
- 2-pack
- Compatible with
- Deskjet 1200, 23XX, 27XX, 28XX, 41XX, 42XX; DeskJet Plus 41XX; ENVY 60XX, 64XX; ENVY Pro 64XX
- Dimensions (WxDxH) / Weight
- 89 g
- Shipping Width
- 10.9 cm
- Shipping Depth
- 3.85 cm
- Shipping Height
- 12.5 cm
- Shipping Weight
- 90 g
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Included Qty
- 2-pack
- Consumables Included
- 1 x ink cartridge (black) - up to 120 pages , 1 x ink cartridge (yellow/cyan/magenta) - up to 100 pages
- Compatible with
- HP Deskjet 1200c, 1200c/ps, 1200ps, 2320, 2330, 2331, 2332, 2710, 2710e, 2720, 2720e, 2721, 2721e, 2722, 2722e, 2723, 2723e, 2724, 2725, 2729, 2732, 2734e, 2742, 2742e, 2752, 2752e, 2755, 2755e, 2776, 2810e, 2820e, 2821e, 2822e, 2823e, 2855e, 4110e, 4120e, 4121e, 4130e, 4132e, 4152e, 4155e, 4158e, 4175e, 4210e, 4220e, 4222e, 4230e, 4255e , HP DeskJet Plus 4110, 4120, 4121, 4122, 4122e, 4123, 4130, 4140, 4152, 4155, 4155e, 4158 , HP ENVY 6010, 6010e, 6020, 6020e, 6022, 6022e, 6030, 6030e, 6032, 6032e, 6034, 6034e, 6052, 6052e, 6055, 6055e, 6058, 6075, 6420e, 6430e, 6432e, 6452e, 6455e, 6458e , HP ENVY Pro 6420, 6422, 6430, 6430e, 6432, 6432e, 6452, 6454, 6455, 6455e, 6458, 6475
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HCTD 051376 Condition: Damaged stock - Item is new but has packaging damage |
£13.70 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
